Go to Post This is a community that builds people as well as knowledge. - Karibou [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 05-03-2015, 10:26
Re: OPR
Originally Posted by Spoam View Post
Adding on to this, if anyone truly wants to do the math themselves it's worth mentioning that you'll end up with an over-determined system and a non-invertible matrix. Because of this, |Ax-b|=0 probably doesn't exist (every robot would have to contribute the exact same amount of points every match for that to happen) and you have to settle for minimizing |Ax-b| instead. This is done via a formula called linear least squares, which is essentially just left-multiplying both sides by the pseudo-inverse of A, to pseudo-solve it, if you will.
It's important to note that in your (excellent) discussion above, [A] is a non-square binary matrix (each element is either 1 or 0) with 2M rows and T columns, where M is the number of matches and T is the number of teams... and [b] is a 2M by 1 column vector of alliance scores. So [A][x]≈[b] is indeed an overdetermined system which has no exact solution.
But if you look carefully at the way saikiranra defined the matrix [A] and the column vector [b], you'll see that his [A] is actually [N]=[AT][A] and his [b] is actually [d]=[AT][b].
[N] will be a square symmetric positive definite matrix, and [N][x]=[d] will have an exact solution because it's already in the Normalized Equations form. The exact solution to [N][x]=[d] will be the least-squares approximate solution to [A][x]≈[b] (to within computer floating-point rounding error).
you have to settle for minimizing |Ax-b| instead. This is done via a formula called linear least squares...
It is also important to note that least squares is not the only criterion for minimizing the residual vector ε=[A][x]-[b]. For example, you could choose to minimize the L1 norm of ε (least absolute deviation) instead of minimizing the L2 norm (least squares).
That is conceptually true, but it is far faster (computationally) to form the system [N][x]=[d] and solve it that way.
Unread 05-03-2015, 10:45
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Re: OPR
Can anyone show me how to use the thebluealliance.com API to get ranking, match and alliance selection data? I am not able to get it from the FIRST website. I am hoping I don't have to do manual copy and paste. I would like to call it from VBA in my Excel scouting database. Is that possible?
Please don't call me Mr. Ed, I am not a talking horse.
Unread 05-03-2015, 10:54
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: OPR
Not an Excel wizard, but I can help with the TBA API. You can find the documentation here.
Keep in mind all requested need a 'X-TBA-App-Id' header (or GET URL parameter, see below), it'll look like: '<team/person id>:<app description>:<version> '
Here are the endpoints you'll need (you can play around with test requests on the apidocs page)
Rankings: /api/v2/event/<key>/rankings
Results: /api/v2/event/<key>/matches
Alliances: /api/v2/event/<key> [alliances will be a field in this response]
You can also get the calculated OPR/DPR/CCWM stats at /api/v2/event/<key>/stats
And here are a couple StackOverflow threads that may or may not be helpful fetching/parsing JSON data:
https://stackoverflow.com/questions/...-unknown-proxy
https://stackoverflow.com/questions/...rnal-libraries
Unread 05-03-2015, 11:18
Re: OPR
Originally Posted by plnyyanks View Post
Keep in mind all requested need a 'X-TBA-App-Id' header, it'll look like: '<team/person id>:<app description>:<version> '
Can you give a full example using the "/api/v2/event/<key>/matches" endpoint?
Can this just be typed into the URL bar of a browser?
Can it be typed at a Windows or Linux command line, and have the output redirected to a file?
Unread 05-03-2015, 11:25
plnyyanks's Avatar
AKA: Phil Lopreiato
Re: OPR
The API works with all HTTP GET requests, so you can enter it in a browser, provided you provide a GET paramter 'X-TBA-App-Id' with your ID. Otherwise, it'll just throw an error (like this). Here is an example of a properly formed URL.
I keep the following bash alias on my computer that I use for test calls
alias tba-api="curl --header 'X-TBA-App-Id:plnyyanks:curl:0.1'"
That way, I can run things like this:
➜  phil@fedora ~ tba-api http://www.thebluealliance.com/api/v2/event/2014necmp/matches
[{"comp_level": "f", "match_number": 1, "videos": [{"type": "youtube", "key": "ZRTRszl2iXw"}], "time_string": "3:18 PM", "set_number": 1, "key": "2014necmp_f1m1", "time": "1397330280", "score_breakdown": null, "alliances": {"blue": {"score": 154, "teams": ["frc177", "frc230", "frc4055"]}, "red": {"score": 78, "teams": ["frc195", "frc558", "frc5122"]}}, "event_key": "2014necmp"}, {"comp_level": "f", "match_number": 2, "videos": [{"type": "youtube", "key": "-ijeqxwp7EI"}, {"type": "youtube", "key": "UJEDkibEIVM"}], "time_string": "3:24 PM", "set_number": 1, "key": "2014necmp_f1m2", "time": "1397330640", "score_breakdown": null, "alliances": {"blue": {"score": 210, "teams": ["frc4055", "frc230", "frc177"]}, "red": {"score": 114, "teams": ["frc195", "frc558", "frc5122"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 1, "videos": [{"type": "youtube", "key": "ICPrgPalH74"}], "time_string": "1:30 PM", "set_number": 1, "key": "2014necmp_qf1m1", "time": "1397323800", "score_breakdown": null, "alliances": {"blue": {"score": 101, "teams": ["frc1058", "frc2067", "frc172"]}, "red": {"score": 246, "teams": ["frc5122", "frc558", "frc195"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 2, "videos": [{"type": "youtube", "key": "iX5wK_hqb3M"}], "time_string": "1:54 PM", "set_number": 1, "key": "2014necmp_qf1m2", "time": "1397325240", "score_breakdown": null, "alliances": {"blue": {"score": 212, "teams": ["frc2067", "frc172", "frc1058"]}, "red": {"score": 88, "teams": ["frc195", "frc5122", "frc558"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 3, "videos": [{"type": "youtube", "key": "n5FLwsJpNYI"}], "time_string": "2:18 PM", "set_number": 1, "key": "2014necmp_qf1m3", "time": "1397326680", "score_breakdown": null, "alliances": {"blue": {"score": 94, "teams": ["frc2067", "frc172", "frc1058"]}, "red": {"score": 194, "teams": ["frc5122", "frc558", "frc195"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 1, "videos": [{"type": "youtube", "key": "wInXE0_GiTs"}], "time_string": "1:36 PM", "set_number": 2, "key": "2014necmp_qf2m1", "time": "1397324160", "score_breakdown": null, "alliances": {"blue": {"score": 151, "teams": ["frc1519", "frc3467", "frc58"]}, "red": {"score": 211, "teams": ["frc811", "frc78", "frc716"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 