Go to Post Learn the subjects that interest you, but at the same time know how it relate to real life situations, and how it is applied. - Ryan Dognaux [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 03-03-2015, 11:49
can Python open a matrix saved by Octave in sparse format?
Attached ZIP file contains a 17842x2696 matrix with 53526 non-zero elements stored in Octave sparse format.
Can Python load a matrix stored in this format?
Unread 03-03-2015, 15:01
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Re: can Python open a matrix saved by Octave in sparse format?
do we know the size of the matrix before hand?
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 03-03-2015, 15:17
Unread 03-03-2015, 18:00
Octave loads the file in less than half a second, and converts it to full format in about a third of a second:
GNU Octave, version 3.6.4
Copyright (C) 2013 John W. Eaton and others.
This is free software; see the source code for copying conditions.
Octave was configured for "i686-pc-mingw32".
Additional information about Octave is available at http://www.octave.org.
+ ## load the alliances design matrix
+ tic;
+ load ('$A.dat');
+ toc
Elapsed time is 0.422 seconds.
+ [alliances, teams] = size (A)
alliances =  17842
teams =  2696
+ matches = alliances / 2
matches =  8921
+ ## convert it to full
+ tic;
+ Af = full (A);
+ toc
Elapsed time is 0.343 seconds.
+ endscript;
Unread 03-03-2015, 18:38
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Here's a bit of a quick hack:
import scipy.sparse
import numpy
def read_sparse(filename):
  (r, c, d) = numpy.transpose(numpy.loadtxt(filename, 'int'))
  return scipy.sparse.coo_matrix((d, (r-1, c-1)))
Note that the matrix's dimensions may be truncated if there are trailing rows and columns that are all 0, but this is not the case with your example matrix. It would need a little more work to read the dimensions from the file.
A better approach would be to have Octave save the data into MATLAB format (using something like
save -6 A_sparse_octave.mat A), then read it in Python using scipy.io.loadmat
FRC 766, 2015-, Mentor
Unread 03-03-2015, 21:23
Originally Posted by RyanCahoon View Post
A better approach would be to have Octave save the data into MATLAB format (using something like save -6 A_sparse_octave.mat A, then read it in Python using scipy.io.loadmat
Thanks Ryan. That looks like a good solution.
Do you happen to know where I can find the spec for the Matlab matrix binary storage file format?
Unread 03-03-2015, 22:07
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
This?
http://www.mathworks.com/help/pdf_do...ile_format.pdf
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
