Go to Post The most important piece of advice I can give is have someone assigned to pay attention to the batteries. You cannot imagine how many teams end up saying "I thought you were charging the batteries..." - RoboMom [more]
Unread 05-03-2015, 15:48
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Re: The Best Encoders for Drivetrain
Originally Posted by Chris is me View Post
Don't even need the zip ties. Get the .25" ID tubing, or even slightly smaller. Muscle it on and you have a rugged, flexible connection that doesn't twist or otherwise muck up your sensor readings.
Alternately, you can press fit the encoder into a .25" hole in a driveshaft, provided you have some LOOSE way to mechanically constrain the encoder from spinning.
If it wasn't clear, I'm also a fan of the Greyhills.
We've had great success mounting the 63r directly into the hex shaft.
We drill a .25 hole in our shaft with the lathe, then using a bit of hot glue push the encoder into the hole. Zip tie the wires to something rigid nearby and you're in business. The only thing to be wary of is ensuring that your tail stock and chuck head are aligned correctly, if they aren't the encoder will wobble quite a bit when the shaft is spinning.
(2015-?): 973
(2012-2015): 955