2, "videos": [{"type": "youtube", "key": "04Kjt-mFS6c"}], "time_string": "2:00 PM", "set_number": 2, "key": "2014necmp_qf2m2", "time": "1397325600", "score_breakdown": null, "alliances": {"blue": {"score": 216, "teams": ["frc3467", "frc58", "frc1519"]}, "red": {"score": 161, "teams": ["frc716", "frc811", "frc78"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 3, "videos": [{"type": "youtube", "key": "bscdxXcRaVg"}], "time_string": "2:24 PM", "set_number": 2, "key": "2014necmp_qf2m3", "time": "1397327040", "score_breakdown": null, "alliances": {"blue": {"score": 180, "teams": ["frc3467", "frc58", "frc1519"]}, "red": {"score": 182, "teams": ["frc716", "frc811", "frc78"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 1, "videos": [{"type": "youtube", "key": "FmNkU9GFWa0"}], "time_string": "1:42 PM", "set_number": 3, "key": "2014necmp_qf3m1", "time": "1397324520", "score_breakdown": null, "alliances": {"blue": {"score": 231, "teams": ["frc3525", "frc2168", "frc228"]}, "red": {"score": 220, "teams": ["frc125", "frc1153", "frc4048"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 2, "videos": [{"type": "youtube", "key": "-jCxjA8w2k8"}], "time_string": "2:06 PM", "set_number": 3, "key": "2014necmp_qf3m2", "time": "1397325960", "score_breakdown": null, "alliances": {"blue": {"score": 205, "teams": ["frc2168", "frc3525", "frc228"]}, "red": {"score": 151, "teams": ["frc4048", "frc125", "frc1153"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 1, "videos": [{"type": "youtube", "key": "ziu8fwYooX8"}], "time_string": "1:48 PM", "set_number": 4, "key": "2014necmp_qf4m1", "time": "1397324880", "score_breakdown": null, "alliances": {"blue": {"score": 146, "teams": ["frc1073", "frc131", "frc175"]}, "red": {"score": 185, "teams": ["frc4055", "frc230", "frc177"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 2, "videos": [{"type": "youtube", "key": "APkUOZqQn2w"}], "time_string": "2:12 PM", "set_number": 4, "key": "2014necmp_qf4m2", "time": "1397326320", "score_breakdown": null, "alliances": {"blue": {"score": 166, "teams": ["frc175", "frc131", "frc1073"]}, "red": {"score": 170, "teams": ["frc4055", "frc177", "frc230"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 1, "videos": [{"type": "youtube", "key": "wIr2wRz6IAM"}], "time_string": "2:30 PM", "set_number": 1, "key": "2014necmp_qm1", "time": "1397154600", "score_breakdown": null, "alliances": {"blue": {"score": 128, "teams": ["frc131", "frc319", "frc1153"]}, "red": {"score": 119, "teams": ["frc61", "frc4048", "frc1099"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 10, "videos": [{"type": "youtube", "key": "xFacbW3X64A"}], "time_string": "3:33 PM", "set_number": 1, "key": "2014necmp_qm10", "time": "1397158380", "score_breakdown": null, "alliances": {"blue": {"score": 275, "teams": ["frc558", "frc58", "frc125"]}, "red": {"score": 177, "teams": ["frc4761", "frc61", "frc811"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 100, "videos": [{"type": "youtube", "key": "uh6kxQSPs-U"}], "time_string": "11:01 AM", "set_number": 1, "key": "2014necmp_qm100", "time": "1397314860", "score_breakdown": null, "alliances": {"blue": {"score": 116, "teams": ["frc1735", "frc69", "frc138"]}, "red": {"score": 148, "teams": ["frc999", "frc1073", "frc716"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 101, "videos": [{"type": "youtube", "key": "cHWKLbzau54"}], "time_string": "11:08 AM", "set_number": 1, "key": "2014necmp_qm101", "time": "1397315280", "score_breakdown": null, "alliances": {"blue": {"score": 98, "teams": ["frc2064", "frc1058", "frc4909"]}, "red": {"score": 186, "teams": ["frc4761", "frc237", "frc3467"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 102, "videos": [{"type": "youtube", "key": "Z_ZEAOhlj4E"}], "time_string": "11:15 AM", "set_number": 1, "key": "2014necmp_qm102", "time": "1397315700", "score_breakdown": null, "alliances": {"blue": {"score": 102, "teams": ["frc78", "frc3525", "frc133"]}, "red": {"score": 201, "teams": ["frc230", "frc558", "frc1099"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 103, "videos": [{"type": "youtube", "key": "tkzPMwUXrNY"}], "time_string": "11:22 AM", "set_number": 1, "key": "2014necmp_qm103", "time": "1397316120", "score_breakdown": null, "alliances": {"blue": {"score": 136, "teams": ["frc131", "frc4048", "frc2648"]}, "red": {"score": 173, "teams": ["frc811", "frc246", "frc2067"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 104, "videos": [{"type": "youtube", "key": "BaqX0J3mbUE"}], "time_string": "11:29 AM", "set_number": 1, "key": "2014necmp_qm104", "time": "1397316540", "score_breakdown": null, "alliances": {"blue": {"score": 146, "teams": ["frc2877", "frc4564", "frc1991"]}, "red": {"score": 190, "teams": ["frc4473", "frc5122", "frc195"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 105, "videos": [{"type": "youtube", "key": "ESWcSwEcXRw"}], "time_string": "11:36 AM", "set_number": 1, "key": "2014necmp_qm105", "time": "1397316960", "score_breakdown": null, "alliances": {"blue": {"score": 146, "teams": ["frc1517", "frc3930", "frc58"]}, "red": {"score": 153, "teams": ["frc172", "frc176", "frc166"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 106, "videos": [{"type": "youtube", "key": "i-y1nd-a6YU"}], "time_string": "11:43 AM", "set_number": 1, "key": "2014necmp_qm106", "time": "1397317380", "score_breakdown": null, "alliances": {"blue": {"score": 191, "teams": ["frc175", "frc1519", "frc2168"]}, "red": {"score": 122, "teams": ["frc4055", "frc4925", "frc228"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 11, "videos": [{"type": "youtube", "key": "eknIU2Skr-M"}], "time_string": "3:40 PM", "set_number": 1, "key": "2014necmp_qm11", "time": "1397158800", "score_breakdown": null, "alliances": {"blue": {"score": 126, "teams": ["frc2067", "frc1991", "frc4055"]}, "red": {"score": 247, "teams": ["frc3525", "frc1153", "frc172"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 12, "videos": [{"type": "youtube", "key": "h49-_UAtmFQ"}], "time_string": "3:47 PM", "set_number": 1, "key": "2014necmp_qm12", "time": "1397159220", "score_breakdown": null, "alliances": {"blue": {"score": 165, "teams": ["frc69", "frc1519", "frc78"]}, "red": {"score": 136, "teams": ["frc1099", "frc1058", "frc1517"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 13, "videos": [{"type": "youtube", "key": "R_yU1efuMdA"}], "time_string": "3:54 PM", "set_number": 1, "key": "2014necmp_qm13", "time": "1397159640", "score_breakdown": null, "alliances": {"blue": {"score": 127, "teams": ["frc4473", "frc131", "frc2064"]}, "red": {"score": 