Go to Post Save the frustration for build season. :p - Brian C [more]
Unread 03-03-2015, 09:42
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Turning giant turntables
We're using a turntable this year, it's powered by a 1/4" thick laser-cut ABS ring gear and pinion on a PG71. Cost all of $15 for laser time plus material. We used Inventor's design tools to get the tooth profiles, and added mounting holes as well.
Previous years we have tried reversed timing belts, flat urethane belts, friction drives but this seems the best.
Hasn't been to competition yet, but worked well during testing.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 03-03-2015, 09:53
pfreivald's Avatar
AKA: Patrick Freivald
A terrible application for a terrible game, but here's our one turret in the past decade--it was dirt cheap and easy to manufacture (which are good attributes for an off-season project), and could be upscaled/downscaled in complexity/materials rather easily.
It's exactly the idea Akash mentioned.
https://www.youtube.com/watch?v=rfFGwIBrspM
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 03-03-2015, 10:10
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
rivet some #35 chain tight to the circumference of the turntable (http://www.mcmaster.com/#turntables/=w5dnug) then use a sprocket as a drive "gear"
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 03-03-2015, 10:23
Joining the 900 Meme Team
FRC #0079
27 has waterjet large gears in the past. http://www.chiefdelphi.com/media/photos/22666
Unread 03-03-2015, 11:59
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
One thing to watch is the construction of your turntable. If you are using one of those light-weight lazy Susan bearings, it will deform under the side stress of a belt or chain drive, and even a drive puck. The bearing loosens up and after a little use, it stops turning.
If you have the height to accommodate it, get a water pump from the auto parts store. It has a wonderful bearing, runs smooth, has a base with bolt holes and a disk where the fan clutch normally mounts. It can take all the side thrust you can give it. Should cost about $6.00 for one. Just ask the auto parts guys for the cheapest one they have or ask to "shop" in their shelves. With this set up, you can get under the large disk to mount a normal chain drive with sprockets in the off-the-shelf size.
Otherwise, I've had success with timing belts for driving turntables. But a water jet or laser cut giant sprocket sounds lovely with some 25 chain. By the way, you can get 25 chain in plastic if you need it. If you go with a smooth disk and belt, you might want to use a 10 turn precision pot or encoder on a drive puck to sense your disk movement rather than trying to measure the motion through encoders on the gear box. McMaster Carr sells multi-turn precision pots but they call them "variable output switches". Use that term in the search box to find a variety of them an reasonable prices.
Sounds like a useful project that could be applied to future games.
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 03-03-2015, 12:17
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
are you familiar with how a snow blower turns the snow chute we have done something similar to that in the past.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 03-03-2015, 12:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Why not Mouser? I suspect the cheapest 10-turn 10k at Mouser is as good as MC-Master's standard one for around half the price. And you can get 0.1% linear wire-wound pots for as much as Mc-Master's standard pot.
Unread 03-03-2015, 13:04
RoboChair's Avatar
RoboChair RoboChair is online now
AKA: Devin Castellucci
I have a Laser Cutter and a CNC Router at my work in Davis, CA, and I may be able to help you manufacture a solution such as a custom sprocket for #25 of #35 chain after the competition season ends. I also have a Sprocket Profile Generator for SolidWorks 2013 that you can punch in all of the variables such as Pitch, Roller Diameter, and Number of Teeth.
Unread 03-03-2015, 16:04
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
That would be the optimal solution for us, as I don't want to worry about maximum turns when moving it around.
Right now I might just use the AM one, but I will contact you postseason to see if it's any trouble to just make a custom one.
Thank you for the offer.
Unread 04-03-2015, 00:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Reading this reminded me of our other turntable, on our air cannon. Since the turret isn't heavy (some sort pipes and the brackets to hold them), we weren't worried about deformation under the torque of rotation. However, because we throw t-shirts and footballs, we were worried about deformation due to lateral forces. After a rather embarrasing amount of mental fiddling with a lot of different things we could purchase to handle the lateral stresses, we finally pulled a toughbox 2 out of the old parts bins and mounted it so the shaft points up. We tie-wrapped a long shaft key at the bottom so we don't lose it as often. The turret is bolted to an AndyMark hub, and we hold the thing down with just a 1/4" thumb screw. This turned out to be really useful when we realized that the new tires made the air cannon wider than any of the doors on our build space - we popped the turret off and carried it out sideways. (We have since slimmed down the base.) Currently we're manually aiming the turret, but we have a mini-CIM and a potentiometer already mounted so we can convert the TB-mini into a servo.
