Go to Post shhhh...our robot is in a bag now, it won't hurt anyone till the milwaukee wisconsin regional. hopefully it won't be fiesty. don't wake it. - Toatekua [more]
Unread 09-03-2003, 18:12
Thunder360 Thunder360 is offline
#0940 (Digital Demolition)
Thunder360 is on a distinguished road
Up the Ramp
Hey guys I just got back from the St Louis regional where our team faired ok only due to alot of help from other teams. But one problem tht came up with us many times was the fact that our robot would only make it over the ramp in "auto" mode and would never make it up or over in normal driver mode. Why is that, it's stumped us for the past 48 hours.
Our team (940) ran 2 Chippy's with a 10 tooth gear on the motor going to a 60 tooth gear on the front wheel. The tires are the "Skyway Tuff wheels" 8.5 inch on the front and small casters on the back.
Any idea why only auto will get us up the ramp?????????
"Who needs Battle Bots, Ive got US FIRST!!!"
Unread 09-03-2003, 18:14
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
we had some issues with our driver because he was going full reverse to full forward and blowing the 40 amp breakers running our drill motors.
So it could be due to driver error and drive styles.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 09-03-2003, 18:18
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
Make sure that when you move the joystick all the way, the appropriate speed controller maxes out (check the LED). If it doesn't then the problem is somewhere in your code.
-Joel
-Joel
Unread 09-03-2003, 18:25
could it be that our alignment was off a little from left to right. it seemed to always want to go to the right. But I almost got rid of all the pull by changing the caser and camber, so Im still lost. Also could it be that auto mode can manage the bot better than a human?
Unread 09-03-2003, 18:28
FRC #4293 (Komodo)
I'm betting that auton mode sends the speed controllers a max signal but the joysticks do not. Anything mechanical would affect both auton and driver controlled performance.
-Joel
-Joel
Unread 09-03-2003, 18:39
one last thing it seemed like a 6 to 1 reduction wasnt good enough at the camp we were super fast and had no torque, what is a good gear ratio for a chippy to get good torque?
Unread 09-03-2003, 22:28
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
we had alot of trouble with tripping breakers when we ran the chippys at 1:16. we're at 1:32 now and we're blazing fast, but we can't push well without tripping the breakers again. i'd guess 1:64 would prolly get ya about 4 to 6 feet per sec and decent pushing power.
good luck with the reductions =-\
edit: our wheels are about the same size as yours, too
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 09-03-2003, 23:00
I am guessing on this one but I would first ask if you calibrated the speed controllers. The calibration procedure sets the maximum speed forward and reverse as sent by the joysticks. In "auto mode" you were likely sending a higher value to the speed controllers than in joystick/human mode. This is a simple fix.
As to the chippies (I prefer "chalupa" myself.) these motors are designed to give max output power at a very high RPM, so if you want to get the max out of the motor, you have to design your gear ratios appropriately. This is not something to guess at and the size of you tires makes a big difference in the design. Choose a gear ratio that is too low and you will stall, too high and you will not run fast but you will have lot's of power. Joe Johnson and many others have spent a lot of time writing about this subject, see the White papers section on this site.
http://www.chiefdelphi.com/forums/pa...C&pagenumber=3
Unread 09-03-2003, 23:31
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
we run our chippy drive with an 80:1 reduction as the average gear reduction, we can vary it up and down with different output sprockets, but it has more than enough power to get itself over the ramp and move around some robots while doing so
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 09-03-2003, 23:57
WakeZero WakeZero is offline
FIRST-a-holic Strategist
#1011 (CRUSH)
WakeZero will become famous soon enough
Send a message via AIM to WakeZero Send a message via Yahoo to WakeZero
Just use the drill motors, they work great
2004 Arizona Regional -- Semifinalist
2003 NAT Galileo Division -- Highest Seeded Rookie (20th)
2003 NAT Galileo Division -- 100% Autonomous Completion (7 for 7)
2003 Arizona Regional -- Rookie All-Star Award
2003 Arizona Regional -- Quarterfinalist
Alumni on Team 64, The Gila Monsters
College Mentor/Founder of Team 1011, CRUSH
Unread 10-03-2003, 04:39
-Joel
As Al S pointed out, if this IS the case, then you might calibrate your Victors.
