Go to Post I'm not the only one confused. Perfect. - MikLast [more]
Thread Tools Rating: Thread Rating: 38 votes, 5.00 average. Display Modes
Unread 08-03-2015, 19:47
xNovax's Avatar
xNovax xNovax is offline
AKA: Aaron
FRC #3710 (Cyber Falcons)
xNovax is an unknown quantity at this point
[Help] Problems with Encoders and PID Control
I have run into an issue with an encoder on my teams robot, the encoder was working fine at the beginning of the day but as the day went on the encoder stopped working. Now we cannot get any encoders to work on the robot. Here is what we have tried: Replace the encoder with a new one, change the wire connection to the encoder, changing the DIO port for the encoder, triple checking our code, testing the DIO ports with a limit switch(successful) and power cycling the robot and our drive station.
I have become stumped with what is causing the issue. My mentors seem to think that it is something to do with software but I have checked the code multiple times.
Here is our code: https://github.com/Cyberfalcons/robot2015
Here is the class where the encoder is being used: https://github.com/Cyberfalcons/robo...nElevator.java
Any help is greatly appreciated!
Unread 08-03-2015, 19:53
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Re: [Help] Problems with Encoders and PID Control
I once had a similar problem where I couldn't get a reading out of our lift encoder. It turned out that the limit switch at the bottom was constantly on, so the encoder kept getting reset to zero.
I see this in your code, which looked similar to what I was doing:
else if (getBottom() == true) {
			resetEncoder();
Just an idea
Head Programmer / Driver
Unread 08-03-2015, 20:01
xNovax's Avatar
AKA: Aaron
That should only cause problems if we try to go down when the limit switch is engaged. We have tried hand spinning an encoder that is not attached to any subsystems and it still does not read anything but 0.
Unread 08-03-2015, 20:06
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Remember all DIOs return true if nothing is attached to them. So if the limit switch came unplugged or went bad, the encoder would be constantly resetting. So if you were trying to test the encoders but had all other DIOs unplugged, the encoder would constantly be getting reset, unless you commented out the reset code.
Team 4488 - Mentor 2013-2016
Unread 08-03-2015, 20:08
xNovax's Avatar
AKA: Aaron
We tested the limit switches to make sure they were working before we started messing with other stuff.
Time to get out the voltmeter.
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
A quadrature encoder will do weird things if both channels are not plugged in. Pretty sure it would read zero. Are both channels plugged in to DIO ports?
Also, did you try inintializing the encoder as a digital input and watching the true/false flash?
Unread 08-03-2015, 20:10
xNovax's Avatar
AKA: Aaron
We checked the connections in both of the wires we tested with.
Unread 08-03-2015, 20:11
xNovax's Avatar
AKA: Aaron
We made sure that both channels were plugged in, I will try the digital input thing once I have access to the robot.
Unread 08-03-2015, 20:15
How did you check them?
Unread 08-03-2015, 20:16
xNovax's Avatar
AKA: Aaron
Beep test (Sorry I don't know the technical term)
Unread 08-03-2015, 20:22
What's a beep test?
Unread 08-03-2015, 20:25
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
What's a beep test?
It's a continuity test, I believe.
Unread 08-03-2015, 20:28
You can't measure volts with a continuity tester.
Unread 08-03-2015, 20:59
AKA: Sparks
How would you use the voltmeter to tell whats wrong with the encoder? Just to see that it is indeed getting power and common? The pulses on the output channels will probably be much too fast to be read without an oscilliscope, unless the encoder has really low resolution I suppose. Carry on.
