Go to Post After all, it's not where you are but the people you're with that make it worth while. - RoboJedi75 [more]
Unread 04-03-2015, 11:17
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: JAVA code to drive straight using H-drive
Originally Posted by Joe Derrick View Post
double robotArcLength = (leftDistance-rightDistance)/2;
double robotDegrees = 360*(robotArcLength/(Math.PI*wheelbase);
Also, that should be 180, not 360. If your left wheels have traveled an extra track width, you will have turned one radian (57 degrees), not two (114 deg). If you're just using this for a PID, it probably didn't matter, because you wound up dividing all your PID constants by 2 in the tuning. It should read:
 double robotDegrees = 180*(robotArcLength/(Math.PI*trackWidth);
Unread 04-03-2015, 11:21
No, 360 is correct.
arc_length=(Left-Right)/2
arc_radius = trackwidth/2
arc_angle = arc_length/arc_radius = arc_length/(trackwidth/2) = 2*arc_length/trackwith
convert to degrees:
2*arc_length/trackwith * (180/pi) = 360*arc_length/(trackwidth*pi)
