Go to Post Your primary job is not to build the most technically advanced robot, but build the best possible team. - PayneTrain [more]
Unread 26-02-2015, 18:40
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: The math of the cans...
Originally Posted by Daniel_LaFleur View Post
While this is correct, it is only applicable at the highest levels of play. Until then the value of the RCs on the step is very low ... especially if they go unused.
"Highest levels of play" is variable.
For example, this year we are going to Utah, SVR, and Championships (probably for the lottery, hopefully if we win). Utah may not be as challenging as SVR, although I don't know what powerhouse teams are attending. SVR ahs 971, 254, 1678, sometimes some of the texas teams. It's very competitive IME. And of course Champs will be interesting.
So depending on the competition, it changes the play. At SVR, for example, I would definitely play a tote-and-flopper, maybe with a wimpy elevator for can topping. I don't know if our team could support it at Utah, and so I would ahve to let one go.
At Champs it's a pretty good chance at victory IMO.
The purpose of a bot like this is to win, not to seed high. Sure, it's a gamble, but a traditional bot has to undergo far more fabrication and testing, as it has to be a multipurpose bot. But a tote-flopper with can topping abilities has to only be loosely tested because it has to lift only 8lbs at once. Add a capable drivetrain and the only thing that has to be tested is the grabber itself- and you have weeks to perfect that. So the odds of winning, even for a middling team otherwise (resources, mentors, etc.) are actually quite good.
Driver practice is much less because they simply have to avoid stacks and top off cans at a rate of 6 or 7 per match. One repetitive action over and over again.
