Go to Post Thanks, that clears things up a lot, and should probably have been obvious. - Branden Ghena [more]
Unread 05-03-2015, 23:49
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
pic: Banana for scale
Unread 05-03-2015, 23:51
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: Banana for scale
What's the big red button for? Are you using all of those buttons?
Unread 06-03-2015, 00:06
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
That's only 11 buttons; one of our early UI designs had about that many. We eventually simplified so we can get it on an xBox controller.
My guess (not that I think I'm right, but just making the point that you can use this many buttons) is that the five white buttons are for lift levels, the big red is cancel or all stop, lower right is "score" (lower the lift until it disengages, possibly sensed by current draw), lower left black is pick up a tote, top black is pick up an RC, and the greens are to place those pieces atop a tote, and maybe pick up the bigger stack.
Unread 06-03-2015, 00:40
audietron's Avatar
You are pretty close, I didn't think of "score" as a button, but now I might make that a thing, which would be opening both of our grabbers to release the stack.
The white buttons are levels. but a bit different. We programmed them for auto stacking. for example the bottom button will go to tote level 2 and drop down to the bottom tote and go back to level 2. second button does the same thing but for 3 to 2. the third button just lifts the totes to the level of the coop stack with one tote already on the step. the green and black buttons are for Manuel up-down on the elevator and in and out on our intake. The big red button is to open the intake because it fits in the palm really well and be able to reach the rest of the buttons. There are 2 more buttons around the side. one is a rocker switch for switching elevator speeds and the other opens our second grabber.
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 06-03-2015, 08:41
Jonathan Ryan's Avatar
Jonathan Ryan Jonathan Ryan is offline
FRC #0145 (T-rx 145)
Jonathan Ryan is an unknown quantity at this point
http://i.imgur.com/0fI0d16.png
Unread 06-03-2015, 10:12
Fields's Avatar
Fields Fields is offline
Classic
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
Originally Posted by Jonathan Ryan View Post
Hilarious!
Unread 06-03-2015, 14:46
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
Some may have missed the humor, but as a geologist, I truly appreciate the "banana for scale" reference. Thanks!
Unread 06-03-2015, 19:38
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
Also in case you missed it, bananas were used as scale objects on the field build assembly plans this year. See if you can find them all!
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 06-03-2015, 20:51
g_sawchuk's Avatar
g_sawchuk g_sawchuk is offline
Hmm.
AKA: Griffin Sawchuk
FRC #4476
g_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really nice
Wow, nice and slick driver station. I'm loving the big red button.
FRC 2013-2015 (K-Botics #2809)
VEX 2015 - 2016 (W.A.F.F.L.E.S. #4476)
FLL 2015 - ??? (MechMasters #16931)
FRC 2016 - ??? (W.A.F.F.L.E.S. #4476)
2016 Dean's List Finalist
My thoughts and ideas do not necessarily reflect those of my team.
Unread 08-03-2015, 17:19
chapman1's Avatar
Yeah, that's the "Easy" button, right? We need one of those as well.
Unread 08-03-2015, 17:28
Is that an FRC Standard Banana or an ANSI Standard Banana?
Unread 08-03-2015, 23:22
FRC #3573 (Ohms)
It's only an FRC Standard Banana if it meets all the rules in Section R and has an inspection sticker on it!
Dr. Bob
Unread 08-03-2015, 23:46
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
You probably think this is a joke, but I understand that the EU forbids "abnormally curved bananas".