122, "teams": ["frc999", "frc2168", "frc228"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 14, "videos": [{"type": "youtube", "key": "UxnxjBftKfY"}], "time_string": "4:01 PM", "set_number": 1, "key": "2014necmp_qm14", "time": "1397160060", "score_breakdown": null, "alliances": {"blue": {"score": 170, "teams": ["frc4048", "frc175", "frc4564"]}, "red": {"score": 167, "teams": ["frc178", "frc2084", "frc176"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 15, "videos": [{"type": "youtube", "key": "L4o5S_5OHV4"}], "time_string": "4:08 PM", "set_number": 1, "key": "2014necmp_qm15", "time": "1397160480", "score_breakdown": null, "alliances": {"blue": {"score": 185, "teams": ["frc230", "frc3467", "frc195"]}, "red": {"score": 102, "teams": ["frc4958", "frc138", "frc1100"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 16, "videos": [{"type": "youtube", "key": "4K2s3vnqXgY"}, {"type": "youtube", "key": "Yz4h6lCLyv4"}], "time_string": "4:15 PM", "set_number": 1, "key": "2014necmp_qm16", "time": "1397160900", "score_breakdown": null, "alliances": {"blue": {"score": 118, "teams": ["frc2648", "frc177", "frc4908"]}, "red": {"score": 141, "teams": ["frc133", "frc166", "frc716"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 17, "videos": [{"type": "youtube", "key": "ZJxBMPE8fRQ"}], "time_string": "4:22 PM", "set_number": 1, "key": "2014necmp_qm17", "time": "1397161320", "score_breakdown": null, "alliances": {"blue": {"score": 147, "teams": ["frc246", "frc2877", "frc3930"]}, "red": {"score": 142, "teams": ["frc3461", "frc4909", "frc319"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 18, "videos": [{"type": "youtube", "key": "0OqIluNyHYc"}], "time_string": "4:29 PM", "set_number": 1, "key": "2014necmp_qm18", "time": "1397161740", "score_breakdown": null, "alliances": {"blue": {"score": 135, "teams": ["frc5122", "frc1073", "frc1153"]}, "red": {"score": 72, "teams": ["frc237", "frc4925", "frc176"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 19, "videos": [{"type": "youtube", "key": "xGP_L2dZ_Y0"}], "time_string": "4:36 PM", "set_number": 1, "key": "2014necmp_qm19", "time": "1397162160", "score_breakdown": null, "alliances": {"blue": {"score": 90, "teams": ["frc4564", "frc2084", "frc4761"]}, "red": {"score": 201, "teams": ["frc230", "frc131", "frc172"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 2, "videos": [{"type": "youtube", "key": "GRNlm29DbbU"}], "time_string": "2:37 PM", "set_number": 1, "key": "2014necmp_qm2", "time": "1397155020", "score_breakdown": null, "alliances": {"blue": {"score": 157, "teams": ["frc58", "frc2084", "frc2168"]}, "red": {"score": 202, "teams": ["frc2067", "frc133", "frc1519"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 20, "videos": [{"type": "youtube", "key": "XGuGLX18lq4"}, {"type": "youtube", "key": "trmMPntU5K4"}, {"type": "youtube", "key": "vN9OPQ146X0"}], "time_string": "4:43 PM", "set_number": 1, "key": "2014necmp_qm20", "time": "1397162580", "score_breakdown": null, "alliances": {"blue": {"score": 88, "teams": ["frc999", "frc1099", "frc2064"]}, "red": {"score": 95, "teams": ["frc178", "frc177", "frc716"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 21, "videos": [{"type": "youtube", "key": "KTr5E1WpU5Q"}], "time_string": "4:50 PM", "set_number": 1, "key": "2014necmp_qm21", "time": "1397163000", "score_breakdown": null, "alliances": {"blue": {"score": 125, "teams": ["frc195", "frc1058", "frc1519"]}, "red": {"score": 71, "teams": ["frc3461", "frc61", "frc4908"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 22, "videos": [{"type": "youtube", "key": "r7E0k0Jjb7k"}], "time_string": "4:57 PM", "set_number": 1, "key": "2014necmp_qm22", "time": "1397163420", "score_breakdown": null, "alliances": {"blue": {"score": 149, "teams": ["frc1100", "frc558", "frc166"]}, "red": {"score": 76, "teams": ["frc1991", "frc246", "frc1735"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 23, "videos": [{"type": "youtube", "key": "0FouILThLLM"}], "time_string": "5:04 PM", "set_number": 1, "key": "2014necmp_qm23", "time": "1397163840", "score_breakdown": null, "alliances": {"blue": {"score": 132, "teams": ["frc4048", "frc138", "frc1073"]}, "red": {"score": 151, "teams": ["frc1517", "frc2168", "frc78"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 24, "videos": [{"type": "youtube", "key": "O7RgVFRtWQk"}], "time_string": "5:11 PM", "set_number": 1, "key": "2014necmp_qm24", "time": "1397164260", "score_breakdown": null, "alliances": {"blue": {"score": 58, "teams": ["frc4925", "frc69", "frc2648"]}, "red": {"score": 129, "teams": ["frc237", "frc228", "frc4958"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 25, "videos": [{"type": "youtube", "key": "H57fYCZJUEw"}], "time_string": "5:18 PM", "set_number": 1, "key": "2014necmp_qm25", "time": "1397164680", "score_breakdown": null, "alliances": {"blue": {"score": 146, "teams": ["frc175", "frc2877", "frc5122"]}, "red": {"score": 275, "teams": ["frc811", "frc3930", "frc3525"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 26, "videos": [{"type": "youtube", "key": "7lLhTARVPRA"}], "time_string": "5:25 PM", "set_number": 1, "key": "2014necmp_qm26", "time": "1397165100", "score_breakdown": null, "alliances": {"blue": {"score": 195, "teams": ["frc319", "frc58", "frc133"]}, "red": {"score": 132, "teams": ["frc4909", "frc4055", "frc3467"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 27, "videos": [{"type": "youtube", "key": "lHkVbxIrEWg"}], "time_string": "5:32 PM", "set_number": 1, "key": "2014necmp_qm27", "time": "1397165520", "score_breakdown": null, "alliances": {"blue": {"score": 167, "teams": ["frc4473", "frc125", "frc716"]}, "red": {"score": 101, "teams": ["frc2067", "frc178", "frc78"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 28, "videos": [{"type": "youtube", "key": "LOM_r2n4QsQ"}], "time_string": "5:39 PM", "set_number": 1, "key": "2014necmp_qm28", "time": "1397165940", "score_breakdown": null, "alliances": {"blue": {"score": 104, "teams": ["frc2084", "frc1099", "frc138"]}, "red": {"score": 169, "teams": ["frc246", "frc1100", "frc2064"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 29, "videos": [{"type": "youtube", "key": "d9Bmmy_TApo"}], "time_string": "5:46 PM", "set_number": 1, "key": "2014necmp_qm29", "time": "1397166360", "score_breakdown": null, "alliances": {"blue": {"score": 151, "teams": ["frc811", "frc237", "frc2168"]}, "red": {"score": 157, "teams": ["frc4908", "frc4958", "frc230"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 3, "videos": [{"type": "youtube", "key": "7ifzn1jZZ_4"}, {"type": "youtube", "key": "Kxwb2Ri-kXM"}], "time_string": "2:44 PM", "set_number": 