Some Victors (883's and a 4) in "factory calibration" (default setting, cal button pushed at power on) which I tested recently gave maximum output (no pulses, steady 12V output) for PWM numbers of 40 and less and for 229 and above, leaving you lots of leeway for your joysticks to not give 0 and 254 (they won't, especially if you've trimmed them).
In the same test, they stopped giving pulsed output in the range from 124 to 139. If this is test was in fact valid, it explains why we have such a hard time "zeroing" the joysticks: The default program allows you to set the stick to 127 both ways, but the Victor gives output if the x and the y are both off by 1 or 2, resulting in a 123 being sent to the Victor.
I wonder if this could be the cause of the turning - the motors are going in opposite directions, and neutral seems displaced.
The test involved feeding a count-up or -down number to the selected PWM output, and looking at the o/p of the subject Victor on a 'scope. The Victor was loaded with a smallish 12V turn-signal lamp, about 1.5 cm diameter, about 3.5 cm long incl moulded glass base (can't locate the package, & I don't know the number offhand). Full output was declared to be a steady 12V output, with no pulses. Neutral was declared to be the state of no-pulse 0 V output.
Unread 10-03-2003, 07:31
Lloyd, did you guys happen to document the results by any chance? We have never gone to this extent and it would be interesting to see the relationships between digital in and actual output. Just wondering...
Unread 10-03-2003, 11:57
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
My GUESS is that you are runnig too high of a gear ratio. If it is a speed controller not giving you full power, (and the fact that you are using a gear ration of 6 to 1) your design is marginal as to whether it has enough torque to get you over the ramp.
Some quick calculations 8.5*PI()/12*5500/6/60 show you would be going 34 ft/sec at the motor's free speed. I'm guessing you are always running at half that or below. No matter what your speed controllers are doing, increasing your gear ratio will help. Even if you double your gear ratio to 12:1 you should still travel at speeds in excess of 15 ft/sec (crazy fast) and still have twice as much torque.
My true recommendation would be to get your gear ratio in the neighborhood of 25:1 at a minimum if you are not shifting gears.
Unread 10-03-2003, 12:32
Just a note to add to the earlier comment about the joysticks.
Autonomous mode will send exactly the max PWM you tell it to, but we've found variations from joystick to joystick even discounting offsets due to trim wheel. One set of our joysticks when trimmed perfectly send values between 23 and 239 as the max/min, so human drivers would always be under powered.
The simple check is to measure each of your joystick outputs with DEBUG statements and the slop can be easily corrected for in the code.
Unread 10-03-2003, 14:32
Amanda Morrison's Avatar Unsung FIRST Hero
Amanda Morrison Amanda Morrison is offline
16 awesome years of FRC!
Amanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond repute
I think we can attest to this fact.
We used the drill motors for our two wheel drive and when using direct drive had problems with the breaker flipping constantly because of too much torque on them. After we converted to direct drive, we almost got up there, but the breakers would flip and our front castors would send us crashing down to the bottom of the ramp again.
I think the drill motors this year were one of the biggest problems that teams had. If it wasn't one thing, it was another!
Director of Operations, VEX Robotics, Inc.
Alumna - Teams 71, 1020, 1720, 148
2002 World Champions (Team 71) | 2008 World Champions (Team 148)
4th Annual Ramp Riot: Team List Update OZ_341 Off-Season Events 14 09-10-2003 15:25
Q&A Discuss: How long is the bump from the ramp to the top? CD47-Bot Extra Discussion 1 11-01-2003 09:48
blocking the ramp Jacqui Sutton General Forum 3 07-01-2003 09:02
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
