Go to Post I fear not the drive team who has practiced 10,000 defenses once, but I fear the drive team who has practiced one defense 10,000 times. -Bruce Lee - bEdhEd [more]
Unread 07-03-2015, 20:25
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Adjusted Robot Ranking
Hello CD,
While watching the last few weeks of competitions, I came up with an idea for a quick ranking system that would, using a very simple equation, estimate a robot's value in eliminations, for scouting purposes. The two goals of this ranking system would be to reduce the value of the Co-Op stacks to that of a grey tote stack, and also eliminate the value of the litter, as they're not really, for the most part, scored by the robot. Here's the equation:
ARR=((.2*COOP)+AUTO+TOTE+CONTAINER)/MP
I made a google doc for the Reading District Event that takes copied and pasted data from here and calculates their ARR rank and the difference between their Qual Rank and their ARR to sift out the teams who are ranked highly because of litter and co-op stacks.
What do you guys think about this method of ranking for scouting?
Thank you!
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 07-03-2015, 21:25
rwodonnell rwodonnell is offline
AKA: Rick O'Donnell
FRC #2876 (Devilbotz)
rwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to behold
Re: Adjusted Robot Ranking
Well I like it - after all, it moves us up 4 places!
By the way, our team sympathized with you guys in match 32 today. Like us two matches earlier, I imagine you felt something like a groom left at the altar. We had the same experience two matches earlier, putting 3 yellow totes on the step with what we thought was an agreement to finish on the other side, but it didn't happen. That coopertition thing can be tricky.
Unread 07-03-2015, 23:32
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
Are points not points? If they have an HP that hits litter points that's still valuable. Non robot scoring is fine, and some robots may be designed to do litter.
Co-op reduction is fine to reduce.
And remember folks, it's an estimation. Nothing beats real scouting
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
Unread 08-03-2015, 10:27
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Good solution; if you put yellow totes on the step, you could put gray ones on the platform. The wrinkles I can think of are:
  • If an auto tote stack was scored, only one of the yellow totes should score, as there's now only one action required to move the whole stack to the step.
  • If an auto stack is deposited anywhere near the landmark and transferred to the step, and the team can't adjust this for playoffs, you might have to move the auto stack out of the way in playoffs.
I'd leave these in. It doesn't matter if the points are scored by the robot or the HP or the two working together. Points is points.
Unread 08-03-2015, 12:50
As Brennan said, this in absolutely no way replaces eyes on the field watching matches, and this algorithm is made to judge the robot only. The reason I left litter out is that, generally, alliances will only have one person throwing litter, rather than the three robots that are out on the field scoring points. Therefore, if HP duties are split evenly in a 12 match per team event, that means a given team's HP only throws noodles in four matches. I'm making a lot of assumptions here, but you get my drift- I believe that the total Litter score is even less reliable of a method of judging a team than the other point totals.
Unread 08-03-2015, 14:24
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Calculated contribution to winning litter (CCWL) might be useful. Of course, watchful eyes actually following matches will be more reliable.
Richard Wallace
since 2003
Unread 08-03-2015, 20:41
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Personally don't think any auto ranking system will be good for this years gameplay..too many variables and changes in scoring. I certainly take then all with a grain of salt.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 08-03-2015, 21:50
SoccerTaco's Avatar
SoccerTaco SoccerTaco is offline
Mentor, Volunteer
AKA: Steve Parham
FRC #3824 (roHAWKtics)
SoccerTaco will become famous soon enough
...The reason I left litter out is that, generally, alliances will only have one person throwing litter...
I like the coopertition reduction idea. I'm going to mention that to our scouting team.
But I agree with others that litter should be left in. Litter points in elims count exactly the same as they do in quals. Also, litter scores in containers, not just from being thrown.
If a team makes 2 complete 42 point stacks, for 84 points, 12 of those points will be from litter in the container. That's 14% of their points.
Unread 08-03-2015, 22:11
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
.. generally, alliances will only have one person throwing litter, rather than the three robots that are out on the field scoring points.
The real point is that the performance of an alliance is highly nonlinear this year. You certainly don't need three robots working the tote chutes, nor three getting RCs off the step, nor three mining the landfill. As such, if your team includes one of the best litterers at the event, yes, zero this out for alliance selections. Likewise, if your first pick has a great litterer, don't look for it in the second round. Heck, if you expect to get all four RCs and stuff all seven with noodles and stack them, the litterer doesn't matter nearly so much. The bottom line is that, if your alliance doesn't have someone who can get the great majority of the litter across the field, you're better off not throwing at all, or at least waiting until the second half of the match.