1, "key": "2014necmp_qm3", "time": "1397155440", "score_breakdown": null, "alliances": {"blue": {"score": 225, "teams": ["frc4055", "frc176", "frc177"]}, "red": {"score": 161, "teams": ["frc230", "frc69", "frc1517"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 30, "videos": [{"type": "youtube", "key": "1-9Q41Xbnvk"}], "time_string": "5:53 PM", "set_number": 1, "key": "2014necmp_qm30", "time": "1397166780", "score_breakdown": null, "alliances": {"blue": {"score": 150, "teams": ["frc4761", "frc133", "frc1991"]}, "red": {"score": 180, "teams": ["frc5122", "frc4048", "frc999"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 31, "videos": [{"type": "youtube", "key": "t44hycmnwcg"}], "time_string": "9:30 AM", "set_number": 1, "key": "2014necmp_qm31", "time": "1397223000", "score_breakdown": null, "alliances": {"blue": {"score": 77, "teams": ["frc1517", "frc4473", "frc175"]}, "red": {"score": 103, "teams": ["frc1153", "frc3461", "frc2648"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 32, "videos": [{"type": "youtube", "key": "EH43R6zGxWE"}], "time_string": "9:37 AM", "set_number": 1, "key": "2014necmp_qm32", "time": "1397223420", "score_breakdown": null, "alliances": {"blue": {"score": 137, "teams": ["frc3930", "frc228", "frc2067"]}, "red": {"score": 196, "teams": ["frc1735", "frc195", "frc177"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 33, "videos": [{"type": "youtube", "key": "F1xJCZH8Qv0"}], "time_string": "9:44 AM", "set_number": 1, "key": "2014necmp_qm33", "time": "1397223840", "score_breakdown": null, "alliances": {"blue": {"score": 104, "teams": ["frc166", "frc4925", "frc4909"]}, "red": {"score": 204, "teams": ["frc176", "frc4564", "frc558"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 34, "videos": [{"type": "youtube", "key": "YeL99JfdEe8"}], "time_string": "9:51 AM", "set_number": 1, "key": "2014necmp_qm34", "time": "1397224260", "score_breakdown": null, "alliances": {"blue": {"score": 166, "teams": ["frc1519", "frc319", "frc3467"]}, "red": {"score": 115, "teams": ["frc1073", "frc172", "frc69"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 35, "videos": [{"type": "youtube", "key": "sXavEZJS2Fo"}], "time_string": "9:58 AM", "set_number": 1, "key": "2014necmp_qm35", "time": "1397224680", "score_breakdown": null, "alliances": {"blue": {"score": 156, "teams": ["frc61", "frc1058", "frc131"]}, "red": {"score": 165, "teams": ["frc2877", "frc4055", "frc3525"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 36, "videos": [{"type": "youtube", "key": "BlWH5Mu_JW4"}], "time_string": "10:05 AM", "set_number": 1, "key": "2014necmp_qm36", "time": "1397225100", "score_breakdown": null, "alliances": {"blue": {"score": 250, "teams": ["frc125", "frc2648", "frc195"]}, "red": {"score": 156, "teams": ["frc58", "frc1099", "frc5122"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 37, "videos": [{"type": "youtube", "key": "cQbjC51VVk0"}], "time_string": "10:12 AM", "set_number": 1, "key": "2014necmp_qm37", "time": "1397225520", "score_breakdown": null, "alliances": {"blue": {"score": 188, "teams": ["frc811", "frc78", "frc3461"]}, "red": {"score": 221, "teams": ["frc133", "frc1100", "frc228"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 38, "videos": [{"type": "youtube", "key": "97g6RRYvWe4"}], "time_string": "10:19 AM", "set_number": 1, "key": "2014necmp_qm38", "time": "1397225940", "score_breakdown": null, "alliances": {"blue": {"score": 154, "teams": ["frc3930", "frc178", "frc166"]}, "red": {"score": 166, "teams": ["frc230", "frc237", "frc2067"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 39, "videos": [{"type": "youtube", "key": "0zrxn9Qz0r0"}], "time_string": "10:26 AM", "set_number": 1, "key": "2014necmp_qm39", "time": "1397226360", "score_breakdown": null, "alliances": {"blue": {"score": 135, "teams": ["frc4958", "frc69", "frc4564"]}, "red": {"score": 147, "teams": ["frc138", "frc2877", "frc4761"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 4, "videos": [{"type": "youtube", "key": "VSN_wHILsZE"}], "time_string": "2:51 PM", "set_number": 1, "key": "2014necmp_qm4", "time": "1397155860", "score_breakdown": null, "alliances": {"blue": {"score": 118, "teams": ["frc811", "frc166", "frc5122"]}, "red": {"score": 98, "teams": ["frc1058", "frc999", "frc3467"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 40, "videos": [{"type": "youtube", "key": "cLuEygRrrJM"}], "time_string": "10:33 AM", "set_number": 1, "key": "2014necmp_qm40", "time": "1397226780", "score_breakdown": null, "alliances": {"blue": {"score": 112, "teams": ["frc1517", "frc176", "frc1153"]}, "red": {"score": 91, "teams": ["frc999", "frc61", "frc4909"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 41, "videos": [{"type": "youtube", "key": "fY1QShwfqrg"}], "time_string": "10:40 AM", "set_number": 1, "key": "2014necmp_qm41", "time": "1397227200", "score_breakdown": null, "alliances": {"blue": {"score": 161, "teams": ["frc319", "frc1073", "frc175"]}, "red": {"score": 189, "teams": ["frc2064", "frc4908", "frc558"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 42, "videos": [{"type": "youtube", "key": "j7iBmZJNyCY"}], "time_string": "10:47 AM", "set_number": 1, "key": "2014necmp_qm42", "time": "1397227620", "score_breakdown": null, "alliances": {"blue": {"score": 142, "teams": ["frc3525", "frc1058", "frc1735"]}, "red": {"score": 84, "teams": ["frc2084", "frc177", "frc246"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 43, "videos": [{"type": "youtube", "key": "Mqt5nz3dK0M"}], "time_string": "10:54 AM", "set_number": 1, "key": "2014necmp_qm43", "time": "1397228040", "score_breakdown": null, "alliances": {"blue": {"score": 240, "teams": ["frc125", "frc3467", "frc4048"]}, "red": {"score": 95, "teams": ["frc4473", "frc4925", "frc1519"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 44, "videos": [{"type": "youtube", "key": "3DeeP1LAU7s"}], "time_string": "11:01 AM", "set_number": 1, "key": "2014necmp_qm44", "time": "1397228460", "score_breakdown": null, "alliances": {"blue": {"score": 137, "teams": ["frc131", "frc2168", "frc716"]}, "red": {"score": 185, "teams": ["frc58", "frc1991", "frc172"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 45, "videos": [{"type": "youtube", "key": "LumUB5rt3TY"}], "time_string": "11:08 AM", "set_number": 1, "key": "2014necmp_qm45", "time": "1397228880", "score_breakdown": null, "alliances": {"blue": {"score": 251, "teams": ["frc2067", "frc4908", "frc5122"]}, "red": {"score": 190, "teams": ["frc4055", "frc69", "frc1100"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 46, "videos": [{"type": "youtube", "key": "CrFtbEuEfqQ"}], "time_string": "11:15 AM", "set_number": 