Go to Post They're just dots. You can get them back. - Brandon Martus [more]
Unread 10-03-2015, 09:37
alextound alextound is offline
alextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these parts
Re: Math: How to solve ranking equation
i mean this:
http://www.usfirst.org/sites/default/files/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info/2015/FRC_District_Standard_Points_Ranking_System_2015%2 0Summary.pdf
Unread 10-03-2015, 09:41
ATannahill ATannahill is offline
AKA: Alex Tannahill
This was discussed in Frank's blog.
There is a document that elaborates further on the equation. You can scroll to the bottom to see what values would come out for a 32, 40, 55, 60 and 64 team event.
Unread 10-03-2015, 10:16
That formula is only relevant for district events. It converts ranking to "District Qualification Points". A comprehensive explanation of the Inverse Error Function belongs in an advanced statistics class. All you need to know is that it is built in to tools like Matlab.
Unread 10-03-2015, 11:15
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
I was curious about the function, did a little digging found someone already made one for Excel VBA. I hope this helps.
http://www.mrexcel.com/forum/excel-q...ml#post1146833
Function invERF(y As Double) As Double
Dim pi As Double, x As Double, d As Double
pi = 3.14159265358979
If y < 0 Then
    invERF = 0 'interval includes the mean only
    Exit Function
ElseIf y >= 1 Then
    invERF = 10 'makes the interval include everything
    Exit Function
'for my purposes, I only want the function to process input from 0 to 1
ElseIf y < 0.596 Then
    x = sqr(pi) / 2 * y * (1 + (pi / 12) * y * y)
Else
    x = sqr(-Log((1 - y) * sqr(pi)))
End If
d = (y - ERF(x)) / (2 * Exp(-x * x) / sqr(pi))
x = x + d
Do While Abs(d) >= 0.00000001
    x = x + d
Loop
invERF = x
End Function
Function ERF(x As Double) As Double
Dim f As Double, c As Double, pi As Double
Dim j As Integer
c = 0
If 1.5 < x Then
    c = 2 - c
    j = 3 + Int(32 / x)
    f = 0
    Do While j <> 0
        f = 1 / (f * j + x * sqr(2))
        j = j - 1
    Loop
    f = f * c * (3 - c * c) * Exp(-x * x) / sqr(2 * pi) + (c - 1) * (3 * c * c + c - 8) / 6
Else
    j = 3 + Int(9 * x)
    f = 1
    Do While j <> 0
        f = 1 + f * x * x * (0.5 - j) / j / (0.5 + j)
        j = j - 1
    Loop
    f = c + f * x * (2 - 4 * c) / sqr(pi)
End If
    ERF = f
End Function
Unread 10-03-2015, 14:21
MasterMentor's Avatar
MasterMentor MasterMentor is offline
TheGreatGonzo
AKA: George Gonzo
MasterMentor will become famous soon enough
You just have to be careful about this, the input into InvERF with the District Qual Points Formula will be negative on one side of the [-1, 1] range, and this function can only handle positive input values. Also at the midpoint it's possible to get a divide-by-zero error with this function too. Both issues are easily worked around with a little formula/programming magic, but it's important to know this isn't a perfect drop-in solution.
-MM
Unread 10-03-2015, 15:42
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Basically the formula is given you just have to plug and chug, some calculators will have an inverse error function ability, if your does you find it use it and plug in the necessary values for the variables, N= number of teams at event, R=your final ranking position and alpha is a constant set by the committee based on averages of event size at 1.07. The lines on each end tell you just to round up to the nearest whole number give it a shot for our first event it would look like this:
invERF[( 33-2x13+2)/(1.07*33)]X(10/(invERF 1/1.07)+12) 13. ....... rounded up to nearest whole integer =14
remember inverse is NOT the same as going to the power of -1 if you don't have a calculator with the function already...
if you don't have this function at all on your calculator then it gets much more complicated solving for invERF as its a function itself requiring integrals and such
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 10-03-2015, 17:56
remember inverse is the same as going to the power of -1 if you don't have a calculator with the function already...
The inverse of a function f(x) is not 1/f(x).
The inverse of f(x) is g(x), such that g(f(x))=x
For example, the inverse of f(x)=x2 is g(x)=sqrt(x), not 1/x2
octave-3.6.4.exe:10> erfinv(0.33)
ans =  0.301332146133706
octave-3.6.4.exe:11> 1/erf(0.33)
ans =  2.78335488667249
Unread 10-03-2015, 18:09
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
Plus, for Qualifications, if the number of teams is not divisible by six, there are surrogate matches, which are the third match for teams that fill the surrogate role.
More Math!
Unread 11-03-2015, 06:48
AKA: Alex Tannahill
More Math!
Not quite correct.
If the number of teams * the number of matches per team is not a multiple of six, then you will have surrogates.
Michigan (and I believe most other district systems) gives each team 12 matches. A benefit to this is that there will never be a surrogate.
Unread 10-03-2015, 18:10
Enginerd
FTC #11722
I knew Ether would show up and clear all this up
Unread 10-03-2015, 18:15
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
When the student is ready, the master appears.
Richard Wallace
since 2003
Unread 10-03-2015, 19:00
Rachel Lim Rachel Lim is offline
FRC #1868 (Space Cookies)
Team Role: Student
Rachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond repute
If you're looking for a more visual explanation (or a simpler one), I wrote up this summary for my team: http://goo.gl/lx2I2l
I tried to explain the math behind it without calculus or too much statistics, which makes it easier to read but not nearly as in depth as the official explanation (in my opinion). It's mostly a graphical / algebra based analysis to get at the basics of what district ranking is and how your ranking at an event factors into it.
Note: I haven't taken any statistics classes and we're not yet in districts, so I'm not sure if everything I wrote is completely accurate. Please let me know if anything is wrong and I'll try to correct it.
Last edited by Rachel Lim : 11-03-2015 at 02:11. Reason: 1. Fixed typo in the text. 2. Fixed typos in the document, replaced link. (I should proofread more carefully...)
Unread 10-03-2015, 19:07
Originally Posted by Rachel Lim View Post
Please let me know if anything is wrong and I'll correct try to correct it.
There's an extra word in that sentence.
Unread 10-03-2015, 19:11
Team Role: Student
Thanks for catching that. Did you find any errors in my analysis?
Unread 10-03-2015, 19:19
Based on the paper you wrote for Math Quiz 6, I wouldn't expect to find any :-)
