Go to Post To give credit where credits due, thanks to the GDC for this update. - Brandon Holley [more]
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Unread 09-03-2015, 15:39
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: FRC Video Splitter (Beta)
Originally Posted by plnyyanks View Post
This is a pretty great idea. The FRC API includes actual match start time in its Results endpoint (we'll add it into TBA if this ever happens).
I bet you could manually sync the video with the actual times by entering them both for the first match, then have a script calculate the rest of match start times using the API, then cut out the next ~2:30.
This actually seems really feasible. If I get the chance today, I'll try and integrate that into my python scripts
Is autoStartTime accurate to seconds?
Unread 09-03-2015, 15:42
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
And more!
➜  phil@fedora ~ frc-api https://frc-api.usfirst.org/api/v1.0/matches/2015/onto2\?tournamentLevel\=qual\&matchNumber\=1
{"Matches":[{"autoStartTime":"2015-03-06T04:19:49.573","description":"Qualification 1","level":"Qualification","matchNumber":1,"scoreRedFinal":63,"scoreRedFoul":0,"scoreRedAuto":6,"scoreBlueFinal":122,"scoreBlueFoul":0,"scoreBlueAuto":6,"Teams":[{"teamNumber":3949,"station":"Red1","dq":false},{"teamNumber":4001,"station":"Red2","dq":false},{"teamNumber":3360,"station":"Red3","dq":false},{"teamNumber":5580,"station":"Blue1","dq":false},{"teamNumber":4069,"station":"Blue2","dq":false},{"teamNumber":1114,"station":"Blue3","dq":false}]}]}%
Unread 09-03-2015, 16:16
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
And more!
+1 for the new API
It also looks like it was a very early start for our friends in Canada.
no stranger to the working end of a pencil
Unread 09-03-2015, 16:23
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Originally Posted by MikeE View Post
+1 for the new API
Looking at the start times, they all seem pretty off.
For example 2015CAMA's QF 1 has a start time of "2015-03-08T09:25:33.04" which doesn't make sense in local time (Pacific) or UTC.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 09-03-2015, 16:38
Robotics Engineer
I guess it wouldn't really matter for this application, all we really care about is the time span between matches.
Unread 09-03-2015, 16:41
The Blue Alliance
Ah, you are correct.
Eugene Fang
Unread 09-03-2015, 17:28
MikeE's Avatar
no team (Volunteer)
Correct. It's only the autoStartTime deltas that matter for this application, but it would be comforting to know the source of the time reference. I'd have expected it was a timestamp from the FMS server, but that's usually set to event local time.
Unread 09-03-2015, 18:18
plnyyanks's Avatar
AKA: Phil Lopreiato
I wrote up a quick script that will hit the FMS API for an event of your choosing an make a CSV file of {tbaMatchKey, autoStartTime} for use elsewhere.
You need to have your API secrets in a file to be read
https://github.com/phil-lopreiato/ma...timing-data.py
Unread 10-03-2015, 23:25
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
The only potential issue I see with relying on the API is that not every event will have API data (IE, most off-season events).
Unread 11-03-2015, 10:01
Robotics Engineer
I've created an option that can use the FRC API to automatically fill in time stamps after the first is entered.
It worked well when I tested it on my Reading District recordings. However, I haven't put the code in to handle the break between qualifications and playoffs. To work around this, run Splitter on qual videos, then run it again on playoff videos.
Unread 02-04-2015, 11:19
Robotics Engineer
New update from Vikesrock!
New features include:
  • Automatic uploading of all videos in destination folder to YouTube
  • Automatic YouTube playlist creation
  • TBA match results in video description.
  • TBA import spreadsheet creation after YouTube upload
  • Improved error handling
  • Progress bars for splitting and uploading
  • And more!
Unread 02-04-2016, 00:08
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Sorry to revive an old thread, but just wanted to say that I used the program for the first time today and loved it. If it's simple enough for me to figure out, it should be a breeze for any other user. Thanks so much, Ty.
Unread 02-04-2016, 00:21
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Agreed this thing is awesome now. Anyone who can download a full achieve of a stream can quickly pull match videos and upload them YouTube and link them to blue alliance which is great for the whole community.
Unread 02-04-2016, 05:53
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Have you tried Version 2? It can pull match start and end time data from TBA and all you need to do is put in the start time of the first match from each day and let it run. Then you can use it to upload to YouTube right from the app with descriptions including match score, make a playlist of the event, and then write an upload file for TBA's match video spreadsheet.
https://github.com/tytremblay/FRC-Video-Splitter-2
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 09-03-2015, 16:13
The Blue Alliance
Precise, yes. Accurate, who knows.
Eugene Fang
