Go to Post After all, professional engineers know The Right Way To Do It (TM) and if we knew that we'd be deprived of the educational experience of screwing up. - phrontist [more]
Unread 26-02-2015, 21:04
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Where is the sweet spot?
This was one of the biggest debates our team had for the design phase: what level stack is going to provide maximum scores most consistently? Not in theory, but in practice, where tall towers tumble, and take time to make that could have been spent better.
Obviously the best teams will do six with RC consistently. But is it really wise for everyone to keep trying to stack six?
Anyway, we eventually settled on three. I'm curious as to what everyone else thinks. I'd do a poll, but I don't know how.
Unread 26-02-2015, 21:06
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Where is the sweet spot?
Using some linear programming and matrix math it's pretty easy to set up an objective function to calculate what height of stacks you should make using you handling times as constraints.
Unread 26-02-2015, 21:12
mrnoble's Avatar
teacher/coach
I'd love to see that, and your results.
Unread 26-02-2015, 21:58
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Its the number of RC's your alliance has and max stack size taking into account that number plus the time it takes to insert a noodle. Minus the time to add to co-op stack plus any time left over to score totes and that will vary every match based on your alliance partners and noodle throwing.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star #21 | Galileo Division #91
Unread 26-02-2015, 22:00
mrnoble's Avatar
teacher/coach
Unread 26-02-2015, 22:07
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I think it's just 6. It really depends on where you're aiming IMO.
At the highest level, it has to be 6 due to the cans. The cans determine the game at the high levels in regionals and on Einstein.
If you want to win a local regional, it's probably okay to go for less than 6 IMO. It might also be fine to go for fewer if you have valuable features like can grabbing or can capping.
Unread 26-02-2015, 22:11
TDav540's Avatar
TDav540 TDav540 is offline
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
I'd expect that, at the regional level, a quality alliance will be able to do a four to six four stacks, and if they control most of the bins then that will be sufficient. At Champs, stacking 5 with a bin in the playoffs will be a minimum.
Unread 26-02-2015, 22:18
mrnoble's Avatar
teacher/coach
Can someone do a poll? I can't figure it out.
Unread 26-02-2015, 22:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Seems to me it's pretty dependent upon your robot design. (or maybe, your robot design is dependent upon what you chose as your own "sweet spot").
Our robot can do 4 but is happier with 3. But it can cap 5 if someone else makes the stack.
Unread 26-02-2015, 22:24
mrnoble's Avatar
teacher/coach
To clarify: I am concerned (or rather, interested) that we are overestimating how stable sixes are, and how quickly we make them. It's a classic gambler's fallacy: I've already put X dollars into this slot machine, so I'll stay here until it pays off. Drivers will underestimate the amount of extra time they are taking gingerly placing their carefully built full stack on the platform, and will waste time that could have been better spent making a second (shorter) stack for the same point value.
Unread 26-02-2015, 22:28
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
It also depends on your partners in any given match. If you are partnered with a team that can stack fast, but are slow to put the stack on the platform it might pay for that quick stacker to make the stack and pass it off to another team to be placed on a platform and start making another stack. The matches are going to be interesting to say the least.
Looking forward to watching the teams this weekend in Waterbury.
Unread 26-02-2015, 22:31
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
...waste time that could have been better spent making a second (shorter) stack for the same point value.
It is only a waste of time if that stack is not capped with a recycle bin. If the stack is capped, it is more advantageous to have a taller stack.
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
Unread 26-02-2015, 22:39
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
I've been running strat over and over in my head because it is kind of my job...
IMO if you are on an alliance that can reliably stack recycling cans on top of stacks, and you have robots that are capable of making 6 tall stacks comfortably, then it is definitely worth it to make 6 tall stacks because you have a bot that can stack them with a RC.
Otherwise, if you have to stack the RC yourself or do not have an alliance member that can cap the stacks off, it is much quicker to make stacks of three to four and make a lot of them.
It's kind of like R-strategists and K-strategists. Do you want to make a lot of little tiny ones or do you want to make little, but big ones? It depends on the resources you have.
College sux yo
Unread 26-02-2015, 22:50
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
From what I am gathering here it seems to be the general consensus is that the best way to score is the biggest stack you can make with a recycling bin as a cycle. Make a giant stack with a recycling bin, wash, rinse, repeat.
From practice videos that is all I see.
Is anyone willing to openly admit that they plan on deviating from that?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
#GLITTERFORCEHYPE!
Play is for kids this is serious...
Unread 26-02-2015, 23:03
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
In addition to how tall your robot can reach, it depends on how long it takes you to line up to stack, and how precise your stacks are (do they nest, or sit on top, ready to fall in if jostled). Fast, precise stackers can go six. If you're either fast or precise but not both, probably four or five. If neither, probably two or three. If you can't make nested stacks, you may want to consider stacks that completely change direction so they don't "settle" later on.
We're hoping to get enough speed and precision to score four totes, then top that with two more totes and and RC, at least for the first stack or two. Later, as the cost of a lost stack goes up, we may go down to four. Until/unless you run out of space on the scoring platforms, there's no need to make uncapped stacks tall; they're 2 points per tote at any altitude (below the top of the backstop).
