Go to Post Part of FRC is to introduce you to how engineering is in real life: you can't use a redo card if you're landing something on the moon. - The other Gabe [more]
Unread 07-03-2015, 18:47
Technette Technette is offline
FRC #2404
Technette is an unknown quantity at this point
Angry Joystick not initialized Error
Hi,
I'm using one joystick and when I added it, I'm getting an error that the Joystick was not initialized in the constructor.
I'd really appreciate help. I also had to comment out the default command because of the errors it was causing.
OI::OI() {
	// Process operator interface input here.
        // BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTORS
	joystick = new Joystick(0);
        // SmartDashboard Buttons
	SmartDashboard::PutData("Drive_Arcade", new Drive_Arcade());
	SmartDashboard::PutData("Autonomous Command", new AutonomousCommand());
	SmartDashboard::PutData("Lift_Up", new Lift_Up());
	SmartDashboard::PutData("Lift_Down", new Lift_Down());
	SmartDashboard::PutData("Drive_To_Platform", new Drive_To_Platform());
	SmartDashboard::PutData("Backup", new Backup());
    // END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTORS
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=FUNCTIONS
Joystick* OI::getJoystick() {
	return joystick;
Unread 07-03-2015, 18:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Joystick not initialized Error
Is joystick declared so that these two methods are actually referring to the same variable, and is it something which is a valid type for Joystick *? If not, initializing the one will not initialize the other.
Unread 07-03-2015, 20:02
FRC #2404
Thank you for responding GeeTwo!
I did have two methods referring to the same variable.
Now I just get an error for the setDefaultCommand still.
It appears that the joystick is not properly initialized.
I get the following errors now:
Description Resource Path Location Type
The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetPOV' OI.cpp /GrabNGo/src line 30 Code Analysis Problem
The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetRawAxis' OI.cpp /GrabNGo/src line 30 Code Analysis Problem
The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetRawButton' OI.cpp /GrabNGo/src line 30 Code Analysis Problem
The type 'Lift_Down' must implement the inherited pure virtual method 'ITableListener::ValueChanged' OI.cpp /GrabNGo/src line 41 Code Analysis Problem
The type 'Lift_Up' must implement the inherited pure virtual method 'ITableListener::ValueChanged' OI.cpp /GrabNGo/src line 39 Code Analysis Problem
Unread 07-03-2015, 20:28
nandeeka's Avatar
nandeeka nandeeka is offline
FRC #1868
nandeeka is on a distinguished road
Did you try indexing?
Unread 07-03-2015, 21:47
FRC #2404
Wink Re: Joystick not initialized Error
Yes,
I tried indexing. I am going to pull up the documentation to see how to correctly implement it.
Unread 08-03-2015, 09:55
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
These three are the most obvious issue:
Joystick is a wpilib class, so it should inherit everything from GenericHID, with implementations.
From the opening paragraph in the javadoc for Joystick in WPIlibj (I'm assuming C/C++ is similar):
Handle input from standard Joysticks connected to the Driver Station. This class handles standard input that comes from the Driver Station. Each time a value is requested the most recent value is returned. There is a single class instance for each joystick and the mapping of ports to hardware buttons depends on the code in the driver station.
Three things I can think of to check:
  1. Is Joystick in this context wpilib.Joystick, or something else?
  2. Are you using a controller which does not match the description of the Joystick class?
  3. Did you include configuration/code to map the joystick ports to hardware buttons in your Driver Station?
Unread 08-03-2015, 20:25
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
"Joystick was not initialized in the constructor" is not an error. It is a warning. You should still be able to build (FRCUserProgram file should still appear under Binaries).
I can reproduce this by creating a new Commandbased C++ project, adding a Joystick * joystick to IO header and heap allocating it in the constructor just as you have.
Clean the project, rebuild the index, right-click delete the errors and warnings in the "Problems" Tab, then full-rebuild.
At this point the warning will be gone.
You will will still see this warning...
libstdc++.so.6, needed by :\Users\ozrie_000/wpilib/cpp/current/lib\libFRC_NetworkCommunication.so.1.5.0
... that's ok, you should still get a new FRCUserProgram executable.
Unread 08-03-2015, 20:43
FRC #2404
Thank you for responding Ozrien!
After rebuilding I get the following error:
Program "make" not found in PATH GrabNGo C/C++ Problem
Unread 08-03-2015, 20:48
FRC #2404
Smile Re: Joystick not initialized Error
I do see that the build did complete though! Wooo Whooo!
Now I can help the team work on the autonomous modes.
