Go to Post Gravity is not always pointing the same direction relative to the robot! - ChrisH [more]
Thread Tools Rating: Thread Rating: 18 votes, 4.78 average. Display Modes
  #76   Spotlight this post!
Unread 28-02-2015, 22:27
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: 2 v 3 in Dallas
Originally Posted by Tyler2517 View Post
This was clearly not done. I don't see how it's possible to disable a robot on the field when there was no re-inspection how do they know i did not see them out on the field with a tape measure?
Actually thats exactly what they did. I went back to see if anything was said or done and they actually did measure it with a tape measure on the field.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #77   Spotlight this post!
Unread 28-02-2015, 22:33
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: 2 v 3 in Dallas
Originally Posted by asid61 View Post
Wait, he said it passed inspection without modifications after that. The rules only say that it has to pass inspection, not follow all the terms surrounding inspection.
The rule is clearly woreded that way to prevent this exact situation from occurring.
Surely you don't believe this is true? You can pass inspection, but actually be non-compliant with the rules because the inspector either missed something, or the robot was damaged/tweaked during gameplay, causing a situation where it is out of compliance. You still have to fix it...you don't just get a free pass because you passed inspection.
The issue here isn't that 987 was discovered to be non-compliant after passing inspection and changing nothing. It is that they were not given a reasonable amount of time (as the rules call for) to remedy the situation and were instead immediately disabled.
2001-2004: Team 100
2006-Present: Team 254
  #78   Spotlight this post!
Unread 28-02-2015, 22:40
Chad987 Chad987 is offline
It's not enough.
AKA: Chad Pesquera
FRC #0987
Chad987 will become famous soon enoughChad987 will become famous soon enough
Re: 2 v 3 in Dallas
Agreed 100%
They wouldn't even tell us whether or not we were disabled. The only way we knew was when the robot did not move in auto.
  #79   Spotlight this post!
Unread 28-02-2015, 22:41
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: 2 v 3 in Dallas
Of course you should be following the rules at all times (I'm not disputing that) but if an inspector passes the robot and nobody knows about any rules being broken, it just seems very unfair to rule it illegal in the deciding match of the competition.
I was thinking of rule T8:
"A Team is only permitted to participate in a Qualification or Playoff MATCH and receive Match Points if their ROBOT has passed
Inspection.
VIOLATION: If prior to the start of the MATCH, the ROBOT is not eligible to participate in the MATCH. If after the start of the
MATCH, the entire ALLIANCE receives a RED CARD for that MATCH."
It mentions only passing inspection.
  #80   Spotlight this post!
Unread 28-02-2015, 22:44
dodar's Avatar
Re: 2 v 3 in Dallas
Inspection.
Just because you pass inspection doesnt give you a clean pass for the remainder of the regional. What he's saying is, through gameplay, your robot may expand; however that may come to happen. And if it is not noticed by the team, but is noticed by the refs, they can chose to inspect it on the spot.
If it is deemed illegal then, it is illegal; while still having passed inspection.
  #81   Spotlight this post!
Unread 28-02-2015, 22:49
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: 2 v 3 in Dallas
Originally Posted by Chad987 View Post
Agreed 100%
The sudden disable isn't an isolated incident in Dallas. This happened numerous times at North Star Regional last year and significantly affected the rankings and eliminations. It's incredibly frustrating and disheartening to see a team's elimination and qualification matches ruined based on a draconian interpretation of a highly ambiguous rule, particularly without any sort of notification or warning. I can understand wanting to speed matches along, but when the fix is as simple as releasing a solenoid or removing a game-piece, it's getting a bit too ridiculous.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #82   Spotlight this post!
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: 2 v 3 in Dallas
I don't think whether or not the rules being enforced at all times is what's really being debated, I think the focus is more on whether or not it was fair to just disable them and start the match instead of giving them some time to resolve the issue.
In the past, we've always been told when a referee had an issue with our robot and given the opportunity to quickly fix it. It seems like that isn't the case this year (or at least in Dallas). It would be nice to get some sort of clarification for that from HQ.
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
  #83   Spotlight this post!