1, "key": "2014necmp_qm46", "time": "1397229300", "score_breakdown": null, "alliances": {"blue": {"score": 122, "teams": ["frc1073", "frc78", "frc1058"]}, "red": {"score": 122, "teams": ["frc4564", "frc1153", "frc3930"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 47, "videos": [{"type": "youtube", "key": "d7pDBW6mN2w"}], "time_string": "11:22 AM", "set_number": 1, "key": "2014necmp_qm47", "time": "1397229720", "score_breakdown": null, "alliances": {"blue": {"score": 188, "teams": ["frc195", "frc166", "frc228"]}, "red": {"score": 56, "teams": ["frc3525", "frc4761", "frc4925"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 48, "videos": [{"type": "youtube", "key": "QtB76b2heXs"}], "time_string": "11:29 AM", "set_number": 1, "key": "2014necmp_qm48", "time": "1397230140", "score_breakdown": null, "alliances": {"blue": {"score": 156, "teams": ["frc138", "frc4909", "frc58"]}, "red": {"score": 144, "teams": ["frc1099", "frc175", "frc1991"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 49, "videos": [{"type": "youtube", "key": "5B6o93-xNzw"}], "time_string": "11:36 AM", "set_number": 1, "key": "2014necmp_qm49", "time": "1397230560", "score_breakdown": null, "alliances": {"blue": {"score": 204, "teams": ["frc4055", "frc1519", "frc178"]}, "red": {"score": 157, "teams": ["frc176", "frc811", "frc2648"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 5, "videos": [{"type": "youtube", "key": "pk29fEJyanA"}], "time_string": "2:58 PM", "set_number": 1, "key": "2014necmp_qm5", "time": "1397156280", "score_breakdown": null, "alliances": {"blue": {"score": 148, "teams": ["frc3525", "frc1991", "frc4908"]}, "red": {"score": 171, "teams": ["frc125", "frc1735", "frc4564"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 50, "videos": [{"type": "youtube", "key": "vW1_Y1s1Jno"}], "time_string": "11:43 AM", "set_number": 1, "key": "2014necmp_qm50", "time": "1397230980", "score_breakdown": null, "alliances": {"blue": {"score": 150, "teams": ["frc2064", "frc125", "frc1517"]}, "red": {"score": 168, "teams": ["frc131", "frc2877", "frc133"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 51, "videos": [{"type": "youtube", "key": "EHqjuYhTELI"}], "time_string": "1:00 PM", "set_number": 1, "key": "2014necmp_qm51", "time": "1397235600", "score_breakdown": null, "alliances": {"blue": {"score": 201, "teams": ["frc177", "frc558", "frc4958"]}, "red": {"score": 140, "teams": ["frc2084", "frc4048", "frc4473"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 52, "videos": [{"type": "youtube", "key": "K6JtabqQPxc"}], "time_string": "1:07 PM", "set_number": 1, "key": "2014necmp_qm52", "time": "1397236020", "score_breakdown": null, "alliances": {"blue": {"score": 79, "teams": ["frc999", "frc1735", "frc237"]}, "red": {"score": 170, "teams": ["frc3467", "frc2168", "frc172"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 53, "videos": [{"type": "youtube", "key": "3YIEqRktY1A"}], "time_string": "1:14 PM", "set_number": 1, "key": "2014necmp_qm53", "time": "1397236440", "score_breakdown": null, "alliances": {"blue": {"score": 167, "teams": ["frc716", "frc61", "frc319"]}, "red": {"score": 96, "teams": ["frc246", "frc230", "frc3461"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 54, "videos": [{"type": "youtube", "key": "vvhC8BXZ_UQ"}], "time_string": "1:21 PM", "set_number": 1, "key": "2014necmp_qm54", "time": "1397236860", "score_breakdown": null, "alliances": {"blue": {"score": 106, "teams": ["frc133", "frc4925", "frc1058"]}, "red": {"score": 118, "teams": ["frc131", "frc1100", "frc178"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 55, "videos": [{"type": "youtube", "key": "1b9KdVB6mlQ"}], "time_string": "1:28 PM", "set_number": 1, "key": "2014necmp_qm55", "time": "1397237280", "score_breakdown": null, "alliances": {"blue": {"score": 129, "teams": ["frc1153", "frc4055", "frc1099"]}, "red": {"score": 168, "teams": ["frc2064", "frc1073", "frc166"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 56, "videos": [{"type": "youtube", "key": "qkHPbbGUWs0"}, {"type": "youtube", "key": "3dShVJ3gwM4"}], "time_string": "1:35 PM", "set_number": 1, "key": "2014necmp_qm56", "time": "1397237700", "score_breakdown": null, "alliances": {"blue": {"score": 43, "teams": ["frc172", "frc138", "frc237"]}, "red": {"score": 222, "teams": ["frc125", "frc175", "frc177"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 57, "videos": [{"type": "youtube", "key": "YNKRbn2VEhc"}], "time_string": "1:42 PM", "set_number": 1, "key": "2014necmp_qm57", "time": "1397238120", "score_breakdown": null, "alliances": {"blue": {"score": 132, "teams": ["frc4048", "frc2877", "frc176"]}, "red": {"score": 241, "teams": ["frc2168", "frc4908", "frc195"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 58, "videos": [{"type": "youtube", "key": "lMW8X8ZV-aM"}, {"type": "youtube", "key": "PtrhVcuMi60"}], "time_string": "1:49 PM", "set_number": 1, "key": "2014necmp_qm58", "time": "1397238540", "score_breakdown": null, "alliances": {"blue": {"score": 160, "teams": ["frc2648", "frc2084", "frc61"]}, "red": {"score": 135, "teams": ["frc4909", "frc1991", "frc78"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 59, "videos": [{"type": "youtube", "key": "81W548hX8rw"}], "time_string": "1:56 PM", "set_number": 1, "key": "2014necmp_qm59", "time": "1397238960", "score_breakdown": null, "alliances": {"blue": {"score": 134, "teams": ["frc2067", "frc1517", "frc716"]}, "red": {"score": 157, "teams": ["frc228", "frc811", "frc4564"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 6, "videos": [{"type": "youtube", "key": "O6AULMPpD34"}], "time_string": "3:05 PM", "set_number": 1, "key": "2014necmp_qm6", "time": "1397156700", "score_breakdown": null, "alliances": {"blue": {"score": 114, "teams": ["frc558", "frc4473", "frc4761"]}, "red": {"score": 184, "teams": ["frc1100", "frc716", "frc237"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 60, "videos": [{"type": "youtube", "key": "fa634T_Hjs4"}], "time_string": "2:03 PM", "set_number": 1, "key": "2014necmp_qm60", "time": "1397239380", "score_breakdown": null, "alliances": {"blue": {"score": 175, "teams": ["frc3525", "frc558", "frc3461"]}, "red": {"score": 206, "teams": ["frc3467", "frc69", "frc58"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 61, "videos": [{"type": "youtube", "key": "iPTntE8ioq0"}], "time_string": "2:10 PM", "set_number": 1, "key": "2014necmp_qm61", "time": "1397239800", "score_breakdown": null, "alliances": {"blue": {"score": 94, "teams": ["frc246", "frc999", "frc4761"]}, "red": {"score": 103, "teams": ["frc4958", "frc1519", "frc3930"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 