Go to Post and if you don't know what i'm doing, that makes two of us. - RogerR [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 25-02-2015, 16:12
KosmicKhaos's Avatar
KosmicKhaos KosmicKhaos is offline
Calm Cool Collected
AKA: Andrew Thompson
FRC #1126 (SparX)
Rookie Year: 2015
KosmicKhaos has a spectacular aura aboutKosmicKhaos has a spectacular aura about
OPR
Does anyone have a an excel document or something where I can plug in match scores and figure out OPR or how I could put an OPR calculator in an Android App
Unread 25-02-2015, 16:20
stingray27's Avatar
stingray27 stingray27 is offline
AKA: Michael Ray
FRC #0027 (Team RUSH)
stingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to all
Re: OPR
I will be posting a spreadsheet after Week 1 regarding advanced stats including OPR and a few other metrics.
I have done these spreadsheets the last few years and they can be found here:
http://www.chiefdelphi.com/media/papers/3003
http://www.chiefdelphi.com/media/papers/2967
In addition, I have an app on the google play store called OPRFIRST2014 that was developed to focus specifically on OPR calculations for android. I released the entire source code for it because TheBlueAlliance began to include OPR calculations in their app and it was too hard to gain users with everyone using thebluealliance.com. So feel free to look through here and use the code to calculate OPR. (Although I may warn you, the code may be a little hard to read because I was just beginning android development and this was the first app I created).
https://github.com/mray19027/OPRFIRST2014
The EXACT location of where my OPR calculations take place is here:
https://github.com/mray19027/OPRFIRS...Info.java#L305
Michael Ray
Team RUSH 27
Driving Record: 93-64-0 Best Finish: Finalist (x4 FiM Districts)
Coaching Record: 16-7-0 Best Finish: Winner (Kettering Invitationa)l
Unread 25-02-2015, 17:38
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
Re: OPR
Ed Law and his team has put together awesome resources for calculating OPR that can be found here.
Calculating OPR isn't actually that hard, although it requires some knowledge about basic linear algebra. Essentially, you are trying to solve a linear system of equations for a certain constant that is what you expect a team to contribute to an alliance each match (OPR). If you have teams a, b, and c playing together in one match, and they score a x amount of points, you are solving
a(OPR) + b(OPR) + c(OPR) = x
As more matches occur, the matrix equations become more complex. In the form of Ax = b, A is the matrix whose values correspond to the amount of matches teams played with each other, x is the OPR vector, and b is the vector of the total score each team made in all the matches they played.
If you don't want to do the hard math/plug in your own match scores, you can use The Blue Alliance's API to get OPRs off their site.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 25-02-2015, 19:01
Re: OPR
Not quite.
Each element of |b| corresponds to a team, and the value of that element is the sum of the alliance scores for all alliances that team played with.
Unread 25-02-2015, 19:15
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: OPR
I don't see the OPR anywhere in their API; am I missing something, or did you just mean that the data required to plug into an OPR calculation is there?
plnyyanks's Avatar
plnyyanks plnyyanks is online now
Data wins arguments.
AKA: Phil Lopreiato
Re: OPR
Similarly, you can find the OPR (and DPR, CCWM) calculations done on TBA in this file. The math is based off of this post.
And if you just want to view the data, it is displayed in the TBA Android app, as well (looks like this, but more material. Sorry, old screenshot)
Unread 25-02-2015, 19:19
plnyyanks's Avatar
AKA: Phil Lopreiato
Re: OPR
The API will return the result of the calculations for OPR, DPR, and CCWM. See here in the docs.
Hit
/api/v2/event/<event-key>/stats
It'll return an output like:
Spoiler for Lots of data:
➜  phil@fedora ~  curl --header "X-TBA-App-Id:foo:bar:baz" http://www.thebluealliance.com/api/v2/event/2014cthar/stats
{"oprs": {"558": 61.03862458660732, "571": 25.26315867245658, "1124": 41.56940261999079, "4572": 22.657822140768516, "238": 22.044939318938813, "3146": 12.63390393300261, "178": 46.950456367359891, "177": 92.226404149116206, "4557": 43.334926949271072, "175": 81.334997593159528, "230": 53.027513648529002, "236": 58.096099167356243, "2785": 11.601348126111738, "3555": 7.2284300176004974, "3104": 14.702459074944898, "173": 9.5159523225474345, "839": 19.960465485473357, "2170": 22.066703794171406, "181": 49.492453525796911, "3182": 26.955221924000668, "3634": 34.152969306235953, "4097": 28.571656205234454, "716": 57.420439555814042, "5142": 15.649331351710339, "999": 36.426610246955612, "3525": 50.453711167618096, "5129": 27.586754386014597, "228": 52.10253623902166, "4628": 17.892949898607437, "95": 29.973898403369855, "176": 65.769697919858061, "1991": 53.614388815829997, "4055": 51.617441033456331, "3464": 37.843662949585344, "3566": 31.888458744244957, "4958": 33.821768467384359, "1687": 12.329197344290588, "1740": 7.5272579695618127, "2067": 39.32265324466966}, "ccwms": {"558": 47.714841929054501, "571": -2.2244726240688477, "1124": 32.556983571913001, "4572": -6.0853698077920315, "238": -35.070117174800544, "3146": -36.885966963297193, "178": 14.96298531132085, "177": 71.191849807978272, "4557": -7.7570855600831052, "175": 30.835262590761605, "230": 