| Thread Tools |
Rating:
Display Modes |
#16
Re: OPR
But if you look carefully at the way saikiranra defined the matrix [A] and the column vector [b], you'll see that his [A] is actually [N]=[AT][A] and his [b] is actually [d]=[AT][b]. [N] will be a square symmetric positive definite matrix, and [N][x]=[d] will have an exact solution because it's already in the Normalized Equations form. The exact solution to [N][x]=[d] will be the least-squares approximate solution to [A][x]≈[b] (to within computer floating-point rounding error). Quote:
Re: OPR
Can anyone show me how to use the thebluealliance.com API to get ranking, match and alliance selection data? I am not able to get it from the FIRST website. I am hoping I don't have to do manual copy and paste. I would like to call it from VBA in my Excel scouting database. Is that possible?
#18
Re: OPR
Keep in mind all requested need a 'X-TBA-App-Id' header (or GET URL parameter, see below), it'll look like: '<team/person id>:<app description>:<version> ' Here are the endpoints you'll need (you can play around with test requests on the apidocs page) Rankings: /api/v2/event/<key>/rankings Results: /api/v2/event/<key>/matches Alliances: /api/v2/event/<key> [alliances will be a field in this response] You can also get the calculated OPR/DPR/CCWM stats at /api/v2/event/<key>/stats And here are a couple StackOverflow threads that may or may not be helpful fetching/parsing JSON data: https://stackoverflow.com/questions/...-unknown-proxy https://stackoverflow.com/questions/...rnal-libraries Last edited by plnyyanks : 05-03-2015 at 11:29. Reason: Can also use GET param |
#19
Re: OPR
Can this just be typed into the URL bar of a browser? Can it be typed at a Windows or Linux command line, and have the output redirected to a file? |
#20
Re: OPR
I keep the following bash alias on my computer that I use for test calls Code:
alias tba-api="curl --header 'X-TBA-App-Id:plnyyanks:curl:0.1'" Code:
➜ phil@fedora ~ tba-api http://www.thebluealliance.com/api/v2/event/2014necmp/matches
[{"comp_level": "f", "match_number": 1, "videos": [{"type": "youtube", "key": "ZRTRszl2iXw"}], "time_string": "3:18 PM", "set_number": 1, "key": "2014necmp_f1m1", "time": "1397330280", "score_breakdown": null, "alliances": {"blue": {"score": 154, "teams": ["frc177", "frc230", "frc4055"]}, "red": {"score": 78, "teams": ["frc195", "frc558", "frc5122"]}}, "event_key": "2014necmp"}, {"comp_level": "f", "match_number": 2, "videos": [{"type": "youtube", "key": "-ijeqxwp7EI"}, {"type": "youtube", "key": "UJEDkibEIVM"}], "time_string": "3:24 PM", "set_number": 1, "key": "2014necmp_f1m2", "time": "1397330640", "score_breakdown": null, "alliances": {"blue": {"score": 210, "teams": ["frc4055", "frc230", "frc177"]}, "red": {"score": 114, "teams": ["frc195", "frc558", "frc5122"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 1, "videos": [{"type": "youtube", "key": "ICPrgPalH74"}], "time_string": "1:30 PM", "set_number": 1, "key": "2014necmp_qf1m1", "time": "1397323800", "score_breakdown": null, "alliances": {"blue": {"score": 101, "teams": ["frc1058", "frc2067", "frc172"]}, "red": {"score": 246, "teams": ["frc5122", "frc558", "frc195"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 2, "videos": [{"type": "youtube", "key": "iX5wK_hqb3M"}], "time_string": "1:54 PM", "set_number": 1, "key": "2014necmp_qf1m2", "time": "1397325240", "score_breakdown": null, "alliances": {"blue": {"score": 212, "teams": ["frc2067", "frc172", "frc1058"]}, "red": {"score": 88, "teams": ["frc195", "frc5122", "frc558"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 3, "videos": [{"type": "youtube", "key": "n5FLwsJpNYI"}], "time_string": "2:18 PM", "set_number": 1, "key": "2014necmp_qf1m3", "time": "1397326680", "score_breakdown": null, "alliances": {"blue": {"score": 94, "teams": ["frc2067", "frc172", "frc1058"]}, "red": {"score": 194, "teams": ["frc5122", "frc558", "frc195"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 1, "videos": [{"type": "youtube", "key": "wInXE0_GiTs"}], "time_string": "1:36 PM", "set_number": 2, "key": "2014necmp_qf2m1", "time": "1397324160", "score_breakdown": null, "alliances": {"blue": {"score": 151, "teams": ["frc1519", "frc3467", "frc58"]}, "red": {"score": 211, "teams": ["frc811", "frc78", "frc716"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 2, "videos": [{"type": "youtube", "key": "04Kjt-mFS6c"}], "time_string": "2:00 PM", "set_number": 2, "key": "2014necmp_qf2m2", "time": "1397325600", "score_breakdown": null, "alliances": {"blue": {"score": 216, "teams": ["frc3467", "frc58", "frc1519"]}, "red": {"score": 161, "teams": ["frc716", "frc811", "frc78"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 3, "videos": [{"type": "youtube", "key": "bscdxXcRaVg"}], "time_string": "2:24 PM", "set_number": 2, "key": "2014necmp_qf2m3", "time": "1397327040", "score_breakdown": null, "alliances": {"blue": {"score": 180, "teams": ["frc3467", "frc58", "frc1519"]}, "red": {"score": 182, "teams": ["frc716", "frc811", "frc78"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 1, "videos": [{"type": "youtube", "key": "FmNkU9GFWa0"}], "time_string": "1:42 PM", "set_number": 3, "key": "2014necmp_qf3m1", "time": "1397324520", "score_breakdown": null, "alliances": {"blue": {"score": 231, "teams": ["frc3525", "frc2168", "frc228"]}, "red": {"score": 220, "teams": ["frc125", "frc1153", "frc4048"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 2, "videos": [{"type": "youtube", "key": "-jCxjA8w2k8"}], "time_string": "2:06 PM", "set_number": 3, "key": "2014necmp_qf3m2", "time": "1397325960", "score_breakdown": null, "alliances": {"blue": {"score": 205, "teams": ["frc2168", "frc3525", "frc228"]}, "red": {"score": 151, "teams": ["frc4048", "frc125", "frc1153"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 1, "videos": [{"type": "youtube", "key": "ziu8fwYooX8"}], "time_string": "1:48 PM", "set_number": 4, "key": "2014necmp_qf4m1", "time": "1397324880", "score_breakdown": null, "alliances": {"blue": {"score": 146, "teams": ["frc1073", "frc131", "frc175"]}, "red": {"score": 185, "teams": ["frc4055", "frc230", "frc177"]}}, "event_key": "2014necmp"}, {"comp_level": "qf", "match_number": 