Unread 28-02-2015, 22:54
Cory's Avatar
AKA: Cory McBride
Re: 2 v 3 in Dallas
There is no clarification needed. See G7. It explicitly states that teams are to be given the opportunity to quickly remedy the situation to become compliant, with disabling being a last resort.
2001-2004: Team 100
  #84   Spotlight this post!
Unread 28-02-2015, 22:56
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: 2 v 3 in Dallas
Agreed 100%
I'm speechless. This is completely inappropriate. No matter what you think of the ruling (which I completely disagree with, for the record), not taking the time to inform the team of their disablement is neither gracious, nor professional.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
  #85   Spotlight this post!
Unread 28-02-2015, 22:59
Ilovepineapples's Avatar
Ilovepineapples Ilovepineapples is offline
Pineapple Enthusiast
Ilovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to behold
Re: 2 v 3 in Dallas
This brings back memories from last year... I had a referee from North Star come to me to complain about how teams were being treated - not being told they would be disabled before a match started because they were out of the starting configuration.
  #86   Spotlight this post!
Unread 28-02-2015, 23:01
Bluman56's Avatar
Bluman56 Bluman56 is offline
Mentor Without Borders
AKA: Nikita
FRC #2579
Bluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the rough
Re: 2 v 3 in Dallas
After reading that these things are not unusual and have happened before, I am curious to know if the refs that are in charge of making these calls are ever held liable to their decisions. There is a lot at stake in these competitions and for the sake of transparency, I believe there really should be a thorough investigation into this matter. Just my two cents.
  #87   Spotlight this post!
Unread 28-02-2015, 23:04
g_sawchuk's Avatar
g_sawchuk g_sawchuk is offline
Hmm.
AKA: Griffin Sawchuk
FRC #4476
g_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really nice
Re: 2 v 3 in Dallas
Should there be an investigation? Yes. Should the refs be investigated? Yes. Were the things that happened both un-GP to 987 and rather unfair in general? Yes. But remember, the refs are volunteers.
FRC 2013-2015 (K-Botics #2809)
VEX 2015 - 2016 (W.A.F.F.L.E.S. #4476)
FLL 2015 - ??? (MechMasters #16931)
FRC 2016 - ??? (W.A.F.F.L.E.S. #4476)
2016 Dean's List Finalist
My thoughts and ideas do not necessarily reflect those of my team.
  #88   Spotlight this post!
Unread 28-02-2015, 23:07
Street_dreamZ Street_dreamZ is offline
Team Role: Team Spirit / Cheering
Rookie Year: 1000
Street_dreamZ is a splendid one to beholdStreet_dreamZ is a splendid one to beholdStreet_dreamZ is a splendid one to beholdStreet_dreamZ is a splendid one to beholdStreet_dreamZ is a splendid one to beholdStreet_dreamZ is a splendid one to behold
Re: 2 v 3 in Dallas
Agreed 100%
If the goal of FIRST is to inspire, then the ref who pulled this one did the exact opposite. Things like this make teams regret ever participating. 987 surely worked extremely hard putting this bot together, just like all other teams, and their robot came out great. To see their hard work ruined by an egregious, hasty move made from a judge is awful.
I'm sad.
  #89   Spotlight this post!
Cory's Avatar
AKA: Cory McBride
Re: 2 v 3 in Dallas
The volunteer thing is always a cop out. They're volunteers...that don't have to be invited back next year.
2001-2004: Team 100
  #90   Spotlight this post!
Unread 28-02-2015, 23:11
g_sawchuk's Avatar
Hmm.
FRC #4476
Re: 2 v 3 in Dallas
I'm sad.
People need to realize that things like this happen everywhere throughout FIRST. And it's really, really bad. Although this is a competition, people need to realize that the most important thing is the students learning and having a good time. Mentor built robots are awful. Not awful technically always, but awful as they ruin students ability to learn. Many teams have mentors who disrespect students, or don't let any students do the work. The thing is, there's also teams who don't, and we need to be able to distinguish from the two.
When it comes down to the competition, what's more important? Shutting down a robot without notifying the team, and possibly discouraging the students from STEM careers?
Or giving them a bit to sort it out, and allowing them to run the robot that they worked hard on for 6 weeks.
Valid point. In all honesty, I'm pretty sure that if a volunteer is being un-GP, someone would gladly take their spot, say as ref.