3.6399453862621081, "236": 20.44387440579483, "2785": -37.350014006119174, "3555": -34.672659512804991, "3104": -28.249324008158332, "173": -37.577530295276226, "839": -19.803791613841952, "2170": -27.524965779988744, "181": 3.7024741266095287, "3182": -8.8673292856880401, "3634": 9.0289537858067348, "4097": -28.403823457387144, "716": 25.671255492674394, "5142": -18.532183768327222, "999": 16.38015834182071, "3525": 27.23416882060123, "5129": -15.548754966962644, "228": 8.7310226121904542, "4628": 7.01561775548765, "95": 5.8413142346092108, "176": 32.851548640364612, "1991": 37.027081101957357, "4055": 13.387511797720734, "3464": 1.4555715944903778, "3566": -15.204361189187283, "4958": -13.407078085909482, "1687": -23.514376735710577, "1740": -21.265070753703672, "2067": 8.2718542816890643}, "dprs": {"558": 13.32378265755275, "571": 27.487631296525407, "1124": 9.0124190480777919, "4572": 28.743191948560586, "238": 57.115056493739317, "3146": 49.519870896299814, "178": 31.987471056039084, "177": 21.034554341137934, "4557": 51.092012509354177, "175": 50.499735002397919, "230": 49.387568262266932, "236": 37.652224761561435, "2785": 48.951362132230891, "3555": 41.901089530405542, "3104": 42.951783083103251, "173": 47.093482617823668, "839": 39.764257099315302, "2170": 49.591669574160193, "181": 45.789979399187374, "3182": 35.822551209688733, "3634": 25.12401552042925, "4097": 56.975479662621588, "716": 31.749184063139648, "5142": 34.181515120037545, "999": 20.046451905134909, "3525": 23.219542347016823, "5129": 43.135509352977216, "228": 43.371513626831245, "4628": 10.877332143119782, "95": 24.13258416876063, "176": 32.918149279493427, "1991": 16.587307713872672, "4055": 38.229929235735582, "3464": 36.388091355095021, "3566": 47.092819933432281, "4958": 47.228846553293849, "1687": 35.843574080001126, "1740": 28.792328723265495, "2067": 31.05079896298054}}
Unread 26-02-2015, 11:18
Re: OPR
Originally Posted by plnyyanks View Post
...you can find the OPR (and DPR, CCWM) calculations done on TBA in this file.
Just a minor observation FWIW:
To solve [M][x]=[s], that code uses numpy.linalg.solve which uses LAPACK routine gesv which does LU decomposition.
Since [M] is symmetric positive definite, Cholesky decomposition can be used instead to take advantage of that particular matrix structure.
For OPR computation for single events the difference will likely be negligible, but when computing combined OPR for all events for an entire season Cholesky will be noticeably faster than LU.
Unread 26-02-2015, 15:30
plnyyanks's Avatar
AKA: Phil Lopreiato
Re: OPR
Really interesting, thanks for input. This'll be a good offseason hackathon project!
Unread 26-02-2015, 16:23
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Re: OPR
It would be a one line change.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 26-02-2015, 16:44
plnyyanks's Avatar
AKA: Phil Lopreiato
Re: OPR
Low hanging fruit, I call it
Unread 26-02-2015, 16:46
saikiranra's Avatar
UCI
Re: OPR
x = np.linalg.cho_solve(np.linalg.cho_factor(M) , s)
Unread 27-02-2015, 09:05
Re: OPR
linalg.cho_factor() and linalg.cho_solve() are in scipy, not numpy.
Attached is a sparse-format "M" matrix generated from this data containing 2,696 teams and 8,921 matches.
Can someone with a Python installation please factor that matrix with LU1 and Cholesky2 and report the times?
1scipy.linalg.lu(M)
2scipy.linalg.cho_factor(M)
Unread 27-02-2015, 11:26
Re: OPR
Here's some even tastier fruit:
Python 2.7.5 (default, May 15 2013, 22:43:36) [MSC v.1500 32 bit (Intel)] on win32
>>> import numpy
>>> import time
>>> import scipy
>>> import scipy.sparse
>>> import scipy.sparse.linalg
>>> # Read M & s ...
>>> M = numpy.loadtxt(open('M.dat'))
>>> s = numpy.loadtxt(open('s.dat'))
>>> end = time.time()
>>> # solve...
... start = time.time()
>>> x = numpy.linalg.solve(M,s)
>>> end = time.time()
>>> print "%f seconds" % (end-start)
15.344000 seconds
>>># solve Cholesky...
>>> xc = scipy.linalg.cho_solve(scipy.linalg.cho_factor(M),s)
>>> end = time.time()
1.688000 seconds
>>> # Convert to sparse...
>>> Msparse = scipy.sparse.csr_matrix(M)
>>> end = time.time()
0.219000 seconds
>>> # solve sparse...
>>> xs = scipy.sparse.linalg.spsolve(Msparse,s)
>>> end = time.time()
0.468000 seconds
PS: above code was run on single core of 8-year-old Pentium D machine running XP SP3
Unread 05-03-2015, 03:03
Spoam's Avatar
Spoam Spoam is offline
AKA: Pedro M.
FRC #0955 (CV Robotics)
Spoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the rough
Re: OPR
Adding on to this, if anyone truly wants to do the math themselves it's worth mentioning that you'll end up with an over-determined system and a non-invertible matrix. Because of this, |Ax-b|=0 probably doesn't exist (every robot would have to contribute the exact same amount of points every match for that to happen) and you have to settle for minimizing |Ax-b| instead. This is done via a formula called linear least squares, which is essentially just left-multiplying both sides by the pseudo-inverse of A, to pseudo-solve it, if you will.
I think it's useful to understand how OPR works too, because often OPR alone often poorly models the game, or the game includes nonlinear (bins this year) or irrelevant (foul points last year) elements which get lumped into naive OPR equations anyways. You should understand what you're looking at before you take a list of teams ranked by OPR at face value.
2015 PNW District Champions (955, 1983, 2930)
Co-Creator of 955 OPR