2, "videos": [{"type": "youtube", "key": "APkUOZqQn2w"}], "time_string": "2:12 PM", "set_number": 4, "key": "2014necmp_qf4m2", "time": "1397326320", "score_breakdown": null, "alliances": {"blue": {"score": 166, "teams": ["frc175", "frc131", "frc1073"]}, "red": {"score": 170, "teams": ["frc4055", "frc177", "frc230"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 1, "videos": [{"type": "youtube", "key": "wIr2wRz6IAM"}], "time_string": "2:30 PM", "set_number": 1, "key": "2014necmp_qm1", "time": "1397154600", "score_breakdown": null, "alliances": {"blue": {"score": 128, "teams": ["frc131", "frc319", "frc1153"]}, "red": {"score": 119, "teams": ["frc61", "frc4048", "frc1099"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 10, "videos": [{"type": "youtube", "key": "xFacbW3X64A"}], "time_string": "3:33 PM", "set_number": 1, "key": "2014necmp_qm10", "time": "1397158380", "score_breakdown": null, "alliances": {"blue": {"score": 275, "teams": ["frc558", "frc58", "frc125"]}, "red": {"score": 177, "teams": ["frc4761", "frc61", "frc811"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 100, "videos": [{"type": "youtube", "key": "uh6kxQSPs-U"}], "time_string": "11:01 AM", "set_number": 1, "key": "2014necmp_qm100", "time": "1397314860", "score_breakdown": null, "alliances": {"blue": {"score": 116, "teams": ["frc1735", "frc69", "frc138"]}, "red": {"score": 148, "teams": ["frc999", "frc1073", "frc716"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 101, "videos": [{"type": "youtube", "key": "cHWKLbzau54"}], "time_string": "11:08 AM", "set_number": 1, "key": "2014necmp_qm101", "time": "1397315280", "score_breakdown": null, "alliances": {"blue": {"score": 98, "teams": ["frc2064", "frc1058", "frc4909"]}, "red": {"score": 186, "teams": ["frc4761", "frc237", "frc3467"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 102, "videos": [{"type": "youtube", "key": "Z_ZEAOhlj4E"}], "time_string": "11:15 AM", "set_number": 1, "key": "2014necmp_qm102", "time": "1397315700", "score_breakdown": null, "alliances": {"blue": {"score": 102, "teams": ["frc78", "frc3525", "frc133"]}, "red": {"score": 201, "teams": ["frc230", "frc558", "frc1099"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 103, "videos": [{"type": "youtube", "key": "tkzPMwUXrNY"}], "time_string": "11:22 AM", "set_number": 1, "key": "2014necmp_qm103", "time": "1397316120", "score_breakdown": null, "alliances": {"blue": {"score": 136, "teams": ["frc131", "frc4048", "frc2648"]}, "red": {"score": 173, "teams": ["frc811", "frc246", "frc2067"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 104, "videos": [{"type": "youtube", "key": "BaqX0J3mbUE"}], "time_string": "11:29 AM", "set_number": 1, "key": "2014necmp_qm104", "time": "1397316540", "score_breakdown": null, "alliances": {"blue": {"score": 146, "teams": ["frc2877", "frc4564", "frc1991"]}, "red": {"score": 190, "teams": ["frc4473", "frc5122", "frc195"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 105, "videos": [{"type": "youtube", "key": "ESWcSwEcXRw"}], "time_string": "11:36 AM", "set_number": 1, "key": "2014necmp_qm105", "time": "1397316960", "score_breakdown": null, "alliances": {"blue": {"score": 146, "teams": ["frc1517", "frc3930", "frc58"]}, "red": {"score": 153, "teams": ["frc172", "frc176", "frc166"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 106, "videos": [{"type": "youtube", "key": "i-y1nd-a6YU"}], "time_string": "11:43 AM", "set_number": 1, "key": "2014necmp_qm106", "time": "1397317380", "score_breakdown": null, "alliances": {"blue": {"score": 191, "teams": ["frc175", "frc1519", "frc2168"]}, "red": {"score": 122, "teams": ["frc4055", "frc4925", "frc228"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 11, "videos": [{"type": "youtube", "key": "eknIU2Skr-M"}], "time_string": "3:40 PM", "set_number": 1, "key": "2014necmp_qm11", "time": "1397158800", "score_breakdown": null, "alliances": {"blue": {"score": 126, "teams": ["frc2067", "frc1991", "frc4055"]}, "red": {"score": 247, "teams": ["frc3525", "frc1153", "frc172"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 12, "videos": [{"type": "youtube", "key": "h49-_UAtmFQ"}], "time_string": "3:47 PM", "set_number": 1, "key": "2014necmp_qm12", "time": "1397159220", "score_breakdown": null, "alliances": {"blue": {"score": 165, "teams": ["frc69", "frc1519", "frc78"]}, "red": {"score": 136, "teams": ["frc1099", "frc1058", "frc1517"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 13, "videos": [{"type": "youtube", "key": "R_yU1efuMdA"}], "time_string": "3:54 PM", "set_number": 1, "key": "2014necmp_qm13", "time": "1397159640", "score_breakdown": null, "alliances": {"blue": {"score": 127, "teams": ["frc4473", "frc131", "frc2064"]}, "red": {"score": 122, "teams": ["frc999", "frc2168", "frc228"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 14, "videos": [{"type": "youtube", "key": "UxnxjBftKfY"}], "time_string": "4:01 PM", "set_number": 1, "key": "2014necmp_qm14", "time": "1397160060", "score_breakdown": null, "alliances": {"blue": {"score": 170, "teams": ["frc4048", "frc175", "frc4564"]}, "red": {"score": 167, "teams": ["frc178", "frc2084", "frc176"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 15, "videos": [{"type": "youtube", "key": "L4o5S_5OHV4"}], "time_string": "4:08 PM", "set_number": 1, "key": "2014necmp_qm15", "time": "1397160480", "score_breakdown": null, "alliances": {"blue": {"score": 185, "teams": ["frc230", "frc3467", "frc195"]}, "red": {"score": 102, "teams": ["frc4958", "frc138", "frc1100"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 16, "videos": [{"type": "youtube", "key": "4K2s3vnqXgY"}, {"type": "youtube", "key": "Yz4h6lCLyv4"}], "time_string": "4:15 PM", "set_number": 1, "key": "2014necmp_qm16", "time": "1397160900", "score_breakdown": null, "alliances": {"blue": {"score": 118, "teams": ["frc2648", "frc177", "frc4908"]}, "red": {"score": 141, "teams": ["frc133", "frc166", "frc716"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 17, "videos": [{"type": "youtube", "key": "ZJxBMPE8fRQ"}], "time_string": "4:22 PM", "set_number": 1, "key": "2014necmp_qm17", "time": "1397161320", "score_breakdown": null, "alliances": {"blue": {"score": 