Go to Post If anybody ever uses a terabyte in the next few years the world would probably come to an end - spadercool [more]
Unread 10-03-2015, 16:25
Re: Need help with logic
Originally Posted by bacarpenter View Post
I tried to do what you said but the while loop inside of the flat sequence runs and the outside loops isn't executed. I posted a picture of what I currently have
With that code, you're essentially taking a snapshot of the joystick button and the limit switch before the flat sequence begins, and not reading them again until it has ended.
You need to put the Joystick Get and the Switch Get Value functions inside their respective loops, so that you're repeatedly reading their current value.
