Originally Posted by Sperkowsky
Ok so what do you recommend in particular.
I've heard copper pipe is ok but what about conduit. That stuff is still decently cheap.
Also how thick and how much do we need.
Lastly what do you reccomend as a valve is a sprinkler valve ok.
Copper pipe is good.
Conduit may or may not be good. If it is plastic (especially PVC), do not use it. If it's metal conduit, that should work.
Copper 1/16" wall is enough for the ~60PSI shock that the barrel should see max.
The biggest thing with the valve is safety and leakage. Make sure the valve is GAS rated for the max pressure it will see. The gas rating is important because most other valves will leak as well as possibly burst.
Well we can't afford 5k that's for sure. We also don't need or want anything fancy looking we just want to shoot one shirt decently safely and move around
The most important thing here is safety. Remember that this will be in the public eye. Any failure, especially one that results in unexpected release of pressurized air, is very bad.
If you cannot afford to ensure it is completely safe at all times then don't build it. That being said, with some leftover KOP/FirstChoice parts you should be able to build a decent safe single shooter for a few hundred dollars.