147, "teams": ["frc246", "frc2877", "frc3930"]}, "red": {"score": 142, "teams": ["frc3461", "frc4909", "frc319"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 18, "videos": [{"type": "youtube", "key": "0OqIluNyHYc"}], "time_string": "4:29 PM", "set_number": 1, "key": "2014necmp_qm18", "time": "1397161740", "score_breakdown": null, "alliances": {"blue": {"score": 135, "teams": ["frc5122", "frc1073", "frc1153"]}, "red": {"score": 72, "teams": ["frc237", "frc4925", "frc176"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 19, "videos": [{"type": "youtube", "key": "xGP_L2dZ_Y0"}], "time_string": "4:36 PM", "set_number": 1, "key": "2014necmp_qm19", "time": "1397162160", "score_breakdown": null, "alliances": {"blue": {"score": 90, "teams": ["frc4564", "frc2084", "frc4761"]}, "red": {"score": 201, "teams": ["frc230", "frc131", "frc172"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 2, "videos": [{"type": "youtube", "key": "GRNlm29DbbU"}], "time_string": "2:37 PM", "set_number": 1, "key": "2014necmp_qm2", "time": "1397155020", "score_breakdown": null, "alliances": {"blue": {"score": 157, "teams": ["frc58", "frc2084", "frc2168"]}, "red": {"score": 202, "teams": ["frc2067", "frc133", "frc1519"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 20, "videos": [{"type": "youtube", "key": "XGuGLX18lq4"}, {"type": "youtube", "key": "trmMPntU5K4"}, {"type": "youtube", "key": "vN9OPQ146X0"}], "time_string": "4:43 PM", "set_number": 1, "key": "2014necmp_qm20", "time": "1397162580", "score_breakdown": null, "alliances": {"blue": {"score": 88, "teams": ["frc999", "frc1099", "frc2064"]}, "red": {"score": 95, "teams": ["frc178", "frc177", "frc716"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 21, "videos": [{"type": "youtube", "key": "KTr5E1WpU5Q"}], "time_string": "4:50 PM", "set_number": 1, "key": "2014necmp_qm21", "time": "1397163000", "score_breakdown": null, "alliances": {"blue": {"score": 125, "teams": ["frc195", "frc1058", "frc1519"]}, "red": {"score": 71, "teams": ["frc3461", "frc61", "frc4908"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 22, "videos": [{"type": "youtube", "key": "r7E0k0Jjb7k"}], "time_string": "4:57 PM", "set_number": 1, "key": "2014necmp_qm22", "time": "1397163420", "score_breakdown": null, "alliances": {"blue": {"score": 149, "teams": ["frc1100", "frc558", "frc166"]}, "red": {"score": 76, "teams": ["frc1991", "frc246", "frc1735"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 23, "videos": [{"type": "youtube", "key": "0FouILThLLM"}], "time_string": "5:04 PM", "set_number": 1, "key": "2014necmp_qm23", "time": "1397163840", "score_breakdown": null, "alliances": {"blue": {"score": 132, "teams": ["frc4048", "frc138", "frc1073"]}, "red": {"score": 151, "teams": ["frc1517", "frc2168", "frc78"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 24, "videos": [{"type": "youtube", "key": "O7RgVFRtWQk"}], "time_string": "5:11 PM", "set_number": 1, "key": "2014necmp_qm24", "time": "1397164260", "score_breakdown": null, "alliances": {"blue": {"score": 58, "teams": ["frc4925", "frc69", "frc2648"]}, "red": {"score": 129, "teams": ["frc237", "frc228", "frc4958"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 25, "videos": [{"type": "youtube", "key": "H57fYCZJUEw"}], "time_string": "5:18 PM", "set_number": 1, "key": "2014necmp_qm25", "time": "1397164680", "score_breakdown": null, "alliances": {"blue": {"score": 146, "teams": ["frc175", "frc2877", "frc5122"]}, "red": {"score": 275, "teams": ["frc811", "frc3930", "frc3525"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 26, "videos": [{"type": "youtube", "key": "7lLhTARVPRA"}], "time_string": "5:25 PM", "set_number": 1, "key": "2014necmp_qm26", "time": "1397165100", "score_breakdown": null, "alliances": {"blue": {"score": 195, "teams": ["frc319", "frc58", "frc133"]}, "red": {"score": 132, "teams": ["frc4909", "frc4055", "frc3467"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 27, "videos": [{"type": "youtube", "key": "lHkVbxIrEWg"}], "time_string": "5:32 PM", "set_number": 1, "key": "2014necmp_qm27", "time": "1397165520", "score_breakdown": null, "alliances": {"blue": {"score": 167, "teams": ["frc4473", "frc125", "frc716"]}, "red": {"score": 101, "teams": ["frc2067", "frc178", "frc78"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 28, "videos": [{"type": "youtube", "key": "LOM_r2n4QsQ"}], "time_string": "5:39 PM", "set_number": 1, "key": "2014necmp_qm28", "time": "1397165940", "score_breakdown": null, "alliances": {"blue": {"score": 104, "teams": ["frc2084", "frc1099", "frc138"]}, "red": {"score": 169, "teams": ["frc246", "frc1100", "frc2064"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 29, "videos": [{"type": "youtube", "key": "d9Bmmy_TApo"}], "time_string": "5:46 PM", "set_number": 1, "key": "2014necmp_qm29", "time": "1397166360", "score_breakdown": null, "alliances": {"blue": {"score": 151, "teams": ["frc811", "frc237", "frc2168"]}, "red": {"score": 157, "teams": ["frc4908", "frc4958", "frc230"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 3, "videos": [{"type": "youtube", "key": "7ifzn1jZZ_4"}, {"type": "youtube", "key": "Kxwb2Ri-kXM"}], "time_string": "2:44 PM", "set_number": 1, "key": "2014necmp_qm3", "time": "1397155440", "score_breakdown": null, "alliances": {"blue": {"score": 225, "teams": ["frc4055", "frc176", "frc177"]}, "red": {"score": 161, "teams": ["frc230", "frc69", "frc1517"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 30, "videos": [{"type": "youtube", "key": "1-9Q41Xbnvk"}], "time_string": "5:53 PM", "set_number": 1, "key": "2014necmp_qm30", "time": "1397166780", "score_breakdown": null, "alliances": {"blue": {"score": 150, "teams": ["frc4761", "frc133", "frc1991"]}, "red": {"score": 180, "teams": ["frc5122", "frc4048", "frc999"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 31, "videos": [{"type": "youtube", "key": "t44hycmnwcg"}], "time_string": "9:30 AM", "set_number": 1, "key": "2014necmp_qm31", "time": "1397223000", "score_breakdown": null, "alliances": {"blue": {"score": 77, "teams": ["frc1517", "frc4473", "frc175"]}, "red": {"score": 