Go to Post Vex has helped to shape me into what I am today. - thefro526 [more]
Unread 27-02-2015, 23:18
Slade Slade is offline
FRC #4471 (Spartrons)
Slade is an unknown quantity at this point
Angry Custom Driver Station on the Field
So today at the competition, we were testing our Dashboard to make sure it would run the autonomous we had selected and it was fine on the practice field as long as we had deployed it regularly. When we built the code and put it to run as startup and went to the field, no matter what it would run the autonomous with the value 0.
Until we find a better solution, we have been setting the autonomous we need to use in the match to 0 cause it always runs.
Also, when we deployed it regularly, we made an indicator to confirm it was running the autonomous we specified and it was fine.
Unread 28-02-2015, 00:49
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Custom Driver Station on the Field
I'm not familiar with NI/LV details, but some general things to check:
Is your autonomous setup somehow assuming the tethered configuration, perhaps through a static IP? If the expected network configuration is not available, it's not unreasonable that an initialization of 0 could result. Ideally, only one connection would be made and both autonomous and teleop would use it.
Another possibility is that the connection takes longer to set up via FMS, and it fully initialized when auto starts.
Unread 28-02-2015, 09:09
You're going to have to provide more details about how the value is sent and read.
You can work with the CSA at your event for issues like this.
Unread 28-02-2015, 09:49
Well for the driver station end, we made a list, and made wrote it to the dashboard data like so:
http://puu.sh/ggndY/7f4bb61c6e.png
Then, in Autonomous for our case selector, we referenced it and put it to our case selector (which selects the autonomous mode):
http://puu.sh/ggnQW/e4c23b7496.png
and this is how our cases are numbered:
http://puu.sh/ggnSQ/e8ce2212a1.png
I know it works cause when I deploy it regularly its fine, but when I run as startup and we go on the field, it just always runs 0
Unread 28-02-2015, 11:36
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
When you run as startup check the Variables tab if it really is 0,
it will help concentrating on the source of the problem.
Unread 28-02-2015, 12:50
Ring_Lord Ring_Lord is offline
FRC #4269
Ring_Lord is an unknown quantity at this point
Question Re: Custom Driver Station on the Field
Our team was working in LabVIEW today on our autonomous mode and found the same problem so we used the dashboard values state (a vi first supplies) and it says in auto mode values are disabled. My current hypothesis is that FIRST disabled any values going from the dashboard to the robot in auto mode.
We are sending an official question to FIRST to see if we are correct.
Unread 28-02-2015, 13:21
Thanks for the reply.
Please let me know what they say!
Unread 28-02-2015, 13:48
FRC #4269
Will do, just submitted to FIRST about half an hour ago.
Unread 28-02-2015, 23:59
A team at the Indianapolis district competition had the same problem. The SD variables on the Basic tab don't seem to be getting to the robot when they're connected on the field. The team says they were working fine earlier in the day, but now don't -- and they made no code changes at the time.
They came up with a workaround: they tether the robot in the queue and set the value then, leaving the robot on until the match is over.
Unread 01-03-2015, 01:22
So instead of building the code and pressing Run as Startup, we should just press the button that is a "soft" deploy(The button to the left: http://puu.sh/ghsYK/d1b8777f29.png) and then pick it through the dashboard, then disconnect the thether, and when we get to the field, just do our thing and connect the computer to their ethernet?
Unread 01-03-2015, 05:53
No. Why would you think you should do that? As soon as you unplug and lose the network connection, the interactive execution will stop. All the team did was to power up the robot with the Driver Station computer connected by wire, set the control on the Dashboard appropriately, and unplug the tether. The SD value was retained by the roboRIO as long as it didn't get powered down before the match began.
Unread 01-03-2015, 11:06
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Another thing to try is to close and reopen the driver station and dashboard prior to connecting to the field.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 01-03-2015, 15:06
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
One way you can tell if your robot got the message is to look at the tree control on the Variables tab of the LV dashboard. If the variables have a diamond glyph next to them, then the variable is only known about on the dashboard. If there is no diamond glyph, then the server (your robot) is up to date and your correct auto should run.
Unread 02-03-2015, 01:27
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
I hope you get a reply soon, and I hope your hypothesis is not correct.
In addition to hampering autonomous mode selection, this would make it impossible to process vision on the driver station laptop, at least as far as autonomous goes.
Unread 02-03-2015, 08:02
Nothing is being disabled on purpose.
It seems to happen only when the robot has been turned on and is running user code before the Driver Station makes its network connection to the field. I've only heard about it from teams using LabVIEW, but that might not mean anything.
Wild guess: It might have something to do with the time-of-day clock on the roboRIO. i'll do some checking when I have access to a robot on Tuesday.
