Go to Post Stacking totes on end; Gives you extra height, alas; Topples with a sneeze. - BethMo [more]
Unread 04-03-2015, 14:09
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Help using I2C Gyro
Our team wants to use this sensor: https://www.sparkfun.com/products/11977
but i have no clue where to start on the code side, i know it uses I2C which is easy on an arduino but it seems more difficult for the Roborio.
could anyone please make a quick mockup of how the code would look it would be greatly appreciated.
Thanks,
Matt
2015-2016 CSA
Software Engineering Student @ Johnson & Wales University
Team 228, Gus Robotics Inc.
Facebook
FLL Mentor for 1107, Edison Eagles!
2015- CT State Champions
2012- WPI Finalist(Thanks 1884 and 549), Spirt, Best Website
2011- WPI Chairman's award winners!
2010- WPI Champions! (thanks 230 & 20), WPI Engineering Inspiration, CT Best Website, CT VEX Champions (VRC228, VRC228b) (21-1-0)
2009- QCC VEX Champions (VRC228) (11-0-0), Innovate Award (VRC228)
Unread 04-03-2015, 15:00
Ben Wolsieffer Ben Wolsieffer is online now
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Help using I2C Gyro
I don't what language you are using, but here is a mostly working driver that I wrote for it in Java. It should be easy to translate to C++, and at least give a little help if you use LabView. It requires some specific code form our libraries, but that should be pretty easy to get rid of. Feel free to ask if you want more explanation of how it works.
I never got it working perfectly, it seemed to filter out many of the small samples, but since we ended up not using it, I stopped working on it.
Unread 04-03-2015, 15:50
MikeF1617 MikeF1617 is offline
AKA: Michael Fischler
FRC #1124 (UberBots)
MikeF1617 is an unknown quantity at this point
I'm not sure if this is much help, but here is what I found and put together.
This is someone trying to do it in Java, and I took some information from there:
http://forums.usfirst.org/showthread...3340#post93340
It seems that there needs to be an initial command of 0x00 (same as 0) to set it to continuous measurement mode, then just read the data 6 bytes at a time (what the java code does, might need changing). But maybe this is not needed and just managed by the LabVIEW I2C code by itself, so it probably does not need to be included.
I put together a VI with the different parts of code needed, hope this is of some help.
Another option is to go with the gyro that your team probably has that looks like this:
Product:
http://www.andymark.com/product-p/am-2067.htm
Datasheet:
http://www.usfirst.org/sites/default...meter-Gyro.pdf
which should have come in previous year's kit of parts, I believe. My team is using this gyro this year, it is much easier since you can open it on an analog port with the gyro VIs in the WPI library.
Unread 05-03-2015, 16:59
FRC #0228 (Gus)
Ill try using the java code as a reference, we are trying to do this in labview if that helps anyone trying to explain it, thanks
Matt
2015-2016 CSA
Facebook
