Go to Post Shouldn't we be encouraging exploration instead of repeatedly beating it with a stick? - Mike Soukup [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
  #76   Spotlight this post!
Unread 01-03-2015, 21:28
sgtell sgtell is offline
FRC #4795
sgtell is an unknown quantity at this point
Re: Jaguar Speed Control Only Reaches 50% of Setpoint
Looks like the Jag PID limits integrator wind-up:
    // Update the error integrator.
    if((psState->lIntegrator & 0x80000000) == (lError & 0x80000000))
//trimmed
[/quote]
From this old thread it looks like the Jaguar's onboard firmware source code was once available - at least the old TI/Luminary micro version (I understand that the FRC version was not).
Is there anywhere to obtain this source code today? Our students are attempting position-based PID control onboard the jaguar using an encoder, and having some difficulty. Being able to point to exactly what the jaguar is doing with their parameters may be a useful teaching opportunity.
thanks, Steve
  #77   Spotlight this post!
Unread 01-03-2015, 23:26
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Have you tried looking here? http://www.ti.com/tool/mdl-bdc24&DCMP=STELLARIS&
There is a software download that should include the non-FRC version, which should include all of the PID algorithms.
  #78   Spotlight this post!
Unread 02-03-2015, 00:06
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by EricVanWyk View Post
By definition, it is impossible to stably hit your set point with a P only control loop. You must have an I term.
It is possible to have an accurate feed-forward and achieve this. Not likely, for sure.
Also, for benefit of anyone reading this and not recognizing the distinction, you can stably hit a position set point with a P-only control loop. (Well, actually you need some D, but this doesn't need to be in software - a bit of friction will often do the job nicely.)
As to a P-only loop only reaching 50% speed, that makes sense if you don't have a feed-forward. Thought experiment: what happens if you start at the setpoint speed, or equivalently read the current speed, and make it the setpoint? Answer: the difference is zero, so zero voltage is applied to the motor. It slows down. As it slows down, D increases and voltage is again applied, but never enough to get back up to the set point.
  #79   Spotlight this post!
Unread 02-03-2015, 08:46
This thread is about speed control using the Jag firmware PID, which does not have a feedforward term.
