Go to Post I was considering letting Big Mike bearhug me for the warmth. - Barry Bonzack [more]
Unread 26-02-2015, 15:01
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
Re: Inverting Talon SRX
Originally Posted by wireties View Post
So just reconnecting the PWM-PWM interfaces for the 2 sensors should fix things?
For one set, yes. I wish we had done both at the same time, one of the pairs is soldered directly to the board seeing as it is within 7 inches of the electronics.
We had a snow day today so no robotics, but on Saturday I should be able to rewire the entire thing.
Unread 26-02-2015, 15:13
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If one cable goes to the upper, and the other goes to the lower, yes, swapping those PWMs should electrically move the limit switches to the proper location.
Unread 26-02-2015, 17:17
Originally Posted by ozrien View Post
You will need to fix it in the wiring. If the Talon is green (positive throttle) it will only check the forward limit switch. What causes the Talon to be green (closed-loop, slaving, slave-invert) instead of red (Reverse) can be controlled by Reverse Sensor and Reverse Closed-Loop output. But the limit switch is compared against the final output.
Originally Posted by jhersh View Post
Is it really that important that forward be up!? I get that it's a little more straightforward, but if you reverse the output and make the top "red" and the bottom "green" then you don't need to rewire, right? You were wanting a software workaround, so a slight inconvenience of needing to invert a number seems reasonable.
Hey Joe, Omar: Are you guys saying different things? Or am I missing something subtle (or obvious?) .
Unread 27-02-2015, 01:50
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I can't speak for Omar, but I'll guess he meant what he said, assuming that the team wanted the polarity of the control values to remain unchanged. My assertion assumed that polarity is a rational trade off to rewiring.
Unread 27-02-2015, 06:45
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
I think what Omar is saying (not to put words in his mouth ) is the limit switches work directly on the output of the controller which there is no reversing. IE the green & red leds relates to the polarity of the output.
Hopefully Omar will confirm or correct this.
