Go to Post Maybe Dean Kamen can appear in Levi's advertising? - David Brinza [more]
Unread 06-03-2015, 14:17
Skooks Skooks is offline
FRC #4388
Skooks is an unknown quantity at this point
Drive Systems
I've been noticing the many different styles of drive systems, such as tank, mecanum, H-drive, and swerve. I was wondering what other people have seen and built for there robots.
Unread 06-03-2015, 16:16
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
Re: Drive Systems
Tank is the basic and, in my opinion, the best drive for most teams. It is simple and effective. I believe that even in RR tank is superior. This is most often a 6 wheel, dropped center. Sometimes you will see an 8 wheel dropped center. It provides the best traction so you get pushing power and acceleration.
The main disadvantage of tank is the inability to move sideways.
Mecanum is often used to move sideways. I am not a programmer, but from what I understand it requires rather complex programming. When done well, it is easy to use, but can be easily messed up. It provides poor tration and is easily pushed around.
H drive uses omni wheels mounted perpendicular to each other. Omni wheels hame small rollers that allow them to slide sideways, so there is a set of wheels for each direction. It has the same low traction as mecanum.
Swerve is often considered the best overall drive. It has great traction and has sideways/diagonal/any direction movement. Each wheel is mounted on a pivot so it turns beneath the bot. These are very difficult to build but are very versatile.
One of the most interesting drives I have driven is one developed by team 967. This 9 wheel drive used an 8 wheel dropped center base, with one wheel mounted perpendicular and on a piston. When the piston is activated the wheel is forced down and the back end of the bot lifts off the ground, so it is supported by the two front wheels and the 9th wheel in the center of the bot. This allows great traction in regular tank mode and the ability to move sideways. I believe in 2014 Team Titanium utilized this concept in their drive base.
What else is out there?
Unread 06-03-2015, 16:19
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: Drive Systems
1114 is using kiwi drive this year. Three omnis set in a triangle.
Unread 06-03-2015, 16:55
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Re: Drive Systems
lots of incorrect and exaggerated information in here. since the OP wasn't asking about each drive and rather what is out there, I won't turn this into thread 8,398 like this.
There were a few Killough (4 wheel omni). Here's one
At least one octocanum.
And don't forget the... kiwi swerve? not sure what overclocked is calling this.
Unread 06-03-2015, 17:01
SJaladi's Avatar
SJaladi SJaladi is offline
Mechanical Mentor
AKA: Sarath Jaladi
FRC #1923 (The MidKnight Inventors)
SJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond repute
Re: Drive Systems
Team 1923 built a custom drivetrain this year that incorporates some of the best qualities of different variations of tank drive. It is constructed with C-channel like a standard tank drive, but similarly to a WCD one wheel on each side is direct driven by the gearbox allowing for us to drive to some extent even if all the chains fail. Additionally to prevent damage to the chain we run all the chain within the c-channel. The drivetrain has 5 wheels on each side (3 colsons in the center and 2 omnis out at the ends). It does not use a drop center but rather relies on the omnis out at the ends to facilitate turning with minimal scrub. We chose to use 5 wheels on each side so that we could use 4" wheels and still maintain complete control while crossing over and driving on the scoring platform.
Because we lack extensive machining resources we designed this drivetrain to be built using only a drill press and a band saw through extensive usage of VexPro VersaFrame.
Unread 06-03-2015, 17:50
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Re: Drive Systems
Here is what we call the HI Drop Drive.
The pneumatic actuated center wheels allow us enough clearance to drive over the bump and will center the robot while driving the length for ease of scoring..
Depending on how you look at it, it is either an "H" or "I", since we are from Hawaii we went with it..
This is an early picture of the system.
http://www.chiefdelphi.com/media/img...4205589a_l.jpg
More to come as the media team gets it to me..
Good luck to everyone.
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Division TBD | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 06-03-2015, 17:55
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
We did something similar on our drive this year as well.
Unread 06-03-2015, 17:57
Re: Drive Systems
Do those center wheels scrub a lot when you rotate?
Unread 06-03-2015, 19:26
dradel's Avatar
Nope look at the pic closer... Air cylinders lift them off the floor. We weren't sure how it would work during competition, but got us to finals last weekend in Waterbury.
Unread 06-03-2015, 20:47
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Drive Systems
We did Omni H with center suspension (Early pic while figuring suspension..which makes a huge difference took us 4 weeks to figure it out)
https://fbcdn-sphotos-a-a.akamaihd.n...a0e94dd5d6f547
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 06-03-2015, 20:51
Data Nerd
FRC #0079
Re: Drive Systems
It's just a 3 wheel swerve. There've been a lot of them. (67 - 05, 148 - 08, 16 - Many years)
Unread 06-03-2015, 20:54
g_sawchuk's Avatar
g_sawchuk g_sawchuk is offline
Hmm.
AKA: Griffin Sawchuk
FRC #4476
g_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really nice
Re: Drive Systems
I saw some hexagonal robots last year (mainly vacumn bots for some reason). Those were interesting to say the least. My favourite drive this year so far is 1114's kiwi/crab drive.
FRC 2013-2015 (K-Botics #2809)
VEX 2015 - 2016 (W.A.F.F.L.E.S. #4476)
FLL 2015 - ??? (MechMasters #16931)
FRC 2016 - ??? (W.A.F.F.L.E.S. #4476)
2016 Dean's List Finalist
My thoughts and ideas do not necessarily reflect those of my team.
Unread 07-03-2015, 23:16
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Re: Drive Systems
Hey! Don't forget us. Don't have a video of it on the actual bot, just the drive train for now.
Unread 08-03-2015, 04:45
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Drive Systems
We've used a 6WD and a 4WD successfully in my time. The year before I joined they made a robot with an 8WD and 8020, which still runs today.
Over the summer we may experiment with swerve drives if we get the necessary manufacturing resources to make a good one.
Unread 08-03-2015, 23:15
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Drive Systems
I put together a lesson on drive systems for our (boreal) summer 2014 "robocamp". Trying to classify drives, I came up with something like:
  • Skid-steer/tank (2n+4 wheels, drop center when n>0, optional shifter)
  • Linkage drives
    • Two-wheel steering (automotive style, rarely if ever seen in FRC, but I wanted to cover it in the camp if only to explain why it is rarely used.)
    • Crab drive (all wheels drive same direction and speed)
    • X drive (I made up this name, but it has 4 wheels, left-rear and right-front rotate together and mirror left-front and right-rear)
    • Fire truck steering (independent 2-wheel steering on front and rear wheels, again rarely used)
  • Holonomic wheel drives (I focused here on the wheels with rollers, not whether it was truly holonomic)
    • Omni tank (a 4-wheel skid steer with omni wheels)
    • H-drive (omni tank plus a transverse-mounted strafe wheel)
    • Killough (that is 4 omni wheels in a diamond configuration, not Killough's drive)
    • Mecanum
    • Kiwi (3 omni wheels whose axle lines cross at the CoG, a lot closer to Killough's drive)
  • Swerve drives (I described 3 and 4 wheel setups, and explained that other configurations were possible)
  • Articulated drives
    • Holonomic wheel hybrids
      • Octanum (includes butterfly and grasshopper)
      • Nonanum
    • Crab/lobster (dual skid/steer - alternate drive is transverse to main drive)
    • Articulated shifter (different size wheels or gear ratios on different drive wheels)
    • Ladder drive (as shown above, though I did not include it this past summer, but will add this year)
I did not include a monobot, or what I've personally called a "dizzy drive" (crab with a big steerable lazy susan for the "upper robot"). I'm sure there are other possibilities.