62, "videos": [{"type": "youtube", "key": "mGmzW4YpHSA"}], "time_string": "2:17 PM", "set_number": 1, "key": "2014necmp_qm62", "time": "1397240220", "score_breakdown": null, "alliances": {"blue": {"score": 235, "teams": ["frc1735", "frc5122", "frc4909"]}, "red": {"score": 241, "teams": ["frc319", "frc230", "frc4473"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 63, "videos": [{"type": "youtube", "key": "xhCgZX5n4ec"}], "time_string": "2:24 PM", "set_number": 1, "key": "2014necmp_qm63", "time": "1397240640", "score_breakdown": null, "alliances": {"blue": {"score": 191, "teams": ["frc138", "frc61", "frc4564"]}, "red": {"score": 220, "teams": ["frc2064", "frc2648", "frc133"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 64, "videos": [{"type": "youtube", "key": "GW-yN-flVHE"}], "time_string": "2:31 PM", "set_number": 1, "key": "2014necmp_qm64", "time": "1397241060", "score_breakdown": null, "alliances": {"blue": {"score": 190, "teams": ["frc178", "frc3461", "frc3467"]}, "red": {"score": 150, "teams": ["frc4055", "frc2168", "frc166"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 65, "videos": [{"type": "youtube", "key": "5rGqFepm8yg"}, {"type": "youtube", "key": "Hk2sTe8Huhk"}], "time_string": "2:38 PM", "set_number": 1, "key": "2014necmp_qm65", "time": "1397241480", "score_breakdown": null, "alliances": {"blue": {"score": 42, "teams": ["frc4925", "frc4958", "frc1517"]}, "red": {"score": 212, "teams": ["frc3525", "frc2084", "frc716"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 66, "videos": [{"type": "youtube", "key": "fWeo4Ckz5ys"}], "time_string": "2:45 PM", "set_number": 1, "key": "2014necmp_qm66", "time": "1397241900", "score_breakdown": null, "alliances": {"blue": {"score": 177, "teams": ["frc4048", "frc1100", "frc230"]}, "red": {"score": 225, "teams": ["frc69", "frc999", "frc175"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 67, "videos": [{"type": "youtube", "key": "h30vWnQGGE0"}], "time_string": "2:52 PM", "set_number": 1, "key": "2014necmp_qm67", "time": "1397242320", "score_breakdown": null, "alliances": {"blue": {"score": 207, "teams": ["frc172", "frc2067", "frc4761"]}, "red": {"score": 168, "teams": ["frc4908", "frc2877", "frc1099"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 68, "videos": [{"type": "youtube", "key": "Og5tWZLvCCo"}], "time_string": "2:59 PM", "set_number": 1, "key": "2014necmp_qm68", "time": "1397242740", "score_breakdown": null, "alliances": {"blue": {"score": 177, "teams": ["frc131", "frc811", "frc1991"]}, "red": {"score": 156, "teams": ["frc319", "frc195", "frc237"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 69, "videos": [{"type": "youtube", "key": "v5KSgb-cpws"}], "time_string": "3:06 PM", "set_number": 1, "key": "2014necmp_qm69", "time": "1397243160", "score_breakdown": null, "alliances": {"blue": {"score": 135, "teams": ["frc176", "frc58", "frc246"]}, "red": {"score": 221, "teams": ["frc1735", "frc78", "frc4473"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 7, "videos": [{"type": "youtube", "key": "ZfKoCvF54RI"}], "time_string": "3:12 PM", "set_number": 1, "key": "2014necmp_qm7", "time": "1397157120", "score_breakdown": null, "alliances": {"blue": {"score": 118, "teams": ["frc228", "frc172", "frc78"]}, "red": {"score": 53, "teams": ["frc4958", "frc4909", "frc178"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 70, "videos": [{"type": "youtube", "key": "qjY7mITYaAc"}, {"type": "youtube", "key": "tf6WXwYpoa0"}], "time_string": "3:13 PM", "set_number": 1, "key": "2014necmp_qm70", "time": "1397243580", "score_breakdown": null, "alliances": {"blue": {"score": 236, "teams": ["frc1153", "frc558", "frc1519"]}, "red": {"score": 126, "teams": ["frc3930", "frc5122", "frc177"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 71, "videos": [{"type": "youtube", "key": "i2iOcjnQjnU"}], "time_string": "3:20 PM", "set_number": 1, "key": "2014necmp_qm71", "time": "1397244000", "score_breakdown": null, "alliances": {"blue": {"score": 210, "teams": ["frc1073", "frc228", "frc230"]}, "red": {"score": 170, "teams": ["frc125", "frc1058", "frc172"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 72, "videos": [{"type": "youtube", "key": "gNEAwLr57Tw"}], "time_string": "3:27 PM", "set_number": 1, "key": "2014necmp_qm72", "time": "1397244420", "score_breakdown": null, "alliances": {"blue": {"score": 172, "teams": ["frc1100", "frc2648", "frc4909"]}, "red": {"score": 127, "teams": ["frc2168", "frc3525", "frc4048"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 73, "videos": [{"type": "youtube", "key": "mW4x7t3q_2A"}], "time_string": "3:34 PM", "set_number": 1, "key": "2014necmp_qm73", "time": "1397244840", "score_breakdown": null, "alliances": {"blue": {"score": 163, "teams": ["frc69", "frc811", "frc4473"]}, "red": {"score": 157, "teams": ["frc166", "frc175", "frc61"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 74, "videos": [{"type": "youtube", "key": "RaHDfJGPgnA"}], "time_string": "3:41 PM", "set_number": 1, "key": "2014necmp_qm74", "time": "1397245260", "score_breakdown": null, "alliances": {"blue": {"score": 133, "teams": ["frc1519", "frc1735", "frc716"]}, "red": {"score": 106, "teams": ["frc178", "frc2877", "frc1153"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 75, "videos": [{"type": "youtube", "key": "MixwONm7rXM"}], "time_string": "3:48 PM", "set_number": 1, "key": "2014necmp_qm75", "time": "1397245680", "score_breakdown": null, "alliances": {"blue": {"score": 110, "teams": ["frc138", "frc176", "frc5122"]}, "red": {"score": 147, "teams": ["frc131", "frc228", "frc558"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 76, "videos": [{"type": "youtube", "key": "XCxM7bP86XQ"}], "time_string": "3:55 PM", "set_number": 1, "key": "2014necmp_qm76", "time": "1397246100", "score_breakdown": null, "alliances": {"blue": {"score": 275, "teams": ["frc4055", "frc195", "frc999"]}, "red": {"score": 205, "teams": ["frc78", "frc2084", "frc125"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 77, "videos": [{"type": "youtube", "key": "gciRs1xcENo"}], "time_string": "4:02 PM", "set_number": 1, "key": "2014necmp_qm77", "time": "1397246520", "score_breakdown": null, "alliances": {"blue": {"score": 106, "teams": ["frc319", "frc4958", "frc2064"]}, "red": {"score": 261, "teams": ["frc1058", "frc2067", "frc58"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 78, "videos": [{"type": "youtube", "key": "a_NsquRxN9E"}], "time_string": "4:09 PM", "set_number": 1, "key": "2014necmp_qm78", "time": "1397246940", "score_breakdown": null, "alliances": {"blue": {"score": 197, "teams": ["frc1099", "frc237", "frc246"]}, "red": {"score": 