Go to Post I've now read Dolly Parton's entire wikipedia page, which was not something I expected to do - WinterPoet [more]
Thread Tools Rating: Thread Rating: 5 votes, 4.40 average. Display Modes
  #31   Spotlight this post!
Unread 26-02-2015, 01:26
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
Re: Quotes from the Chief Engineer and I
Originally Posted by Spoam View Post
Since I guess no one else has mentioned it, the only reason OP is "correct" is because in Java "2d" arrays neither row-major nor column-major. Java arrays aren't truly multidimensional (all data contiguously stored in rm or cm order) they're just arrays of arrays.
That's almost exactly how we were trying to explain it to the teacher. I've always visualized a 2d array as an array of arrays, and a so called 3d as an array of those arrays of arrays. And so forth and so on. I don't really like how my teacher draws them like:
Because while it may be all nice and cool to look at it's not how I've always understood them to be.
  #32   Spotlight this post!
Unread 26-02-2015, 09:30
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
One thing to remember is that conventions exist for a reason. It is for some purposes important to know whether a computer stores:
a b c
d e f
g h i
as: a b c d e f g h i
or: a d g b e h c f i
It is also sometimes important to know if your language interprets a two dimensional array as an array of arrays or as one array. (This usually determines where the data are actually stored.) As has been said, it can be important to know how your language, or more properly how your compiler, does storage to make certain processes faster.
But in most cases if you are trying to understand a two dimensional matrix as a linear thing you are missing the point. If you had data that was appropriately thought of as linear you should use a one dimensional array. The convention exists in order to make it easier conceptually to understand the relationship between the pieces of data. I have an old boss who would probably say something like "Yes, you can conceptualize this as column, row and comment it and the code will work. But you won't. At least here."
You should use a matrix when you have data that is being referenced according to two different indices or categories. Consider an example. Imagine you are storing data for one of three different starting orientations for your robot and five different initial positions. This is a case where there is no obvious reason to make one the row and one the column. When you are designing the program, if you create a 3 row by 5 column table your coding standards should absolutely dictate how that will be coded. It should not be up the whim of one individual programmer.
The row major convention was most likely chosen because a majority of the people who developed the programming languages we now use read and write in a left to right, top down (in other words row major) language like English.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
  #33   Spotlight this post!
Unread 26-02-2015, 11:24
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Originally Posted by wireties View Post
Express your solution in a diagram or notation of some sort (UML or simple flow diagrams and so on) first. When you start coding, comment first and fill in the code afterwards. If your style is good, the code is readable and the comments explain the algorithm. Little else is really necessary no matter the audience.
+1 on this. Write your comments first to express your algorithm, then fill in the code. Saves effort.
  #34   Spotlight this post!
Unread 26-02-2015, 12:14
The OP was talking of basic concepts, not efficient linear algebra algorithms.
Understood. My post was mostly for the benefit of other readers, particularly high school students, who may have been left with the impression that row-major vs column-major storage never makes a difference.
  #35   Spotlight this post!
Unread 26-02-2015, 12:25
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
http://zone.ni.com/reference/en-XX/h...sing_matrices/
Matrices a la LabView.
http://www.mathworks.com/help/matlab...nd-arrays.html
Matrices a la MatLab.
Sometimes arguing about the visual representation of data is basically a course in UI and graphics arts.
You can spend literally your entire life arguing which view is the best one. Like any communications - the 'right' one is that one that manages to deliver the right messsage as fast as possible to the audience to which it was intended.
  #36   Spotlight this post!
Unread 26-02-2015, 12:33
Since your post is linked to mine I'll assume that was the intended context, since no other context was given.
I'll try to be clearer:
My post had nothing to do with "arguing which view is the best one". It was simply pointing out that there are domains in which a knowledge of how your programming language stores matrix elements is important.
  #37   Spotlight this post!
