Go to Post p.s. note that 5-1/2 hours in the car with your daughter on the way to IRI is NOT the same as 10 hours in the van with seven members of Team 116 on the way to IRI. One is a wonderful familial experience, the other is an opportunity to go insane. - dlavery [more]
Unread 03-07-2015, 08:02 PM
Technette Technette is offline
FRC #2404
Technette is an unknown quantity at this point
Re: Joystick not initialized Error
Thank you for responding GeeTwo!
I did have two methods referring to the same variable.
Now I just get an error for the setDefaultCommand still.
It appears that the joystick is not properly initialized.
I get the following errors now:
Description Resource Path Location Type
The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetPOV' OI.cpp /GrabNGo/src line 30 Code Analysis Problem
The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetRawAxis' OI.cpp /GrabNGo/src line 30 Code Analysis Problem
The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetRawButton' OI.cpp /GrabNGo/src line 30 Code Analysis Problem
The type 'Lift_Down' must implement the inherited pure virtual method 'ITableListener::ValueChanged' OI.cpp /GrabNGo/src line 41 Code Analysis Problem
The type 'Lift_Up' must implement the inherited pure virtual method 'ITableListener::ValueChanged' OI.cpp /GrabNGo/src line 39 Code Analysis Problem
