Go to Post Real engineers don't need sleep... Just ask our bosses! - Mike Betts [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 03-03-2015, 18:38
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: can Python open a matrix saved by Octave in sparse format?
Here's a bit of a quick hack:
import scipy.sparse
import numpy
def read_sparse(filename):
  (r, c, d) = numpy.transpose(numpy.loadtxt(filename, 'int'))
  return scipy.sparse.coo_matrix((d, (r-1, c-1)))
Note that the matrix's dimensions may be truncated if there are trailing rows and columns that are all 0, but this is not the case with your example matrix. It would need a little more work to read the dimensions from the file.
A better approach would be to have Octave save the data into MATLAB format (using something like
save -6 A_sparse_octave.mat A), then read it in Python using scipy.io.loadmat
FRC 766, 2015-, Mentor