Unread 26-02-2015, 12:43
techhelpbb's Avatar
It's no problem, I did not intend for my post to be linked to yours at all.
I intended to address the topic in general.
However to go back to your point, if you consider the computers 'view' of the data you are absolutely correct.
Just as it wouldn't make sense to fight little-endian / big-endian it doesn't make any sense to fight the way your language works.
http://en.wikipedia.org/wiki/Endianness
Danny Cohen's "On Holy Wars and a Plea for Peace" published in 1980[7] ends with: "Swift's point is that the difference between breaking the egg at the little-end and breaking it at the big-end is trivial. Therefore, he suggests, that everyone does it in his own preferred way. We agree that the difference between sending eggs with the little- or the big-end first is trivial, but we insist that everyone must do it in the same way, to avoid anarchy. Since the difference is trivial we may choose either way, but a decision must be made."
  #38   Spotlight this post!
Unread 26-02-2015, 13:20
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
Don't forget that OP is in a AP CS course. Java is a tool to teach basic concepts in CS, not just programming, not just a specific language.
It's basically beginning course, in which you are learning the basic building blocks, vocabulary, and conventions. This is how people in the trade communicate with each other.
  #39   Spotlight this post!
Unread 26-02-2015, 15:39
MatthewC529 MatthewC529 is offline
Lcom/mattc/halp;
AKA: Matthew
FRC #1554 (Oceanside Sailors)
MatthewC529 is on a distinguished road
I mean it does not matter, but the JVM does attempt to store one-dimensional arrays contiguously, especially for primitives. Though there is, of course, no guarantee.
It is just much easier to imagine a matrix with 0,0 at the top left since this is how so many things in Java are represented. The only time I was able to use a non-standard matrix was in LibGDX where it represents it's display with 0,0 at the bottom (though you can flip it).
Of course you are right though, I can represent a Matrix as a NxM length single-dimensional array if I wanted to.
Team 1554 -- Oceanside Sailors
  • 2013-2014 - Lead/Sole Programmer
  • 2014-2015 - Lead Programmer, President
  • 2015-? - Team 1554 Mentor
Independent Public Projects
Developer at Legend Zero LLC.
Java/C++ Programmer
  #40   Spotlight this post!
Unread 26-02-2015, 19:25
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Originally Posted by King Nerd III View Post
It really frustrates me that my so called AP Computer Science teacher hasn't taught this since haskell, had to learn Java over the summer (he pronounces it as Jaiva, it can get irritating), and said, and I quote, "Java is the most popular programming language because three billion devices sounds like a lot". He just makes me want to smash my head into a wall. At least he got us 4 megabyte jumpdrives!
Keep in mind that many schools don't have any CS classes, let alone AP.
Take this as training for dealing with a boss that annoys you, or motivation to start your own company so that you can be that annoying boss.
  #41   Spotlight this post!
Unread 26-02-2015, 19:38
AKA: Isaac
At this point I would rather not have the class and do what they had done the past few years and done the class as an independent study. Half the class has no idea what a primitive is because he taught that all variables are objects, even ints and chars and the such. I think no class would be better than a class that is almost guaranteeing that you learn the wrong thing. I get your point about being grateful to have a class, but sometimes no class is better than a horrible one.
  #42   Spotlight this post!
Unread 26-02-2015, 22:26
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Is it possible the confusion on primitives vs objects comes from the way the Java language handles things?
While "int" and "char" ARE primitives in Java, there are also "Integer" and "Character" objects in Java, that have one field, either a int or char, respectively.
While that probably isn't the case, just thought I would check.
I'd also like to point out something else: AP Computer Science is a GREAT course. It was my favorite course when I was in high school. However, I also had a GREAT teacher (Shoutout to my former teacher, Mr. Mike Reilly). The teacher can really make or break the class.
If you feel so strongly that your current teacher is wrong on multiple accounts, I suggest you do the following:
1) Document these instances. Write down what he said/assigned on the quiz, and what your answer was, and what the teacher said the correct answer was.
