Go to Post If it's anything that FIRST's competitive spirit has taught me, its to take the good with the bad. - Mike Schroeder [more]
Unread 10-03-2015, 11:01
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
Re: Maximum current draw through DIO port
J,
When you speak of LEDs, many of us naturally think an LED string. A single LED can be switched by the DIO through a switching transistor or other driver. If your LED can operate (actually produce light) at 4 ma, you can sink that much current as quoted by Frank above.
We have a custom circuit that with a hall effect switch powered off from a DIO port. The circuit has a LED on it to act as an indicator when the hall effect chip has latched.
Unread 10-03-2015, 11:37
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Unless there's something in the 2015 rules I missed, the Pneumatics Control Module is another option for LED control.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 10-03-2015, 13:48
jbernardis jbernardis is offline
FRC #1403
jbernardis is an unknown quantity at this point
I have a small circuit with a 2n2222a transistor and a 2k resistor that draws only 2 ma. Connecting this to the DIO port will allow switching the LED on and off and yet stay within the limitations of the DIO port.
Unread 10-03-2015, 15:09
I run small circuits like that off the DIO all the time.
Unread 10-03-2015, 16:45
FRC #1403
Actually I've been doing my figuring based on 5v, but I'm pretty certain these ports operate at 3.3v. So if my transistor has a voltage drop of 0.7v, then to achieve ~2ma I need a smaller resistor than the 2k I have in mind. Based on 3.3, the voltage across the resistor would be 2.6v, so using a 1K resistor instead would limit current to ~2.6ma which is in the ballpark.
Unread 10-03-2015, 17:38
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
http://dangerousprototypes.com/2011/...reshold-chart/
http://www.pericom.com/assets/App-Note-Files/AN066.pdf
74HCTxxx or 74LSxxx TTL logic chips ought to be able to tolerate 3.3V inputs.
Just remember to put a voltage divider on outputs to DIO inputs to go from 5V TTL supply voltage to 3.3V.
In this way with a 74HCT240 (inverting) or 241 (non-inverting) octal buffers give you 8 buffers per chip.
These buffers are usually capable of >25mA of sink/source current.
With that one could drive the inputs of the ULN2803 that would give you 8 Darlington transistors good for 500mA up to 50V.
Not sure what you can do with that but I would advise checking the rules carefully.