103, "teams": ["frc1153", "frc3461", "frc2648"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 32, "videos": [{"type": "youtube", "key": "EH43R6zGxWE"}], "time_string": "9:37 AM", "set_number": 1, "key": "2014necmp_qm32", "time": "1397223420", "score_breakdown": null, "alliances": {"blue": {"score": 137, "teams": ["frc3930", "frc228", "frc2067"]}, "red": {"score": 196, "teams": ["frc1735", "frc195", "frc177"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 33, "videos": [{"type": "youtube", "key": "F1xJCZH8Qv0"}], "time_string": "9:44 AM", "set_number": 1, "key": "2014necmp_qm33", "time": "1397223840", "score_breakdown": null, "alliances": {"blue": {"score": 104, "teams": ["frc166", "frc4925", "frc4909"]}, "red": {"score": 204, "teams": ["frc176", "frc4564", "frc558"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 34, "videos": [{"type": "youtube", "key": "YeL99JfdEe8"}], "time_string": "9:51 AM", "set_number": 1, "key": "2014necmp_qm34", "time": "1397224260", "score_breakdown": null, "alliances": {"blue": {"score": 166, "teams": ["frc1519", "frc319", "frc3467"]}, "red": {"score": 115, "teams": ["frc1073", "frc172", "frc69"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 35, "videos": [{"type": "youtube", "key": "sXavEZJS2Fo"}], "time_string": "9:58 AM", "set_number": 1, "key": "2014necmp_qm35", "time": "1397224680", "score_breakdown": null, "alliances": {"blue": {"score": 156, "teams": ["frc61", "frc1058", "frc131"]}, "red": {"score": 165, "teams": ["frc2877", "frc4055", "frc3525"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 36, "videos": [{"type": "youtube", "key": "BlWH5Mu_JW4"}], "time_string": "10:05 AM", "set_number": 1, "key": "2014necmp_qm36", "time": "1397225100", "score_breakdown": null, "alliances": {"blue": {"score": 250, "teams": ["frc125", "frc2648", "frc195"]}, "red": {"score": 156, "teams": ["frc58", "frc1099", "frc5122"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 37, "videos": [{"type": "youtube", "key": "cQbjC51VVk0"}], "time_string": "10:12 AM", "set_number": 1, "key": "2014necmp_qm37", "time": "1397225520", "score_breakdown": null, "alliances": {"blue": {"score": 188, "teams": ["frc811", "frc78", "frc3461"]}, "red": {"score": 221, "teams": ["frc133", "frc1100", "frc228"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 38, "videos": [{"type": "youtube", "key": "97g6RRYvWe4"}], "time_string": "10:19 AM", "set_number": 1, "key": "2014necmp_qm38", "time": "1397225940", "score_breakdown": null, "alliances": {"blue": {"score": 154, "teams": ["frc3930", "frc178", "frc166"]}, "red": {"score": 166, "teams": ["frc230", "frc237", "frc2067"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 39, "videos": [{"type": "youtube", "key": "0zrxn9Qz0r0"}], "time_string": "10:26 AM", "set_number": 1, "key": "2014necmp_qm39", "time": "1397226360", "score_breakdown": null, "alliances": {"blue": {"score": 135, "teams": ["frc4958", "frc69", "frc4564"]}, "red": {"score": 147, "teams": ["frc138", "frc2877", "frc4761"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 4, "videos": [{"type": "youtube", "key": "VSN_wHILsZE"}], "time_string": "2:51 PM", "set_number": 1, "key": "2014necmp_qm4", "time": "1397155860", "score_breakdown": null, "alliances": {"blue": {"score": 118, "teams": ["frc811", "frc166", "frc5122"]}, "red": {"score": 98, "teams": ["frc1058", "frc999", "frc3467"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 40, "videos": [{"type": "youtube", "key": "cLuEygRrrJM"}], "time_string": "10:33 AM", "set_number": 1, "key": "2014necmp_qm40", "time": "1397226780", "score_breakdown": null, "alliances": {"blue": {"score": 112, "teams": ["frc1517", "frc176", "frc1153"]}, "red": {"score": 91, "teams": ["frc999", "frc61", "frc4909"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 41, "videos": [{"type": "youtube", "key": "fY1QShwfqrg"}], "time_string": "10:40 AM", "set_number": 1, "key": "2014necmp_qm41", "time": "1397227200", "score_breakdown": null, "alliances": {"blue": {"score": 161, "teams": ["frc319", "frc1073", "frc175"]}, "red": {"score": 189, "teams": ["frc2064", "frc4908", "frc558"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 42, "videos": [{"type": "youtube", "key": "j7iBmZJNyCY"}], "time_string": "10:47 AM", "set_number": 1, "key": "2014necmp_qm42", "time": "1397227620", "score_breakdown": null, "alliances": {"blue": {"score": 142, "teams": ["frc3525", "frc1058", "frc1735"]}, "red": {"score": 84, "teams": ["frc2084", "frc177", "frc246"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 43, "videos": [{"type": "youtube", "key": "Mqt5nz3dK0M"}], "time_string": "10:54 AM", "set_number": 1, "key": "2014necmp_qm43", "time": "1397228040", "score_breakdown": null, "alliances": {"blue": {"score": 240, "teams": ["frc125", "frc3467", "frc4048"]}, "red": {"score": 95, "teams": ["frc4473", "frc4925", "frc1519"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 44, "videos": [{"type": "youtube", "key": "3DeeP1LAU7s"}], "time_string": "11:01 AM", "set_number": 1, "key": "2014necmp_qm44", "time": "1397228460", "score_breakdown": null, "alliances": {"blue": {"score": 137, "teams": ["frc131", "frc2168", "frc716"]}, "red": {"score": 185, "teams": ["frc58", "frc1991", "frc172"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 45, "videos": [{"type": "youtube", "key": "LumUB5rt3TY"}], "time_string": "11:08 AM", "set_number": 1, "key": "2014necmp_qm45", "time": "1397228880", "score_breakdown": null, "alliances": {"blue": {"score": 251, "teams": ["frc2067", "frc4908", "frc5122"]}, "red": {"score": 190, "teams": ["frc4055", "frc69", "frc1100"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 46, "videos": [{"type": "youtube", "key": "CrFtbEuEfqQ"}], "time_string": "11:15 AM", "set_number": 1, "key": "2014necmp_qm46", "time": "1397229300", "score_breakdown": null, "alliances": {"blue": {"score": 122, "teams": ["frc1073", "frc78", "frc1058"]}, "red": {"score": 122, "teams": ["frc4564", "frc1153", "frc3930"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 47, "videos": [{"type": "youtube", "key": "d7pDBW6mN2w"}], "time_string": "11:22 AM", "set_number": 1, "key": "2014necmp_qm47", "time": "1397229720", "score_breakdown": null, "alliances": {"blue": {"score": 