Go to Post If nothing's going wrong, then there is something seriously wrong. - Astronouth7303 [more]
Unread 02-03-2015, 07:38
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: 6X multiplier?
Originally Posted by asid61 View Post
See the post above yours.
Interesting. This could be a really really good strategy. In fact, it is, as it effectively makes a stack worth 5x that of just totes at very little extra cost.
The extra cost is rather significant - the very real likelihood of de-scoring all of the points of the first RC and maybe even the totes. My advice is to not try this in a match unless both of the following are true:
  • Because of alliance abilities or time, there are not going to be enough tote stacks to put one under each of your RCs
  • You've practiced it so much that you know you're a good bit more likely to score than de-score (and I mean practiced with a scoring platform, not on carpet)