2) For every instance of incorrect teaching, RESEARCH and be able to prove that these instances are incorrect. This means doing lots of research, such as reading the Java documentations, and maybe create example programs to show the difference between what the correct answer is vs what your teacher says the correct answer is.
3): After doing this research, write everything into a Word document, with both the inaccurate information and the correct information, including your source. Respectfully talk to your teacher, and ask him about all these points.
If that doesn't change anything, you might consider talking to your school's administration. I would first write another paper, but a bit more formally, with a list of things that were taught or graded inaccurately, perhaps like this:
Discrepancy One: Mr. TeacherName gave a quiz with the following question: "The moon is a square, True or False". Mr. TeacherName graded the quizzes, with the correct answer being "True".
However, the answer is actually "False", which can be verified here: "http://nssdc.gsfc.nasa.gov/planetary/factsheet/moonfact.html".
Obviously you would change the questions to be based on what you have said. And for any research you do, do NOT cite Wikipedia as a source, (or ChiefDelphi), try to keep it to the java documentation, or maybe some universities webpages, if you can find information there.
Include an introduction, with a brief history of what is going on with the class. After you have written the paper, see if one of your English teachers will help you proofread it, and ask for their opinion on the formatting.
Once the paper is finalized, ask to talk to your principal about the matter. Bring a copy of the paper with you. When talking to your principal, it is EXTREMELY important that you remain respectful, but also bring up the fact that your teacher is not adequately preparing the student for the AP exams, and is potentially teaching incorrect information. (Also remember this: APCS is not a subject many will be familiar with, so try to not get TOO technical when explaining any incorrect information.) Remember, your goal is to create a better class for future students, which in turn will raise the average AP scores for the class, which in turn makes the school look better.
It should also be noted that talking to any administration should be your last resort, it is almost akin to the "nuclear option". And also, do remember that during this whole process, it is important to not be combative, but rather try and be seen as a student who deeply cares about the subject and is trying to learn more.
Hopefully just talking to your teacher, with the correct information documented, will be enough. Most teachers genuinely care and want to help you succeed. While it may be too late for this year's class, maybe next year will be better for your fellow students.
Edit: This is coming from what I would do, and is similar to what I did when I had a very bad experience with a teacher my senior year. Before doing anything, I would first: Talk to your parents about this, and second: Talk to a trusted teacher you have about what the best protocol would be in this situation, (But please make 100% sure you are correct and can prove it, before talking to another teacher about this.)
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
  #43   Spotlight this post!
Unread 26-02-2015, 23:43
AKA: Isaac
I think I'll start to do this, thank you. My school can't have more students attempt to take the AP test with the teacher giving them wrong information. Currently I'm talking with the AP Assistant Principle about replacing this teacher with a different one, preferably an in house solution. As for the rest of the year, the kids in the class that actually care about it (some were put in for lack of space in any other class) are probably going to buy a textbook and teach ourselves from it. We just need to find one. Any ideas?
  #44   Spotlight this post!
Unread 26-02-2015, 23:58
AKA: Matt B
FRC #1771 (1771)
That's good to see you are actively working on a solution.
I'm surprised that students were simply "placed" into a AP course, much less a CS course. When I was in high school it was an elective, with a decent amount of prerequisites.
As for what text book to use? No idea. I don't remember what book we used when I took the test, that was in 2010.
Does your school not provide any textbook at all for the course?
1771- Mentor (2015)
  #45   Spotlight this post!
Unread 27-02-2015, 00:03
AKA: Isaac
Picking the textbook is up to the teacher, so therefore he decided that the class did not need one as he would teach it in class. Currently we are learning by doing type and runs, it's effective to some extent, but we are only learning syntax, nothing else.
The kids were placed in because we needed more kids for it to be a class, they get math credit, and the school gets money for each kid that takes AP Computer Science.
