Go to Post Now stop reading CD, do your homework, eat your peas, brush your teeth, and go to bed. Any time you spend speculating as to what Dave's ravings might mean is completely wasted. - Richard Wallace [more]
Unread 09-03-2015, 00:52
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Text-based Autonomous POC
Yeah, but the root of this problem seems to be the lack of documentation on the libraries, but to the OP keep up the good work and figure out some way to port this onto simple!
Unread 10-03-2015, 14:52
Defensoft3585 Defensoft3585 is offline
Programming Captain
AKA: The Defenestrator
FRC #3585 (Rogue Robots of 4H)
Defensoft3585 is on a distinguished road
Originally Posted by MrRoboSteve View Post
One thing to think about when designing a programming language like this (whether or not you think so, you're designing a programming language) is what use cases are in and what are out.
For example, will you allow:
variables No, this is supposed to be simple.
subroutines No, this is supposed to be simple.
logic (if/then/else) No, this is supposed to be simple.
looping No, this is supposed to be simple.
Another example -- what support will you have for detecting errors in the script and communicating them to the user? If you read the code, it already has this feature.
Once you decide what is in and what is out, you should compare the effort to do what your scripting language does to the effort needed to write the same thing in the underlying language (Java, in this case). These examples will be good to use when you're trying to convince people that what you've developed makes things so much simpler that they'll learn your language in addition to Java.
My replies in bold. People seem to mistake this for an entire language - this is a data format that anyone could feasibly understand.
Unread 10-03-2015, 15:07
Programming Captain
Thank you very much! And WPILib does have documentation. For me it's in C:\Users\<username>\wpilib\java\current\javadoc\in dex.html.