188, "teams": ["frc195", "frc166", "frc228"]}, "red": {"score": 56, "teams": ["frc3525", "frc4761", "frc4925"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 48, "videos": [{"type": "youtube", "key": "QtB76b2heXs"}], "time_string": "11:29 AM", "set_number": 1, "key": "2014necmp_qm48", "time": "1397230140", "score_breakdown": null, "alliances": {"blue": {"score": 156, "teams": ["frc138", "frc4909", "frc58"]}, "red": {"score": 144, "teams": ["frc1099", "frc175", "frc1991"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 49, "videos": [{"type": "youtube", "key": "5B6o93-xNzw"}], "time_string": "11:36 AM", "set_number": 1, "key": "2014necmp_qm49", "time": "1397230560", "score_breakdown": null, "alliances": {"blue": {"score": 204, "teams": ["frc4055", "frc1519", "frc178"]}, "red": {"score": 157, "teams": ["frc176", "frc811", "frc2648"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 5, "videos": [{"type": "youtube", "key": "pk29fEJyanA"}], "time_string": "2:58 PM", "set_number": 1, "key": "2014necmp_qm5", "time": "1397156280", "score_breakdown": null, "alliances": {"blue": {"score": 148, "teams": ["frc3525", "frc1991", "frc4908"]}, "red": {"score": 171, "teams": ["frc125", "frc1735", "frc4564"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 50, "videos": [{"type": "youtube", "key": "vW1_Y1s1Jno"}], "time_string": "11:43 AM", "set_number": 1, "key": "2014necmp_qm50", "time": "1397230980", "score_breakdown": null, "alliances": {"blue": {"score": 150, "teams": ["frc2064", "frc125", "frc1517"]}, "red": {"score": 168, "teams": ["frc131", "frc2877", "frc133"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 51, "videos": [{"type": "youtube", "key": "EHqjuYhTELI"}], "time_string": "1:00 PM", "set_number": 1, "key": "2014necmp_qm51", "time": "1397235600", "score_breakdown": null, "alliances": {"blue": {"score": 201, "teams": ["frc177", "frc558", "frc4958"]}, "red": {"score": 140, "teams": ["frc2084", "frc4048", "frc4473"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 52, "videos": [{"type": "youtube", "key": "K6JtabqQPxc"}], "time_string": "1:07 PM", "set_number": 1, "key": "2014necmp_qm52", "time": "1397236020", "score_breakdown": null, "alliances": {"blue": {"score": 79, "teams": ["frc999", "frc1735", "frc237"]}, "red": {"score": 170, "teams": ["frc3467", "frc2168", "frc172"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 53, "videos": [{"type": "youtube", "key": "3YIEqRktY1A"}], "time_string": "1:14 PM", "set_number": 1, "key": "2014necmp_qm53", "time": "1397236440", "score_breakdown": null, "alliances": {"blue": {"score": 167, "teams": ["frc716", "frc61", "frc319"]}, "red": {"score": 96, "teams": ["frc246", "frc230", "frc3461"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 54, "videos": [{"type": "youtube", "key": "vvhC8BXZ_UQ"}], "time_string": "1:21 PM", "set_number": 1, "key": "2014necmp_qm54", "time": "1397236860", "score_breakdown": null, "alliances": {"blue": {"score": 106, "teams": ["frc133", "frc4925", "frc1058"]}, "red": {"score": 118, "teams": ["frc131", "frc1100", "frc178"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 55, "videos": [{"type": "youtube", "key": "1b9KdVB6mlQ"}], "time_string": "1:28 PM", "set_number": 1, "key": "2014necmp_qm55", "time": "1397237280", "score_breakdown": null, "alliances": {"blue": {"score": 129, "teams": ["frc1153", "frc4055", "frc1099"]}, "red": {"score": 168, "teams": ["frc2064", "frc1073", "frc166"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 56, "videos": [{"type": "youtube", "key": "qkHPbbGUWs0"}, {"type": "youtube", "key": "3dShVJ3gwM4"}], "time_string": "1:35 PM", "set_number": 1, "key": "2014necmp_qm56", "time": "1397237700", "score_breakdown": null, "alliances": {"blue": {"score": 43, "teams": ["frc172", "frc138", "frc237"]}, "red": {"score": 222, "teams": ["frc125", "frc175", "frc177"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 57, "videos": [{"type": "youtube", "key": "YNKRbn2VEhc"}], "time_string": "1:42 PM", "set_number": 1, "key": "2014necmp_qm57", "time": "1397238120", "score_breakdown": null, "alliances": {"blue": {"score": 132, "teams": ["frc4048", "frc2877", "frc176"]}, "red": {"score": 241, "teams": ["frc2168", "frc4908", "frc195"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 58, "videos": [{"type": "youtube", "key": "lMW8X8ZV-aM"}, {"type": "youtube", "key": "PtrhVcuMi60"}], "time_string": "1:49 PM", "set_number": 1, "key": "2014necmp_qm58", "time": "1397238540", "score_breakdown": null, "alliances": {"blue": {"score": 160, "teams": ["frc2648", "frc2084", "frc61"]}, "red": {"score": 135, "teams": ["frc4909", "frc1991", "frc78"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 59, "videos": [{"type": "youtube", "key": "81W548hX8rw"}], "time_string": "1:56 PM", "set_number": 1, "key": "2014necmp_qm59", "time": "1397238960", "score_breakdown": null, "alliances": {"blue": {"score": 134, "teams": ["frc2067", "frc1517", "frc716"]}, "red": {"score": 157, "teams": ["frc228", "frc811", "frc4564"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 6, "videos": [{"type": "youtube", "key": "O6AULMPpD34"}], "time_string": "3:05 PM", "set_number": 1, "key": "2014necmp_qm6", "time": "1397156700", "score_breakdown": null, "alliances": {"blue": {"score": 114, "teams": ["frc558", "frc4473", "frc4761"]}, "red": {"score": 184, "teams": ["frc1100", "frc716", "frc237"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 60, "videos": [{"type": "youtube", "key": "fa634T_Hjs4"}], "time_string": "2:03 PM", "set_number": 1, "key": "2014necmp_qm60", "time": "1397239380", "score_breakdown": null, "alliances": {"blue": {"score": 175, "teams": ["frc3525", "frc558", "frc3461"]}, "red": {"score": 206, "teams": ["frc3467", "frc69", "frc58"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 61, "videos": [{"type": "youtube", "key": "iPTntE8ioq0"}], "time_string": "2:10 PM", "set_number": 1, "key": "2014necmp_qm61", "time": "1397239800", "score_breakdown": null, "alliances": {"blue": {"score": 94, "teams": ["frc246", "frc999", "frc4761"]}, "red": {"score": 103, "teams": ["frc4958", "frc1519", "frc3930"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 