Go to Post Winning a competition is great, but seeing kids who never thought they had a chance before suddenly discover a brand new future would be the most amazing experience. - MissInformation [more]
Unread 03-03-2015, 17:44
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
talon srx SetVoltageRampRate disabling motor controllers
Hello all,
So my team is using the talon srx motor controllers this year. I was attempting to use the SetVoltageRampRate function for autonomous, but when I put the lines in the motor controllers don't output anything at all! I've tried putting them in different sections of the code, nothing works. If you're interested, here's the code:
	FR->SetVoltageRampRate(6.0);
	FL->SetVoltageRampRate(6.0);
	RR->SetVoltageRampRate(6.0);
	RL->SetVoltageRampRate(6.0);
this is called once in the beginning of autonomous. I've also tried it with the value 1000, that does not work either :/ any suggestions?
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 03-03-2015, 18:05
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: talon srx SetVoltageRampRate disabling motor controllers
It will take 2 seconds to get to max output. Is that the problem, were you expecting such a long ramp? Is your autonomous code running for the correct amount of time?
Unread 03-03-2015, 18:12
AKA: Michael Shires
FRC #0384 (Sparky)
No, that's the problem, I don't get ANY motor output. And it is definitely just those lines. I comment them out, it works, I comment those four lines back in, and I get zero motor movement. I've left it for about 2 minutes thinking maybe it was just a slow ramp, but the motors do not change :/ Is there a different set function you have to call after using the SetVoltageRampRate? Is there something in the web interface you have to do? I'm running it through CAN if that helps, but like I said it's not a wiring issue, it works perfectly until I put those lines in then it stops doing any motor output.
Unread 03-03-2015, 18:43
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Please grab the self-test results when a Talon SRX is not meeting your expectations. That's always the first step.
Also check the DS Messages view on the right side for anything. If the view is not empty, correct the problems listed in the messages listview.
Unread 03-03-2015, 19:47
You are also setting an actual motor output value somewhere, right? Just configuring the ramp rate doesn't tell the Talon to drive anything. Based on your commenting the lines in/out and having it fail/work, I don't think you're being so silly, but I just want to make sure.
Unread 04-03-2015, 08:19
AKA: Michael Shires
FRC #0384 (Sparky)
Yeah, I am. I'm setting them all to 1.0 for autonomous. do you maybe need to tell it to monitor a specific pdp port or something? I'm at a loss because supposedly it just works, and the documentation for this section of the software is lacking a bit for trouble shooting.
Unread 04-03-2015, 08:43
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The Talon programing manual (pg. 63) implies the throttle range is 1023 to -1023. 1 is essentially 0? I know the joy stick output is 1 to -1 but maybe the gets scaled somewhere that is not obvious before being sent to the talon?
Unread 04-03-2015, 10:46
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
We are passing -1.0 to 1.0 to the Set() function and using the SetVoltageRampRate() with no problems. It has to be something else.
Did you by chance set the limits to normally closed at some point and leave them that way? Check the status using the web interface and see if something looks goofy. What revision of the firmware is on the Talons?
Unread 04-03-2015, 12:05
AKA: Michael Shires
FRC #0384 (Sparky)
Nope, just like every other motor controller in FRC, the range is -1.0 to 1.0. Again, when I comment those four lines out it works perfectly with all it's sweet features. The talon SRX is a really amazing piece of electronics.
I'll get back to you this afternoon at around 4:45 once I get to our shop. Is there any specific setting that they have to be at? We're not wiring a limit switch in so I really haven't bothered with the NO or NC options in the web interface. Fingers crossed that that's it!
Also, would you mind posting your applicable code? Just so I can see if perhaps I'm missing some basic issue?
Unread 04-03-2015, 17:03
AKA: Michael Shires
FRC #0384 (Sparky)
And I'm running hardware revision 1.4, bootloader revision 2.6, Firmware revision 0.28. And all of them are set to coast mode, and normally opened on both forward and reverse limit switch.
Unread 04-03-2015, 17:07
ozrien's Avatar
Omar Zrien
AKA: Omar
Unrelated but......
Firmware 0.28? Did you read rule R59? You must update the Talons to be FRC-legal (1.1 or greater).
Unread 04-03-2015, 18:02
Originally Posted by ozrien View Post
Unrelated but......
Firmware 0.28?
I'm not sure it's unrelated at all. The early firmware does not implement all the features of the current firmware (1.1-1.4).
Unread 04-03-2015, 18:19
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Yeah, update to 1.1 or even better to 1.4 and try again.
ozrien's Avatar
Omar Zrien
AKA: Omar
Hey, looks like there was a throttle-ramp fix back in 0.34. Cool (jeesh that was back in November) Forgot about that. Good thinking Alan.
So anyway, this is addressed to ALL teams : PLEASE UPDATE YOUR CAN DEVICES because...
-The ship firmware is not legal
-Updating them at the comp wastes a great deal of time.
-The legal firmware is what the control system team and beta teams have been using/testing.
Sparkyshires, please update your Talons.
Unread 05-03-2015, 11:33
AKA: Michael Shires
FRC #0384 (Sparky)
Oh my god, I feel like an idiot D: I updated the talons on our final, but not our prototype. Thank you so much! Sorry about this!
