| Thread Tools |
Rating:
Display Modes |
#16
Re: Which 3 robots would form the most overpowered alliance?
I'm thinking 1114 + 148 + ludicrous speed 2 RC bot
An auto, 148 can do a 3 tote auto (assuming they can get that working), and 1114 can try for a third RC, because I know they have some grabbing mechanism. I saw it in the GTR practice matches, but I don't know how fast it is. |
#17
From what I've seen, 3130/525/4215 averaged over 100 together. I feel like they should be taken into account.
#18
1114 is averaging more than 100 on their own.
#19
Welp. My bad. That's a lot more OP than what I had lined up.
#20
We still haven't seen the best of 148, so they're my #1 pick.
As of now, 1114 is the top landfill, so they're my #2 pick. knowing them, they will be able to grab 2 bins by champs, and it will likely be fast. The bin grabber I want necessarily must be the fastest. the best 4 bin grabber i've seen so far was 2848, but even if they were as fast as 3310 or 118, both of the latter teams were grabbing the side 2 bins and that torque on 2848's bot would have been... interesting. as long as a 2 bin grabber is as fast as a 4 bin and can grab the 2 on the side, the #1 alliance will be fine. I think champs winner will have 2 bots grabbing 2 totes each. In STL I think there will be a lot of unveiling of withholding allowance ramps and bin grabbers. |
#21
Even more than speed is power and ballast/traction - if designed and executed anywhere nearly as well, two robots grabbing 2 each will overpower one grabbing 4.
#22
3476 is able to put 18 (3 stacks on the scoring platform) in a match.
They chose to do 5 each instead to complement their partner. With a third partner who focuses solely on the step to grab RC's and place them on stacks, that is a viable option for 2 of the 3 members. I think the key question is what combination of teams can put up 200 points in a match? |
#23
1114: 20 (Auto)+3x42 Teleop 148: 3x42 Teleop |
#24
https://m.youtube.com/watch?v=2j49zpQjC_8 |
#26
In addition, 2 alliances that score well over 200+ in a match pitted against each other will have some negative effect going for the same step bins. |
#27
With eliminations going serpentine, this has huge ramifications in getting teams that are effective at RC bins in auto for teams lower in the alliance selection seedings. |
#28
you are absolutely right. But I think the point here is that you mention not needing a third partner for teams like 1114, 118, 987, 148, etc.... For teams that cant work that "magic", the third partner is essential and helps to equate what effectively took 2 of them to do. Of the teams we saw the past 2 weeks, what happens if an effective 4 bin step grabber is on the opposite alliance against them? |
#30
.25 seconds? what is this? the james may alliance?