62, "videos": [{"type": "youtube", "key": "mGmzW4YpHSA"}], "time_string": "2:17 PM", "set_number": 1, "key": "2014necmp_qm62", "time": "1397240220", "score_breakdown": null, "alliances": {"blue": {"score": 235, "teams": ["frc1735", "frc5122", "frc4909"]}, "red": {"score": 241, "teams": ["frc319", "frc230", "frc4473"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 63, "videos": [{"type": "youtube", "key": "xhCgZX5n4ec"}], "time_string": "2:24 PM", "set_number": 1, "key": "2014necmp_qm63", "time": "1397240640", "score_breakdown": null, "alliances": {"blue": {"score": 191, "teams": ["frc138", "frc61", "frc4564"]}, "red": {"score": 220, "teams": ["frc2064", "frc2648", "frc133"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 64, "videos": [{"type": "youtube", "key": "GW-yN-flVHE"}], "time_string": "2:31 PM", "set_number": 1, "key": "2014necmp_qm64", "time": "1397241060", "score_breakdown": null, "alliances": {"blue": {"score": 190, "teams": ["frc178", "frc3461", "frc3467"]}, "red": {"score": 150, "teams": ["frc4055", "frc2168", "frc166"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 65, "videos": [{"type": "youtube", "key": "5rGqFepm8yg"}, {"type": "youtube", "key": "Hk2sTe8Huhk"}], "time_string": "2:38 PM", "set_number": 1, "key": "2014necmp_qm65", "time": "1397241480", "score_breakdown": null, "alliances": {"blue": {"score": 42, "teams": ["frc4925", "frc4958", "frc1517"]}, "red": {"score": 212, "teams": ["frc3525", "frc2084", "frc716"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 66, "videos": [{"type": "youtube", "key": "fWeo4Ckz5ys"}], "time_string": "2:45 PM", "set_number": 1, "key": "2014necmp_qm66", "time": "1397241900", "score_breakdown": null, "alliances": {"blue": {"score": 177, "teams": ["frc4048", "frc1100", "frc230"]}, "red": {"score": 225, "teams": ["frc69", "frc999", "frc175"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 67, "videos": [{"type": "youtube", "key": "h30vWnQGGE0"}], "time_string": "2:52 PM", "set_number": 1, "key": "2014necmp_qm67", "time": "1397242320", "score_breakdown": null, "alliances": {"blue": {"score": 207, "teams": ["frc172", "frc2067", "frc4761"]}, "red": {"score": 168, "teams": ["frc4908", "frc2877", "frc1099"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 68, "videos": [{"type": "youtube", "key": "Og5tWZLvCCo"}], "time_string": "2:59 PM", "set_number": 1, "key": "2014necmp_qm68", "time": "1397242740", "score_breakdown": null, "alliances": {"blue": {"score": 177, "teams": ["frc131", "frc811", "frc1991"]}, "red": {"score": 156, "teams": ["frc319", "frc195", "frc237"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 69, "videos": [{"type": "youtube", "key": "v5KSgb-cpws"}], "time_string": "3:06 PM", "set_number": 1, "key": "2014necmp_qm69", "time": "1397243160", "score_breakdown": null, "alliances": {"blue": {"score": 135, "teams": ["frc176", "frc58", "frc246"]}, "red": {"score": 221, "teams": ["frc1735", "frc78", "frc4473"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 7, "videos": [{"type": "youtube", "key": "ZfKoCvF54RI"}], "time_string": "3:12 PM", "set_number": 1, "key": "2014necmp_qm7", "time": "1397157120", "score_breakdown": null, "alliances": {"blue": {"score": 118, "teams": ["frc228", "frc172", "frc78"]}, "red": {"score": 53, "teams": ["frc4958", "frc4909", "frc178"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 70, "videos": [{"type": "youtube", "key": "qjY7mITYaAc"}, {"type": "youtube", "key": "tf6WXwYpoa0"}], "time_string": "3:13 PM", "set_number": 1, "key": "2014necmp_qm70", "time": "1397243580", "score_breakdown": null, "alliances": {"blue": {"score": 236, "teams": ["frc1153", "frc558", "frc1519"]}, "red": {"score": 126, "teams": ["frc3930", "frc5122", "frc177"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 71, "videos": [{"type": "youtube", "key": "i2iOcjnQjnU"}], "time_string": "3:20 PM", "set_number": 1, "key": "2014necmp_qm71", "time": "1397244000", "score_breakdown": null, "alliances": {"blue": {"score": 210, "teams": ["frc1073", "frc228", "frc230"]}, "red": {"score": 170, "teams": ["frc125", "frc1058", "frc172"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 72, "videos": [{"type": "youtube", "key": "gNEAwLr57Tw"}], "time_string": "3:27 PM", "set_number": 1, "key": "2014necmp_qm72", "time": "1397244420", "score_breakdown": null, "alliances": {"blue": {"score": 172, "teams": ["frc1100", "frc2648", "frc4909"]}, "red": {"score": 127, "teams": ["frc2168", "frc3525", "frc4048"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 73, "videos": [{"type": "youtube", "key": "mW4x7t3q_2A"}], "time_string": "3:34 PM", "set_number": 1, "key": "2014necmp_qm73", "time": "1397244840", "score_breakdown": null, "alliances": {"blue": {"score": 163, "teams": ["frc69", "frc811", "frc4473"]}, "red": {"score": 157, "teams": ["frc166", "frc175", "frc61"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 74, "videos": [{"type": "youtube", "key": "RaHDfJGPgnA"}], "time_string": "3:41 PM", "set_number": 1, "key": "2014necmp_qm74", "time": "1397245260", "score_breakdown": null, "alliances": {"blue": {"score": 133, "teams": ["frc1519", "frc1735", "frc716"]}, "red": {"score": 106, "teams": ["frc178", "frc2877", "frc1153"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 75, "videos": [{"type": "youtube", "key": "MixwONm7rXM"}], "time_string": "3:48 PM", "set_number": 1, "key": "2014necmp_qm75", "time": "1397245680", "score_breakdown": null, "alliances": {"blue": {"score": 110, "teams": ["frc138", "frc176", "frc5122"]}, "red": {"score": 147, "teams": ["frc131", "frc228", "frc558"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 76, "videos": [{"type": "youtube", "key": "XCxM7bP86XQ"}], "time_string": "3:55 PM", "set_number": 1, "key": "2014necmp_qm76", "time": "1397246100", "score_breakdown": null, "alliances": {"blue": {"score": 275, "teams": ["frc4055", "frc195", "frc999"]}, "red": {"score": 205, "teams": ["frc78", "frc2084", "frc125"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 77, "videos": [{"type": "youtube", "key": "gciRs1xcENo"}], "time_string": "4:02 PM", "set_number": 