Go to Post A great mentor guides without giving the answers, teaches through discovery, demonstrates without lecturing, provides support from backstage, observes without hovering, and leads by example. - dlavery [more]
Unread 05-03-2015, 21:24
microman1934 microman1934 is offline
AKA: Uday SHarma
FRC #4939 (Allspark9)
microman1934 is an unknown quantity at this point
Limit speed of 4 chassis CIM motors
Hi there,
I'm from team 4939 and for this year's competition, our robot turned out quite tall. So in order to decrease tipping of the robot, I was wondering if it was possible to limit the speed of the 4 chassis CIM motors.
Thank you,
Uday Sharma
Unread 05-03-2015, 21:27
Qmcdonn Qmcdonn is offline
FRC #2374
Qmcdonn is an unknown quantity at this point
Re: Limit speed of 4 chassis CIM motors
You could certainly do this in software by setting a multiplier for the speed to 0.5 or something like that. I do not know of any electrical way to achieve the same result.
Unread 05-03-2015, 21:30
DanielPlotas DanielPlotas is offline
FRC #1984 (Raider Revolution Robotics)
DanielPlotas will become famous soon enoughDanielPlotas will become famous soon enough
What language?
Sleep? What is that? A rare Pokemon?
Unread 05-03-2015, 21:46
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
You have a few ways to do this:
One way would to just multiply your inputs from the joystick by a constant, less than 1, and pass that value to your motor.Set() function.
Another way, would be to limit the actual speed of your robot. For this to work, you would need encoders on each side of the robot, to monitor your speed.
Then you have an if statement, comparing the current speed of your robot, to a predefined "maximum" speed. If you are approaching your maximum speed, lower the output of the motors by a certain amount.
I would suggest, for either solution, you have a toggle to turn it on and off. Maybe you will want to go full speed for some reason? Who knows.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 05-03-2015, 21:49
You may want to limit acceleration.
Unread 05-03-2015, 21:52
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
http://thinktank.wpi.edu/article/140
If you are underweight, you can also lower the center of gravity by adding ballast low in the robot.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 05-03-2015, 21:56
AKA: Uday SHarma
we are using java and we are underweight but by about 2 pounds
Unread 05-03-2015, 22:04
AKA: Steve Peterson
http://www.chiefdelphi.com/media/papers/2211 could be translated to Java fairly straightforwardly.
Unread 05-03-2015, 22:11
What motor controllers are you using for your drivetrain motors? CAN or PWM?
Unread 05-03-2015, 22:17
http://www.chiefdelphi.com/forums/sh...69&postcount=8
http://www.chiefdelphi.com/forums/sh...22&postcount=2
Unread 05-03-2015, 22:22
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Limiting acceleration using encoders would require writing some code to calculate the acceleration from the speed (just the change in speed divided by the elapsed time). I don't know of any libraries to do this, so unless you have some experienced programmers, you probably wouldn't want to attempt it at this late date.
On the other, hand, limiting the maximum value you send to the motors will reduce acceleration by itself. You can improve stability a bit more by combining this with a throttle change limiter - and that's rather easier. All you have to do is to determine what the maximum acceptable change in the throttle is for each poll of the joysticks and update of the motors. In java it would look like:
//in initializer
double maxSpeedDelta = 0.05; // larger values allow faster changes
// inside loop
//assumes that your current call looks like:
//     motor.set(joystick.getY())
newSpeed = joystick.getY(); // or your original argument to motor.set()
curSpeed = motor.getSpeed();
if (newSpeed > curSpeed + maxSpeedDelta)
     newspeed = curSpeed + maxSpeedDelta;
if (newSpeed < curSpeed - maxSpeedDelta)
     newspeed = curSpeed - maxSpeedDelta;
motor.set(newSpeed);
Unread 05-03-2015, 22:38
AKA: Matt B
FRC #1771 (1771)
I know what we used in previous years, on the cRIO using C++, we had a 2-speed transmission with automatic shifting, based on the speed, but we also used the timer class to prevent us from rapidly shifting from high to low gear within a certain period of time.
double time = GetTime();
double left_dist = leftSide.GetDistance();
double right_dist = -rightSide.GetDistance();
double left_rate = (left_dist - leftPrevDist) / (time- leftPrevTime);
double right_rate = (right_dist - rightPrevDist) / (time - rightPrevTime);
leftPrevDist = left_dist;
rightPrevDist = right_dist;
leftPrevTime = time;
rightPrevTime = time;
//printf("left: %f, right: %f, Speed! %f\n", left_rate, right_rate, absd((left_rate + right_rate) / 2));
if (!HighGear && absd((left_rate + right_rate) / 2) > 3.7) {
shift.Set(true);
HighGear = true;
} else if (HighGear && absd((left_rate + right_rate) / 2) < 2) {
shift.Set(false);
HighGear = false;
That's the relevant portion of what we did in 2011, and 2012. It was placed inside of our main tele-op loop.
The "shift" object was a solenoid, that shifted the pnuematic shifter in the gearbox.
While there probably isn't a library to do that, writing the code for it shouldn't be too difficult. (You could probably just modify that to do what you need it to...)
1771- Mentor (2015)
Unread 05-03-2015, 22:45
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
I'm driving this year and so we made a button that while held places the max output of all drive motors at 25% you could do something similar and keep you ability to use all power and the ability to go slow at the same time... The other thought I would have is possibly removing a 2 cims from your drivetrain If you are running 4 already. We dropped from 4 to 2 and still have more than enough speed. We also have a build up in acceleration and deceleration too.
Unread 05-03-2015, 23:05
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Oh, duh!
If you really want to limit acceleration, you can use the accelerometers built into the RoboRIO; just select the one oriented along the axis that you're driving, or a vector sum of them that points you that way. For example, if your RIO is laid out on a board 30 degrees from horizontal, with the USB end towards the front and elevated, your acceleration in the drive direction would be
driveAccel = accelYaxis.getAcceleration() * .866 + accelZaxis.getAcceleration() * 0.5;
Unread 05-03-2015, 23:19
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Also, what might help is limiting deceleration. I would make sure my motor controllers are set to coast and not brake, this way you don't decelerate as rapidly so that you have less tipping issues when stopping.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