131, "teams": ["frc1517", "frc133", "frc4564"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 79, "videos": [{"type": "youtube", "key": "htN-DTKbgfM"}, {"type": "youtube", "key": "H0lxcq069zU"}], "time_string": "4:16 PM", "set_number": 1, "key": "2014necmp_qm79", "time": "1397247360", "score_breakdown": null, "alliances": {"blue": {"score": 131, "teams": ["frc4925", "frc1991", "frc3461"]}, "red": {"score": 181, "teams": ["frc177", "frc4761", "frc1073"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 8, "videos": [{"type": "youtube", "key": "tOcshJd_MfU"}], "time_string": "3:19 PM", "set_number": 1, "key": "2014necmp_qm8", "time": "1397157540", "score_breakdown": null, "alliances": {"blue": {"score": 175, "teams": ["frc2877", "frc1073", "frc195"]}, "red": {"score": 141, "teams": ["frc2648", "frc175", "frc246"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 80, "videos": [{"type": "youtube", "key": "nJhZaa9zasw"}], "time_string": "4:23 PM", "set_number": 1, "key": "2014necmp_qm80", "time": "1397247780", "score_breakdown": null, "alliances": {"blue": {"score": 179, "teams": ["frc4908", "frc3467", "frc1100"]}, "red": {"score": 196, "teams": ["frc3930", "frc176", "frc131"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 81, "videos": [{"type": "youtube", "key": "DewGRfX-a88"}], "time_string": "4:30 PM", "set_number": 1, "key": "2014necmp_qm81", "time": "1397248200", "score_breakdown": null, "alliances": {"blue": {"score": 232, "teams": ["frc230", "frc999", "frc1153"]}, "red": {"score": 196, "teams": ["frc58", "frc2877", "frc228"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 82, "videos": [{"type": "youtube", "key": "DCc9ek5d8UU"}], "time_string": "4:37 PM", "set_number": 1, "key": "2014necmp_qm82", "time": "1397248620", "score_breakdown": null, "alliances": {"blue": {"score": 157, "teams": ["frc2084", "frc5122", "frc319"]}, "red": {"score": 106, "teams": ["frc2648", "frc138", "frc166"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 83, "videos": [{"type": "youtube", "key": "dRBLFwjrPuo"}], "time_string": "4:44 PM", "set_number": 1, "key": "2014necmp_qm83", "time": "1397249040", "score_breakdown": null, "alliances": {"blue": {"score": 186, "teams": ["frc133", "frc61", "frc4055"]}, "red": {"score": 86, "teams": ["frc1073", "frc4958", "frc4473"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 84, "videos": [{"type": "youtube", "key": "DmWY2ff_Qmg"}], "time_string": "4:51 PM", "set_number": 1, "key": "2014necmp_qm84", "time": "1397249460", "score_breakdown": null, "alliances": {"blue": {"score": 69, "teams": ["frc175", "frc2067", "frc4925"]}, "red": {"score": 265, "teams": ["frc78", "frc3467", "frc1099"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 85, "videos": [{"type": "youtube", "key": "Y90KHtb9bac"}], "time_string": "4:58 PM", "set_number": 1, "key": "2014necmp_qm85", "time": "1397249880", "score_breakdown": null, "alliances": {"blue": {"score": 118, "teams": ["frc178", "frc1058", "frc4908"]}, "red": {"score": 125, "teams": ["frc1517", "frc558", "frc1991"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 86, "videos": [{"type": "youtube", "key": "68gt0YvoAmU"}], "time_string": "5:05 PM", "set_number": 1, "key": "2014necmp_qm86", "time": "1397250300", "score_breakdown": null, "alliances": {"blue": {"score": 202, "teams": ["frc3525", "frc237", "frc4564"]}, "red": {"score": 172, "teams": ["frc1519", "frc4048", "frc3461"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 87, "videos": [{"type": "youtube", "key": "Uqh5jEynRGA"}], "time_string": "9:30 AM", "set_number": 1, "key": "2014necmp_qm87", "time": "1397309400", "score_breakdown": null, "alliances": {"blue": {"score": 130, "teams": ["frc246", "frc125", "frc69"]}, "red": {"score": 230, "teams": ["frc2168", "frc3930", "frc2064"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 88, "videos": [{"type": "youtube", "key": "eTk7i2bDagk"}], "time_string": "9:37 AM", "set_number": 1, "key": "2014necmp_qm88", "time": "1397309820", "score_breakdown": null, "alliances": {"blue": {"score": 79, "teams": ["frc177", "frc172", "frc4909"]}, "red": {"score": 316, "teams": ["frc195", "frc716", "frc811"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 89, "videos": [{"type": "youtube", "key": "YPWh5LFkz4E"}], "time_string": "9:44 AM", "set_number": 1, "key": "2014necmp_qm89", "time": "1397310240", "score_breakdown": null, "alliances": {"blue": {"score": 95, "teams": ["frc4761", "frc4958", "frc175"]}, "red": {"score": 123, "teams": ["frc1735", "frc1517", "frc319"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 9, "videos": [{"type": "youtube", "key": "XFMHYhrOQLU"}], "time_string": "3:26 PM", "set_number": 1, "key": "2014necmp_qm9", "time": "1397157960", "score_breakdown": null, "alliances": {"blue": {"score": 147, "teams": ["frc3930", "frc3461", "frc1735"]}, "red": {"score": 86, "teams": ["frc2064", "frc4925", "frc138"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 90, "videos": [{"type": "youtube", "key": "sxu1_xTETRI"}], "time_string": "9:51 AM", "set_number": 1, "key": "2014necmp_qm90", "time": "1397310660", "score_breakdown": null, "alliances": {"blue": {"score": 145, "teams": ["frc2877", "frc2084", "frc1100"]}, "red": {"score": 146, "teams": ["frc1073", "frc237", "frc58"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 91, "videos": [{"type": "youtube", "key": "r0xVIAj7yAw"}], "time_string": "9:58 AM", "set_number": 1, "key": "2014necmp_qm91", "time": "1397311080", "score_breakdown": null, "alliances": {"blue": {"score": 194, "teams": ["frc246", "frc228", "frc4908"]}, "red": {"score": 150, "teams": ["frc3467", "frc4925", "frc61"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 92, "videos": [{"type": "youtube", "key": "sTX3u1i6HPc"}], "time_string": "10:05 AM", "set_number": 1, "key": "2014necmp_qm92", "time": "1397311500", "score_breakdown": null, "alliances": {"blue": {"score": 150, "teams": ["frc177", "frc166", "frc69"]}, "red": {"score": 140, "teams": ["frc131", "frc125", "frc4909"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 93, "videos": [{"type": "youtube", "key": "DYZcpyDPFRU"}], "time_string": "10:12 AM", "set_number": 1, "key": "2014necmp_qm93", "time": "1397311920", "score_breakdown": null, "alliances": {"blue": {"score": 109, "teams": ["frc999", "frc3461", "frc172"]}, "red": {"score": 98, "teams": ["frc2648", "frc2067", "frc558"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 94, "videos": [{"type": "youtube", "key": "eX12jFiE0lw"}], "time_string": "10:19 AM", "set_number": 1, "key": "2014necmp_qm94", "time": "1397312340", "score_breakdown": null, "alliances": {"blue": {"score": 