Go to Post I have many ideas, every last one of them involves finding something more productive to do with your time. - Andrew Schreiber [more]
Unread 04-03-2015, 16:23
Re: Custom Driver Station on the Field
Originally Posted by Slade View Post
...it did work when we went to the practice field and tried changing the autonomous mode around. Only when we went for an actual match was it not getting the right value.
This sounds exactly like the symptoms reported by several teams now. It could just be coincidence or a false pattern, but the common factors seem to be using LabVIEW robot code and connecting the Driver Station while the code is already running after a cold boot.
One proven but clunky workaround is to power up the robot in queue with the DS already connected. The currently suggested procedure is to restart the robot code after the robot and DS are communicating on the field.