1, "key": "2014necmp_qm77", "time": "1397246520", "score_breakdown": null, "alliances": {"blue": {"score": 106, "teams": ["frc319", "frc4958", "frc2064"]}, "red": {"score": 261, "teams": ["frc1058", "frc2067", "frc58"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 78, "videos": [{"type": "youtube", "key": "a_NsquRxN9E"}], "time_string": "4:09 PM", "set_number": 1, "key": "2014necmp_qm78", "time": "1397246940", "score_breakdown": null, "alliances": {"blue": {"score": 197, "teams": ["frc1099", "frc237", "frc246"]}, "red": {"score": 131, "teams": ["frc1517", "frc133", "frc4564"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 79, "videos": [{"type": "youtube", "key": "htN-DTKbgfM"}, {"type": "youtube", "key": "H0lxcq069zU"}], "time_string": "4:16 PM", "set_number": 1, "key": "2014necmp_qm79", "time": "1397247360", "score_breakdown": null, "alliances": {"blue": {"score": 131, "teams": ["frc4925", "frc1991", "frc3461"]}, "red": {"score": 181, "teams": ["frc177", "frc4761", "frc1073"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 8, "videos": [{"type": "youtube", "key": "tOcshJd_MfU"}], "time_string": "3:19 PM", "set_number": 1, "key": "2014necmp_qm8", "time": "1397157540", "score_breakdown": null, "alliances": {"blue": {"score": 175, "teams": ["frc2877", "frc1073", "frc195"]}, "red": {"score": 141, "teams": ["frc2648", "frc175", "frc246"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 80, "videos": [{"type": "youtube", "key": "nJhZaa9zasw"}], "time_string": "4:23 PM", "set_number": 1, "key": "2014necmp_qm80", "time": "1397247780", "score_breakdown": null, "alliances": {"blue": {"score": 179, "teams": ["frc4908", "frc3467", "frc1100"]}, "red": {"score": 196, "teams": ["frc3930", "frc176", "frc131"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 81, "videos": [{"type": "youtube", "key": "DewGRfX-a88"}], "time_string": "4:30 PM", "set_number": 1, "key": "2014necmp_qm81", "time": "1397248200", "score_breakdown": null, "alliances": {"blue": {"score": 232, "teams": ["frc230", "frc999", "frc1153"]}, "red": {"score": 196, "teams": ["frc58", "frc2877", "frc228"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 82, "videos": [{"type": "youtube", "key": "DCc9ek5d8UU"}], "time_string": "4:37 PM", "set_number": 1, "key": "2014necmp_qm82", "time": "1397248620", "score_breakdown": null, "alliances": {"blue": {"score": 157, "teams": ["frc2084", "frc5122", "frc319"]}, "red": {"score": 106, "teams": ["frc2648", "frc138", "frc166"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 83, "videos": [{"type": "youtube", "key": "dRBLFwjrPuo"}], "time_string": "4:44 PM", "set_number": 1, "key": "2014necmp_qm83", "time": "1397249040", "score_breakdown": null, "alliances": {"blue": {"score": 186, "teams": ["frc133", "frc61", "frc4055"]}, "red": {"score": 86, "teams": ["frc1073", "frc4958", "frc4473"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 84, "videos": [{"type": "youtube", "key": "DmWY2ff_Qmg"}], "time_string": "4:51 PM", "set_number": 1, "key": "2014necmp_qm84", "time": "1397249460", "score_breakdown": null, "alliances": {"blue": {"score": 69, "teams": ["frc175", "frc2067", "frc4925"]}, "red": {"score": 265, "teams": ["frc78", "frc3467", "frc1099"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 85, "videos": [{"type": "youtube", "key": "Y90KHtb9bac"}], "time_string": "4:58 PM", "set_number": 1, "key": "2014necmp_qm85", "time": "1397249880", "score_breakdown": null, "alliances": {"blue": {"score": 118, "teams": ["frc178", "frc1058", "frc4908"]}, "red": {"score": 125, "teams": ["frc1517", "frc558", "frc1991"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 86, "videos": [{"type": "youtube", "key": "68gt0YvoAmU"}], "time_string": "5:05 PM", "set_number": 1, "key": "2014necmp_qm86", "time": "1397250300", "score_breakdown": null, "alliances": {"blue": {"score": 202, "teams": ["frc3525", "frc237", "frc4564"]}, "red": {"score": 172, "teams": ["frc1519", "frc4048", "frc3461"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 87, "videos": [{"type": "youtube", "key": "Uqh5jEynRGA"}], "time_string": "9:30 AM", "set_number": 1, "key": "2014necmp_qm87", "time": "1397309400", "score_breakdown": null, "alliances": {"blue": {"score": 130, "teams": ["frc246", "frc125", "frc69"]}, "red": {"score": 230, "teams": ["frc2168", "frc3930", "frc2064"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 88, "videos": [{"type": "youtube", "key": "eTk7i2bDagk"}], "time_string": "9:37 AM", "set_number": 1, "key": "2014necmp_qm88", "time": "1397309820", "score_breakdown": null, "alliances": {"blue": {"score": 79, "teams": ["frc177", "frc172", "frc4909"]}, "red": {"score": 316, "teams": ["frc195", "frc716", "frc811"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 89, "videos": [{"type": "youtube", "key": "YPWh5LFkz4E"}], "time_string": "9:44 AM", "set_number": 1, "key": "2014necmp_qm89", "time": "1397310240", "score_breakdown": null, "alliances": {"blue": {"score": 95, "teams": ["frc4761", "frc4958", "frc175"]}, "red": {"score": 123, "teams": ["frc1735", "frc1517", "frc319"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 9, "videos": [{"type": "youtube", "key": "XFMHYhrOQLU"}], "time_string": "3:26 PM", "set_number": 1, "key": "2014necmp_qm9", "time": "1397157960", "score_breakdown": null, "alliances": {"blue": {"score": 147, "teams": ["frc3930", "frc3461", "frc1735"]}, "red": {"score": 86, "teams": ["frc2064", "frc4925", "frc138"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 90, "videos": [{"type": "youtube", "key": "sxu1_xTETRI"}], "time_string": "9:51 AM", "set_number": 1, "key": "2014necmp_qm90", "time": "1397310660", "score_breakdown": null, "alliances": {"blue": {"score": 145, "teams": ["frc2877", "frc2084", "frc1100"]}, "red": {"score": 146, "teams": ["frc1073", "frc237", "frc58"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 91, "videos": [{"type": "youtube", "key": "r0xVIAj7yAw"}], "time_string": "9:58 AM", "set_number": 1, "key": "2014necmp_qm91", "time": "1397311080", "score_breakdown": null, "alliances": {"blue": {"score": 194, "teams": ["frc246", "frc228", "frc4908"]}, "red": {"score": 150, "teams": ["frc3467", "frc4925", "frc61"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 