Go to Post FRC is about what we collectively make of it. - Tristan Lall [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 06-03-2015, 07:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Looking For T-Shirt Cannon Help.
Independent of the look and drive, a few safety and engineering tips:
  • No PVC. Use plumbing rated for air pressure. When PVC fails under air pressure, the shrapnel is terrible.
  • Relatively large pipes and hoses. Ours has 1-1/4" carrying air for 2 barrels, 1" after the split. The solenoid valve is 3/4", and if we were buying today, it'd be 1".
  • Relatively low pressure - 40-50 psi.
  • Large barrel - ours is 3" i.d. much easier to shoot with the low pressure/high flow.
  • Short burst of air: I think we settled on 30 ms; at 50 ms we sent t-shirts over the press box.
  • Offboard A/C compressor, large tank: I don't remember the numbers, but a 1 cfm compressor would have to run continuously unless you only shoot a couple of times a quarter.
  • plan for rain. We wound up putting our electronics inside a rubbermaid tote.