82, "teams": ["frc133", "frc2168", "frc178"]}, "red": {"score": 186, "teams": ["frc4761", "frc195", "frc1153"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 95, "videos": [{"type": "youtube", "key": "GU1VEmDzrEc"}], "time_string": "10:26 AM", "set_number": 1, "key": "2014necmp_qm95", "time": "1397312760", "score_breakdown": null, "alliances": {"blue": {"score": 187, "teams": ["frc4473", "frc3525", "frc176"]}, "red": {"score": 173, "teams": ["frc1058", "frc138", "frc811"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 96, "videos": [{"type": "youtube", "key": "QI3HZq3EJGA"}], "time_string": "10:33 AM", "set_number": 1, "key": "2014necmp_qm96", "time": "1397313180", "score_breakdown": null, "alliances": {"blue": {"score": 119, "teams": ["frc716", "frc1099", "frc3930"]}, "red": {"score": 225, "teams": ["frc1735", "frc4055", "frc4048"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 97, "videos": [{"type": "youtube", "key": "CjXDc8BT6pU"}], "time_string": "10:40 AM", "set_number": 1, "key": "2014necmp_qm97", "time": "1397313600", "score_breakdown": null, "alliances": {"blue": {"score": 225, "teams": ["frc230", "frc2064", "frc78"]}, "red": {"score": 162, "teams": ["frc5122", "frc1519", "frc1991"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 98, "videos": [{"type": "youtube", "key": "jnzHmSjlWgg"}, {"type": "youtube", "key": "AWLJ25XyrOc"}], "time_string": "10:47 AM", "set_number": 1, "key": "2014necmp_qm98", "time": "1397314020", "score_breakdown": null, "alliances": {"blue": {"score": 136, "teams": ["frc61", "frc1100", "frc177"]}, "red": {"score": 206, "teams": ["frc4564", "frc319", "frc178"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 99, "videos": [{"type": "youtube", "key": "JA4q_E9e-L0"}, {"type": "youtube", "key": "_h47BURAm3U"}], "time_string": "10:54 AM", "set_number": 1, "key": "2014necmp_qm99", "time": "1397314440", "score_breakdown": null, "alliances": {"blue": {"score": 110, "teams": ["frc4958", "frc3461", "frc2084"]}, "red": {"score": 260, "teams": ["frc4908", "frc125", "frc1153"]}}, "event_key": "2014necmp"}, {"comp_level": "sf", "match_number": 1, "videos": [{"type": "youtube", "key": "pZH5eA-YVxk"}], "time_string": "2:42 PM", "set_number": 1, "key": "2014necmp_sf1m1", "time": "1397328120", "score_breakdown": null, "alliances": {"blue": {"score": 126, "teams": ["frc716", "frc811", "frc78"]}, "red": {"score": 178, "teams": ["frc5122", "frc558", "frc195"]}}, "event_key": "2014necmp"}, {"comp_level": "sf", "match_number": 2, "videos": [{"type": "youtube", "key": "VwcQspvplMw"}], "time_string": "2:54 PM", "set_number": 1, "key": "2014necmp_sf1m2", "time": "1397328840", "score_breakdown": null, "alliances": {"blue": {"score": 116, "teams": ["frc716", "frc319", "frc78"]}, "red": {"score": 189, "teams": ["frc558", "frc195", "frc5122"]}}, "event_key": "2014necmp"}, {"comp_level": "sf", "match_number": 1, "videos": [{"type": "youtube", "key": "tSEMwB4-NN8"}], "time_string": "2:48 PM", "set_number": 2, "key": "2014necmp_sf2m1", "time": "1397328480", "score_breakdown": null, "alliances": {"blue": {"score": 209, "teams": ["frc4055", "frc230", "frc177"]}, "red": {"score": 111, "teams": ["frc2168", "frc3525", "frc228"]}}, "event_key": "2014necmp"}, {"comp_level": "sf", "match_number": 2, "videos": [{"type": "youtube", "key": "DIUnjGEroec"}], "time_string": "3:00 PM", "set_number": 2, "key": "2014necmp_sf2m2", "time": "1397329200", "score_breakdown": null, "alliances": {"blue": {"score": 173, "teams": ["frc230", "frc177", "frc4055"]}, "red": {"score": 127, "teams": ["frc3525", "frc228", "frc2168"]}}, "event_key": "2014necmp"}]%
Last edited by plnyyanks : 05-03-2015 at 11:28. Reason: Forgot you could pass X-TBA-App-Id as GET param
Unread 05-03-2015, 11:27
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Re: OPR
The API works with all HTTP GET requests, so you can enter it in a browser, provided you have some extension that allows you to set the X-TBA-App-Id header. Otherwise, it'll just throw an error (like this)
Actually, the X-TBA-App-Id can be set as a URL param. Example: http://www.thebluealliance.com/api/v...ugene:test:v01
Edit: Phil ninjaed my ninja.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 05-03-2015, 12:30
Re: OPR
I just noticed that URL retrieves 2014 data.
I replaced "2014necmp" with "2015inind" and examined the resulting data... and the "score breakdown" doesn't appear to include coopertition, tote, or container. Am I doing something wrong, or is the shiny new 2015 FRC API not providing that data?
Unread 05-03-2015, 13:04
Re: OPR
It's not in the API https://usfirst.collab.net/sf/go/artf4008
Unread 05-03-2015, 13:21
Re: OPR
Originally Posted by Joe Ross View Post
Thanks Joe for that authoritative and definitive link.
So no Twitter data for 2015, and no per-match scoring categories in the API. Very un-inspiring for the stats mavens :-(
I am presently listening to the WMV audio recording to try to understand how such a decision was arrived at.
Unread 05-03-2015, 15:58
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: OPR
Any thoughts this year on "Modified" OPR? Looking at competition scores, I am a bit inclined to divide the Co-Op portion of the points in half. I would put this similar to 2012 whee you had to add points for the Co-Op bridge. In this scenario, both alliances have to bring some Co-Op to the middle in order to get the points.
I can definitely see where component OPR (RCs, Co-Ops, Totes,...) would be powerful this year if you do not have scouting.
Unread 05-03-2015, 16:11
AdamHeard's Avatar
Lead Mentor
Re: OPR
Please someone make an easy to use (at event) component OPR calc
I'll pay with 973 swag if someone does.
Unread 05-03-2015, 16:25
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
Re: OPR
I'd totally do this if I didn't have to go to class in an hour and wasn't volunteering this weekend.
Heck, I'll probably do it anyways.
Field reset: Kettering Kickoff ('13, '14), Kettering ('14, '15), Bedford ('14), Woodhaven ('16), Carver ('16), Einstein! ('16)
Referee: Bedford ('15), MARC ('15, '16), Kettering Kickoff ('15, '16), Kettering District (#1&2: '16), Troy ('16)
Unread 05-03-2015, 16:26
AdamHeard's Avatar
Lead Mentor
Re: OPR
I'm fine if you finish by next wednesday
Unread 05-03-2015, 17:30
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
Re: OPR
The API will return the result of the calculations for OPR, DPR, and CCWM.
I'm really interested in that DPR this year...
Unread 05-03-2015, 17:34
plnyyanks's Avatar
AKA: Phil Lopreiato
Re: OPR
By my calculations, DPR this year is 83% fear factor and 17% taking-cans-in-auto*
*Results not scientific