92, "videos": [{"type": "youtube", "key": "sTX3u1i6HPc"}], "time_string": "10:05 AM", "set_number": 1, "key": "2014necmp_qm92", "time": "1397311500", "score_breakdown": null, "alliances": {"blue": {"score": 150, "teams": ["frc177", "frc166", "frc69"]}, "red": {"score": 140, "teams": ["frc131", "frc125", "frc4909"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 93, "videos": [{"type": "youtube", "key": "DYZcpyDPFRU"}], "time_string": "10:12 AM", "set_number": 1, "key": "2014necmp_qm93", "time": "1397311920", "score_breakdown": null, "alliances": {"blue": {"score": 109, "teams": ["frc999", "frc3461", "frc172"]}, "red": {"score": 98, "teams": ["frc2648", "frc2067", "frc558"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 94, "videos": [{"type": "youtube", "key": "eX12jFiE0lw"}], "time_string": "10:19 AM", "set_number": 1, "key": "2014necmp_qm94", "time": "1397312340", "score_breakdown": null, "alliances": {"blue": {"score": 82, "teams": ["frc133", "frc2168", "frc178"]}, "red": {"score": 186, "teams": ["frc4761", "frc195", "frc1153"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 95, "videos": [{"type": "youtube", "key": "GU1VEmDzrEc"}], "time_string": "10:26 AM", "set_number": 1, "key": "2014necmp_qm95", "time": "1397312760", "score_breakdown": null, "alliances": {"blue": {"score": 187, "teams": ["frc4473", "frc3525", "frc176"]}, "red": {"score": 173, "teams": ["frc1058", "frc138", "frc811"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 96, "videos": [{"type": "youtube", "key": "QI3HZq3EJGA"}], "time_string": "10:33 AM", "set_number": 1, "key": "2014necmp_qm96", "time": "1397313180", "score_breakdown": null, "alliances": {"blue": {"score": 119, "teams": ["frc716", "frc1099", "frc3930"]}, "red": {"score": 225, "teams": ["frc1735", "frc4055", "frc4048"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 97, "videos": [{"type": "youtube", "key": "CjXDc8BT6pU"}], "time_string": "10:40 AM", "set_number": 1, "key": "2014necmp_qm97", "time": "1397313600", "score_breakdown": null, "alliances": {"blue": {"score": 225, "teams": ["frc230", "frc2064", "frc78"]}, "red": {"score": 162, "teams": ["frc5122", "frc1519", "frc1991"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 98, "videos": [{"type": "youtube", "key": "jnzHmSjlWgg"}, {"type": "youtube", "key": "AWLJ25XyrOc"}], "time_string": "10:47 AM", "set_number": 1, "key": "2014necmp_qm98", "time": "1397314020", "score_breakdown": null, "alliances": {"blue": {"score": 136, "teams": ["frc61", "frc1100", "frc177"]}, "red": {"score": 206, "teams": ["frc4564", "frc319", "frc178"]}}, "event_key": "2014necmp"}, {"comp_level": "qm", "match_number": 99, "videos": [{"type": "youtube", "key": "JA4q_E9e-L0"}, {"type": "youtube", "key": "_h47BURAm3U"}], "time_string": "10:54 AM", "set_number": 1, "key": "2014necmp_qm99", "time": "1397314440", "score_breakdown": null, "alliances": {"blue": {"score": 110, "teams": ["frc4958", "frc3461", "frc2084"]}, "red": {"score": 260, "teams": ["frc4908", "frc125", "frc1153"]}}, "event_key": "2014necmp"}, {"comp_level": "sf", "match_number": 1, "videos": [{"type": "youtube", "key": "pZH5eA-YVxk"}], "time_string": "2:42 PM", "set_number": 1, "key": "2014necmp_sf1m1", "time": "1397328120", "score_breakdown": null, "alliances": {"blue": {"score": 126, "teams": ["frc716", "frc811", "frc78"]}, "red": {"score": 178, "teams": ["frc5122", "frc558", "frc195"]}}, "event_key": "2014necmp"}, {"comp_level": "sf", "match_number": 2, "videos": [{"type": "youtube", "key": "VwcQspvplMw"}], "time_string": "2:54 PM", "set_number": 1, "key": "2014necmp_sf1m2", "time": "1397328840", "score_breakdown": null, "alliances": {"blue": {"score": 116, "teams": ["frc716", "frc319", "frc78"]}, "red": {"score": 189, "teams": ["frc558", "frc195", "frc5122"]}}, "event_key": "2014necmp"}, {"comp_level": "sf", "match_number": 1, "videos": [{"type": "youtube", "key": "tSEMwB4-NN8"}], "time_string": "2:48 PM", "set_number": 2, "key": "2014necmp_sf2m1", "time": "1397328480", "score_breakdown": null, "alliances": {"blue": {"score": 209, "teams": ["frc4055", "frc230", "frc177"]}, "red": {"score": 111, "teams": ["frc2168", "frc3525", "frc228"]}}, "event_key": "2014necmp"}, {"comp_level": "sf", "match_number": 2, "videos": [{"type": "youtube", "key": "DIUnjGEroec"}], "time_string": "3:00 PM", "set_number": 2, "key": "2014necmp_sf2m2", "time": "1397329200", "score_breakdown": null, "alliances": {"blue": {"score": 173, "teams": ["frc230", "frc177", "frc4055"]}, "red": {"score": 127, "teams": ["frc3525", "frc228", "frc2168"]}}, "event_key": "2014necmp"}]%
Last edited by plnyyanks : 05-03-2015 at 11:28. Reason: Forgot you could pass X-TBA-App-Id as GET param |
#21
Re: OPR
Actually, the X-TBA-App-Id can be set as a URL param. Example: http://www.thebluealliance.com/api/v...ugene:test:v01 Edit: Phil ninjaed my ninja. Last edited by Eugene Fang : 05-03-2015 at 11:32. |
#22
Re: OPR
I replaced "2014necmp" with "2015inind" and examined the resulting data... and the "score breakdown" doesn't appear to include coopertition, tote, or container. Am I doing something wrong, or is the shiny new 2015 FRC API not providing that data? Last edited by Ether : 05-03-2015 at 12:53. |
#23
Re: OPR
Re: OPR
So no Twitter data for 2015, and no per-match scoring categories in the API. Very un-inspiring for the stats mavens :-( I am presently listening to the WMV audio recording to try to understand how such a decision was arrived at. |
#25
Re: OPR
Any thoughts this year on "Modified" OPR? Looking at competition scores, I am a bit inclined to divide the Co-Op portion of the points in half. I would put this similar to 2012 whee you had to add points for the Co-Op bridge. In this scenario, both alliances have to bring some Co-Op to the middle in order to get the points.
I can definitely see where component OPR (RCs, Co-Ops, Totes,...) would be powerful this year if you do not have scouting. |
#26
Re: OPR
![]() I'll pay with 973 swag if someone does. |
#27
Re: OPR
Heck, I'll probably do it anyways. |
#28
Re: OPR
Re: OPR
Re: OPR
By my calculations, DPR this year is 83% fear factor and 17% taking-cans-in-auto*
*Results not scientific |
