Go to Post The MAINTENANCE of teams is just as important as the growth. Starting a new team is not always the answer. - Amanda Morrison [more]
Unread 06-03-2015, 08:54
stopyourself stopyourself is offline
FRC #2335 (Sargon)
stopyourself is on a distinguished road
Timing Autonomous with While Loops?
In the 2015 timed autonomous tutorial, found here: https://decibel.ni.com/content/docs/DOC-26295 NI uses wait loops to instruct the drive motors. My mentor who worked with me during build season is no longer coming to meetings, but he instructed me to NEVER use these because they're CPU hogs. The thought is giving me anxiety.
Is this the correct way? Is there an alternative?
2013-2016: Team 2335
Unread 06-03-2015, 09:39
Re: Timing Autonomous with While Loops?
They can be CPU hogs if used incorrectly.
The Wait call inside each one throttles the loop down and avoids sucking the life out of the CPU. So never use a While loop without a Wait.
So that example works as long as you make sure to use Waits.
There are several alternative styles that avoid the use of loops altogether, but Waits are still required to get your timing down.
Here is one alternative using a Flat Sequence Structure: http://www.team358.org/files/program...php#Autonomous
Unread 06-03-2015, 09:50
Slade Slade is offline
FRC #4471 (Spartrons)
Slade is an unknown quantity at this point
Well my question would be is what if your moving a motor and you want to stop it at a limit switch, how would you go about doing so without a while loop?
Unread 06-03-2015, 11:24
Loops are used/required a couple of places, such as Robot Main and Periodic Tasks.vi
User programs loop to keep working and checking for driver packets, changes of robot state (Disabled/Enabled/Teleop/Autonomous), etc.
If you have to check constantly to see if a limit switch is reached then a loop can be used (just always throttle it with a Wait). If the operation is commonly used both for Teleop and for Autonomous, then a loop in Periodic Tasks might be a better location for it.
Unread 06-03-2015, 11:25
Attach the limit switch to your motor controller. The motor controller firmware will stop the motor.
Unread 06-03-2015, 14:14
How would you go about putting the limit switch to the motor controller. I'm not exactly sure what you mean
Unread 06-03-2015, 14:32
FRC #2335 (Sargon)
I think...our limit switches are in DIO 6 and 7 on out bot. So instead plug it in to the motor controller? I think it would be on a breakout board like this for the Talon SRX: http://www.chiefdelphi.com/media/img...ee71979d_l.jpg
Unread 06-03-2015, 14:34
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
For the talon srx and jaguar you are able to use a limit switch and put embedded code to stop the motor when the limit switch is pressed. If you do not possess these motor controllers. You probably want to use a condition in your while loop to state that if the limit switch is pressed to stop the loop.
VEX & FRC Student Team Member #357 Royal Assault 2010-2014 "Dare Mighty Things"
2014-2019 Attending Drexel University Major:Electrical Enginnering
Unread 06-03-2015, 14:55
Talon SRX User's Guide; see pages 19 & 20:
http://www.crosstheroadelectronics.c...7s%20Guide.pdf
Jaguar Getting Started Guide; see pages 7 9 10 13 14 22
http://team358.org/files/electrical/MDL-BDC24_GSG.pdf
