| Thread Tools |
Rating:
Display Modes |
#16
Re: G10, The Dallas Disable & Crickets Chirping in Manchester
If so we are going to be seeing some assembly while two people are holding the robot off the carpet.
#17
I'm also glad our robot requires no adjustment from transport configuration so we can avoid these setup time issues. |
#18
I hope not. It was in an email from Kevin Ross (PNW Chairman), and it's not in the Manual, so unless someone has something more official, hopefully this won't happen.
#19
Along similar lines...Transport Configuration.
I'm curious how it was enforced and implemented in other areas of the country. In South Florida- teams were permitted to exit Transport Configuration once they reached the on-deck queue boxes. Will this be the norm? Is this how it was done in other venues? -Brando |
#20
This was allowed at PNW Oregon City for the entire weekend, and I heard that it was happening at PNW Auburn-Mountainview late Friday since they were running 2 hours behind. PNWFIRST has stated that FIRST approved this as a temporary thing, so don't plan on it for Week 2 events. It could happen at some events, but I think it was a Week 1 thing.
#21
The head ref at the Indy event gave us a warning about us taking to long during set up.
#22
As I understand it, utilizing this tool is at the discretion of the event, based on the needs of the event. If there's no need, then I doubt it'll be used. |
#23
An email from Kevin Ross (PNW Chairman) stated that this practice would not be permitted in our week 2 event and that we were expected to strictly abide by the limit. I have also gotten word (indirectly) from the head ref of that event that the 60 second time limit will be enforced. I really don't think it's a big deal: We knew it would be an issue on day 1 and made design decisions about our robot knowing that the time limit would exist - albeit we did not know how much lenience there would be. If a veteran team creates a robot that simply cannot be assembled in less than, say, 90 seconds, they should be warned, then disabled. We have to play by the rules. If it is a rookie team, perhaps a little more patience would be wise - though not in elimination matches. |
#24
Has an MC ever managed to damage a robot while introducing the teams?
#25
The 60 second setup time can be brutal, teams often took way longer than that in previous years with no transport config.
#26
At Northern Lights, we didn't end up relaxing the transport configuration rule as we only ran an hour behind and teams were pretty good about setup time. There were some laggards, but we communicated with them and they got better.
Going longer than 60 seconds is a risk, not a rule. During quals, when the event is an hour behind and your robot is in the #3 box -- more likely to be an issue. During practice matches -- less risky. |
#27
A big challenge this year comes in the semifinals.
Teams need time to be able to tether (although I read somewhere you cant?) to reset their robots, fill air tanks and do other software/mechanical checks and setups prior to playing another match. What happens if you play back-back matches during the round robin 3 matches? Some teams at IE were rushing to get going again because of this. |
#28
