Go to Post So your gearbox failed, and your first course of action was to post about it CD? This is an interesting failure recovery plan. :) - JVN [more]
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Unread 26-02-2015, 23:18
Chris C 3624 Chris C 3624 is offline
FRC #3624
Chris C 3624 is an unknown quantity at this point
Re: Week 1 Observations
Can anyone explain the process used for measuring transport configuration?
Unread 26-02-2015, 23:22
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Imagine a box does your robot fit in it ?
Transport: 28 in. wide, 42 in. long, and 78 in. tall. 120lbs max internal weight
They will likely have a box with those dimensions to test.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 26-02-2015, 23:24
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
From LRI training, it should just be a taped outline on the floor and a tape measure in the hand of the inspector.
Unread 26-02-2015, 23:28
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
You know I had a chance to make a joke and I missed it but here goes anyway.
For inspection generally you see maybe one or two mimes at competition. These mimes are in charge of making invisible walls around your robot and if there are any cracks between where the invisible walls should meet then your robot doesn't pass. After security has chased the people randomly dressed up mimes away they lay down a tape square and do it for real.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 26-02-2015, 23:29
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
+1
How it was done today in Dallas
No box. They just eyeballed the vertical planes of the box, not my preferred method of checking this rule. If you happen to be off by 1/4" or 1/2" you would likely get away with it especially if it was higher up on the robot.
Unread 27-02-2015, 00:24
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Be prepared to update your firmware. Bring a flash drive with the most updated firmware for your PDP, PCM, Roborio and Talon SRX.
I'm a little surprised how many teams did not update to the min legal firmware versions, which have been in the rules for some time (PCM and Talon since kickoff and PDP in an early team update).
Unread 27-02-2015, 00:44
Engineering Coach
I'm not surprised at all. Countless teams need help even to image the RoboRIO. If it doesn't fix a noticeable problem, it doesn't become a priority for teams. Even my team has shown up to competition with an outdated driver station version before.
Unread 27-02-2015, 01:41
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Also this is the first year in which teams teams need to update PDP's Talon's and PCM's as well. That's a lot of things to keep up to date.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 27-02-2015, 06:25
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Originally Posted by Michael Corsetto View Post
Curious, what penalties are being called?
Let me just give a general "thank you!" for sharing this insight with the community!
Human player kept stepping off the carpet too get pool noodles. Once again poor training of human players are going to hurt teams trying to get cheap points when just simply drilling into their minds to watch what they are doing would save them alot of trouble.
Unread 27-02-2015, 11:54
Left To Beaver Left To Beaver is offline
In 8 hours I'll have a keychain
no team (CHS fanboy)
Left To Beaver is an unknown quantity at this point
Send a message via AIM to Left To Beaver
If the path to center of the step is even slightly impeded for either alliance, just call off any coopertition actions.
Unread 27-02-2015, 12:08
What about prioritizing totes to clear a path to the step in that scenario. Or snow plows?
Unread 27-02-2015, 12:24
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
I've heard a few called for contact with both the chute door and a tote, and therefore propping up the chute door. A nice little 12pt whammy.
Academic Student (Forever)
Unread 27-02-2015, 13:56
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
I'm not sure what the level of interest will be in watching all of the matches. After watching a team a couple of matches it all becomes quite predictable. The only question will be if certain teams improve substantially over the competition. This will become less relevant as the season progresses and teams reach their level of proficiency.
Unread 27-02-2015, 14:10
The mess on the field when one team makes a mistake is so crazy and so detrimental to the team. Another underestimation by a good 300% on my end. Mobility is more important then I thought it would be. These 6 stacks are so slow to make and so bad if they topple. The more I see the more clear the team comp gets and the more stupid I feel but whatever...
Unread 27-02-2015, 17:33
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Originally Posted by Tytus Gerrish View Post
Recycle rush is the most garbage game ever
Where's a portable incinerator when you need one?
#oldschoolreference
