Go to Post The minute humans begin depending on robots for anything in their daily routine is .... well, let's just hope people "in it for the lulz" don't take notice. - JesseK [more]
Unread 06-03-2015, 16:49
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Programmers on the Drive Team
Why did you guys decide on limit switches instead of encoders?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 06-03-2015, 17:24
Lij2015's Avatar
Lij2015 Lij2015 is offline
I like turtles
AKA: Elijah Steele
FRC #2363 (Triple Helix)
Lij2015 has a spectacular aura aboutLij2015 has a spectacular aura about
Send a message via MSN to Lij2015
I have a score button(for placing the totes) and I have control of the roller mechanism. I usually also put an inverse throttle trigger on there for myself(This was super useful last year)
Programming to your needs specifically is super useful
Alumni turned volunteer!
2016 Chesapeake District volunteer, Scorekeeper/Game announcer.
Team 2363 Proud Alumni, Programmer/Driver 2013, 2014, 2015(Captain)
2016 Northern Virginia Winners (1418 and 2421)
2016 Hampton Roads Finalists(1885 and 5954)
2015 Chesapeake Regional Winners(1690 and 4050)
2015 Virginia Regional Winners(384 and 1610)
2014 Chesapeake Regional Winners(1629 and 623)
2013 Virginia Regional Finalists (3015 and 2053)
Unread 09-03-2015, 11:49
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Originally Posted by GeeTwo View Post
We have limit switches on our lift as well, actually four. We used some long-lever switches from Jameco and bent the arms up about 45 degrees one needle-nose-plier width beyond the end of the switch, and down about 90 degrees another plier width down. It ended up looking something like this:
   _________/\
We mounted this inside our lift channel beside the place where our lift plate passed. As the plate reaches the switch, it pushes back on that 90 degree bend, activating the switch. The long lead at the end keeps the lift from jamming the switch on the return stroke, which was a problem we had with rollers that weren't precisely aligned.
Edit: I attached a photo of how our roller limit switches were mounted.
Interesting. That's an eloquent solution, our original idea was something like that. Thank you!
Unread 09-03-2015, 12:15
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Three words: magnetic limit switches. Switched (rim-shot) to these in 2013 and have never looked back.
http://www.mcmaster.com/#magnetic-switches/=w8hmkk
We used numerous magnetic limit switches, supplemented with encoders, to pre-program positions for our tote collector and to implement safety-interlocks on most of our robot's mechanisms.
Unread 09-03-2015, 12:28
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
i am primary driver this year, (not a programer) Really the only thing that our programer aded to the drive is a 50% slowdown on the drive for when getting rcs of the step. We are not even using a gyro on our mecnum drive this year. We had one that worked but i felt that it was just not needed. It almost made the drive feel like it was unnatural. The drive is so much more fluid without it.
On another note, last year i had a button to reverse the front and back of the bot. We shot one direction and picked up the other direction. It was a nice function to show off but it became disorienting to drive with, i always forgot witch way it was going to go if i had been stopped for to long. Never used it much.
Unread 09-03-2015, 13:20
Shaif Shaif is offline
FRC #5580 (SQUAD)
Rookie Year: 2015
Shaif is an unknown quantity at this point
One thing that our mentor team (Team 188) suggested we would do is add an override to our limit switches in case of failure during a match. We didn't think we would need it but literally the game right after putting the override into our code we ended up using it because of a gutsy move on my end trying to get as high as I could on our lift system which in return broke the limit switch.
So the lesson learned here is that always have a backup plan for any point of failure so that way you will always be prepared for whatever may happen on the playing field.
Unread 09-03-2015, 13:23
FRC #5580 (SQUAD)
Rookie Year: 2015
Can you post a picture of them on the robot?
Unread 09-03-2015, 13:29
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
We love WCP's hall effect sensors. Light, cheap, and very easy.
http://www.wcproducts.net/sensors
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 09-03-2015, 13:54
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I'm sorry, I don't have any decent close-ups of the switches we've used.
We've attached them with VHB or small screws, and they work well with ~1-2mm air gap between the magnet and the switch.
When we have the robot un-bagged I'll see about getting a photo or two of them.
Unread 10-03-2015, 22:42
AWoL's Avatar
AWoL AWoL is offline
Lvl. 225 Dark Code Mage (Java Type)
AKA: Adam Wolnikowski
FRC #0225 (TechFire)
AWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond repute
I'm the lead programmer, as well as the driver. I made our mecanum drive move the same speed in each direction
2016 Competition Results (Co-captain, Driver, and Lead Programmer; Junior)
Springside-Chestnut Hill District Event - WINNER / #2 Seed, #1 Seed's First Pick / Gracious Professionalism Award
Westtown District Event - WINNER / #1 Seed / Industrial Design Award
MAR District Championship - WINNER / #1 Seed / Industrial Design Award / Dean's List Finalist Award (Me)
World Championship, Carson Subdivision - QUARTERFINALIST / #3 Seed, #2 Seed's First Pick
Indiana Robotics Invitational - FINALIST / #14 Seed, #2 Seed's Second Pick
Unread 10-03-2015, 23:44
ShinyShips's Avatar
ShinyShips ShinyShips is offline
Former Operator and Captain
AKA: Andy
FRC #3314 (Mechanical Mustangs)
ShinyShips is on a distinguished road
We've added a few things to make driving easier, manual compressor off (in case of brown outs), ability to lock our swerves to front/back movement, auto line up with totes, ability to rotate around the stack, and were able to switch between robot and field centric.
Unread 11-03-2015, 00:57
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Can you describe in more detail what you mean by this?
Unread 12-03-2015, 00:23
AWoL's Avatar
A normal mecanum drive moves forwards/backwards at 100% speed, strafes at 50% speed, and moves at a proportional percentage at angles in between. With my code, our drive moves at the same speed in each direction, essentially handling like an omni-drive. Hope I explained it.
Unread 12-03-2015, 00:42
For a hypothetical mecanum drive, top speed in the forward direction is 10fps, and top speed in the strafing direction is 5fps, and at other angles the top speed is between these two speeds. With your code implementation, feedback is used to assure that the robot's top speed never exceeds 5fps, regardless of which angle the robot is moving.
Is this a correct interpretation of what you did?
Unread 12-03-2015, 09:50
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Why do you think that this is advantageous?
