| Thread Tools |
Rating:
Display Modes |
#16
Re: FRC Video Splitter (Beta)
I bet you could manually sync the video with the actual times by entering them both for the first match, then have a script calculate the rest of match start times using the API, then cut out the next ~2:30. This actually seems really feasible. If I get the chance today, I'll try and integrate that into my python scripts |
#18
And more!
➜ phil@fedora ~ frc-api https://frc-api.usfirst.org/api/v1.0/matches/2015/onto2\?tournamentLevel\=qual\&matchNumber\=1
{"Matches":[{"autoStartTime":"2015-03-06T04:19:49.573","description":"Qualification 1","level":"Qualification","matchNumber":1,"scoreRedFinal":63,"scoreRedFoul":0,"scoreRedAuto":6,"scoreBlueFinal":122,"scoreBlueFoul":0,"scoreBlueAuto":6,"Teams":[{"teamNumber":3949,"station":"Red1","dq":false},{"teamNumber":4001,"station":"Red2","dq":false},{"teamNumber":3360,"station":"Red3","dq":false},{"teamNumber":5580,"station":"Blue1","dq":false},{"teamNumber":4069,"station":"Blue2","dq":false},{"teamNumber":1114,"station":"Blue3","dq":false}]}]}%
#20
Precise, yes. Accurate, who knows.
#21
+1 for the new API
It also looks like it was a very early start for our friends in Canada. |
#22
For example 2015CAMA's QF 1 has a start time of "2015-03-08T09:25:33.04" which doesn't make sense in local time (Pacific) or UTC. |
#23
I guess it wouldn't really matter for this application, all we really care about is the time span between matches.
#24
Ah, you are correct.
#25
Correct. It's only the autoStartTime deltas that matter for this application, but it would be comforting to know the source of the time reference. I'd have expected it was a timestamp from the FMS server, but that's usually set to event local time.
#26
I wrote up a quick script that will hit the FMS API for an event of your choosing an make a CSV file of {tbaMatchKey, autoStartTime} for use elsewhere.
You need to have your API secrets in a file to be read https://github.com/phil-lopreiato/ma...timing-data.py |
#27
The only potential issue I see with relying on the API is that not every event will have API data (IE, most off-season events).
#28
I've created an option that can use the FRC API to automatically fill in time stamps after the first is entered.
It worked well when I tested it on my Reading District recordings. However, I haven't put the code in to handle the break between qualifications and playoffs. To work around this, run Splitter on qual videos, then run it again on playoff videos. |
#29
New update from Vikesrock!
New features include:
#30
Sorry to revive an old thread, but just wanted to say that I used the program for the first time today and loved it. If it's simple enough for me to figure out, it should be a breeze for any other user. Thanks so much, Ty.
