Go to Post I'm always afraid of what the GDC will come up with... Their sanity is often questioned... :D - thefro526 [more]
Unread 06-03-2015, 00:15
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Limit speed of 4 chassis CIM motors
Originally Posted by jblay View Post
Also, what might help is limiting deceleration. I would make sure my motor controllers are set to coast and not brake, this way you don't decelerate as rapidly so that you have less tipping issues when stopping.
Yes tipping when abruptly getting off the throttle will also likely cause tipping. With 4 motors you can set one on each side to coast and one on each side to brake for a lower braking force. We did that on the rookie team I am working with this year and it has worked good in practice.
Personally I would remove a motor per side if it can be done w/o major disassembly.
Unread 06-03-2015, 00:16
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Absolutely. Deceleration is a form of acceleration, and I included it implicitly. The following line was intended to reduce deceleration, and putting the motor controllers in coast would prevent a sudden unintentional change.
Originally Posted by GeeTwo View Post
if (newSpeed < curSpeed - maxSpeedDelta)
     newspeed = curSpeed - maxSpeedDelta;
Unread 06-03-2015, 13:53
You may want to limit acceleration.
The suggestions previously given in the post quoted above can be used to limit acceleration/deceleration without using sensors (no wheel encoders required).
If you have wheel encoders and you want to create smooth accel/decel-controlled pre-planned motion in auto, you might try something like this:
http://www.chiefdelphi.com/media/papers/download/4312
Unread 06-03-2015, 14:10
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
We did a quick implementation of this approach a couple of weeks back. Limiting the rate that the joystick input can increase is an easy fix in code and does the job well. You can set different rate limits for each joystick axis (we have forward/back, strafing, and turning) to match the tipping geometry of the robot too.
Unread 06-03-2015, 14:13
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
You using Joysticks or gamepads for control?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
So I got my jacket back, but it turns out the "W" in WPI doesn't stand for that steak sauce I can't pronounce.
Play is for kids this is serious...
Unread 06-03-2015, 14:29
s_forbes's Avatar
The interface hardware doesn't get rid of the tall-tippy-robot issue; you can still inadvertently send the robot a command of "full speed ahead" whether you use a joystick, a gamepad, or a DDR dance mat.
Unread 06-03-2015, 14:33
Going to have to disagree in regards to gamepads or typical console controllers you can gain more control over movement (provided they are bound to the thumb sticks) by increasing the height of the thumbstick you need to accidentally make much larger movements. If you are using a joystick your out of luck though.
Unread 06-03-2015, 21:47
microman1934 microman1934 is offline
AKA: Uday SHarma
FRC #4939 (Allspark9)
microman1934 is an unknown quantity at this point
Talking Re: Limit speed of 4 chassis CIM motors
Thank you so much for the help guys, I just ended up doing this:
double rot = -stick.getX();
double speed = -stick.getY();
myRobot.arcadeDrive(rot*0.5, speed*0.5);
Unread 06-03-2015, 21:58
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Glad you found a solution.
I would suggest you throw that in a if-else statement though, making the half-speed your default speed:
if(stick.getRawButton(1))
myRobot.arcadeDrive(-stick.getX(),-stick.getY());
else
This way, if in the middle of a match, your driver decides that he or she needs full speed, they have the ability to do so.
Just a suggestion. Of course, you may already have it that way in the rest of your code!
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 15-03-2015, 21:52
AKA: Uday SHarma
Thanks for the idea, would the throttle work for that as well?
Unread 16-03-2015, 01:16
AKA: Matt B
FRC #1771 (1771)
Yes. You could set the throttle to act as a toggle switch...
I'm on my phone so I can't format this correctly and can only give some pseudo code.
If(stick.getThrottle () > 0)
myRobot.Drive (halfSpeedValues);
else if(stick.getThrottle <= 0)
myRobot.Drive (fullSpeedValues);
Remember the throttle on the joystick ranges from -1 to 1, so 0 will be in the middle.
1771- Mentor (2015)
Unread 16-03-2015, 01:19
Knufire Knufire is offline
Just remember, by implementing that throttle (we refer to it as a software shift), you lose both speed and torque. This shouldn't be an issue driving around on an open field, but things like noodles or carrying large stacks while driving with the throtte enabled could cause very poor drive performance.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 16-03-2015, 09:14
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Depending on your drive train characteristics, you may have trouble turning. This will be especially prevalent in tight spaces or next to a bump. It is just as bad (or worse, perception-wise) as flopping over on your face every match. Could you describe your drive train from a mechanical perspective?
Unread 16-03-2015, 11:18
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Why not just square the magnitude? Pseudo code for example.
double speed = -stick.getRawAxis(drive axis);
myRobot.arcadeDrive(rot, speed * Math.abs(speed));
This allows finer control at lower speeds (when joystick is reading 0.5 you will send 0.25 to the motors) but still allows full speed when the joysticks are at full throttle.
