Go to Post It really is up to us to stand up for these principles so when we sell it to the general public we're not just feeding them some line because if we don't believe it, why should they? - Koko Ed [more]
Unread 10-03-2015, 08:39
alextound alextound is offline
alextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these parts
Question Math: How to solve ranking equation
I no do math, can someone give me a quick math lesson on solving the ranking equation.
Thanks!
Unread 10-03-2015, 08:56
microbuns's Avatar
microbuns microbuns is offline
AKA: Sam Maier
FRC #4917
microbuns is an unknown quantity at this point
Re: Math: How to solve ranking equation
Do you mean in Qualifications? They just take your average score from each game you played in quals, then rank the teams from highest to lowest.
Unread 10-03-2015, 09:03
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
They average your alliance's score as your Qualification Average and they go in the following order:
Qual Avg
Cooperative pts
Auto pts
RC pts
Tote pts
sum of Noodle pts
Random FMS sorting
See 5.3.4 of the Game Manual.
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
What ranking equation do you mean? Ranking is simple: more points is better. To a first approximation, a team ranks above other teams with fewer points, and below other teams with more points.
Unread 10-03-2015, 09:37
i mean this:
http://www.usfirst.org/sites/default/files/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info/2015/FRC_District_Standard_Points_Ranking_System_2015%2 0Summary.pdf
Unread 10-03-2015, 09:41
ATannahill ATannahill is offline
AKA: Alex Tannahill
This was discussed in Frank's blog.
There is a document that elaborates further on the equation. You can scroll to the bottom to see what values would come out for a 32, 40, 55, 60 and 64 team event.
Unread 10-03-2015, 10:16
That formula is only relevant for district events. It converts ranking to "District Qualification Points". A comprehensive explanation of the Inverse Error Function belongs in an advanced statistics class. All you need to know is that it is built in to tools like Matlab.
Unread 10-03-2015, 11:15
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
I was curious about the function, did a little digging found someone already made one for Excel VBA. I hope this helps.
http://www.mrexcel.com/forum/excel-q...ml#post1146833
Function invERF(y As Double) As Double
Dim pi As Double, x As Double, d As Double
pi = 3.14159265358979
If y < 0 Then
    invERF = 0 'interval includes the mean only
    Exit Function
ElseIf y >= 1 Then
    invERF = 10 'makes the interval include everything
    Exit Function
'for my purposes, I only want the function to process input from 0 to 1
ElseIf y < 0.596 Then
    x = sqr(pi) / 2 * y * (1 + (pi / 12) * y * y)
Else
    x = sqr(-Log((1 - y) * sqr(pi)))
End If
d = (y - ERF(x)) / (2 * Exp(-x * x) / sqr(pi))
x = x + d
Do While Abs(d) >= 0.00000001
    x = x + d
Loop
invERF = x
End Function
Function ERF(x As Double) As Double
Dim f As Double, c As Double, pi As Double
Dim j As Integer
c = 0
If 1.5 < x Then
    c = 2 - c
    j = 3 + Int(32 / x)
    f = 0
    Do While j <> 0
        f = 1 / (f * j + x * sqr(2))
        j = j - 1
    Loop
    f = f * c * (3 - c * c) * Exp(-x * x) / sqr(2 * pi) + (c - 1) * (3 * c * c + c - 8) / 6
Else
    j = 3 + Int(9 * x)
    f = 1
    Do While j <> 0
        f = 1 + f * x * x * (0.5 - j) / j / (0.5 + j)
        j = j - 1
    Loop
    f = c + f * x * (2 - 4 * c) / sqr(pi)
End If
    ERF = f
End Function
Unread 10-03-2015, 14:21
MasterMentor's Avatar
MasterMentor MasterMentor is offline
TheGreatGonzo
AKA: George Gonzo
MasterMentor will become famous soon enough
You just have to be careful about this, the input into InvERF with the District Qual Points Formula will be negative on one side of the [-1, 1] range, and this function can only handle positive input values. Also at the midpoint it's possible to get a divide-by-zero error with this function too. Both issues are easily worked around with a little formula/programming magic, but it's important to know this isn't a perfect drop-in solution.
-MM
Unread 10-03-2015, 15:42
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Basically the formula is given you just have to plug and chug, some calculators will have an inverse error function ability, if your does you find it use it and plug in the necessary values for the variables, N= number of teams at event, R=your final ranking position and alpha is a constant set by the committee based on averages of event size at 1.07. The lines on each end tell you just to round up to the nearest whole number give it a shot for our first event it would look like this:
invERF[( 33-2x13+2)/(1.07*33)]X(10/(invERF 1/1.07)+12) 13. ....... rounded up to nearest whole integer =14
remember inverse is NOT the same as going to the power of -1 if you don't have a calculator with the function already...
if you don't have this function at all on your calculator then it gets much more complicated solving for invERF as its a function itself requiring integrals and such
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 10-03-2015, 17:56
remember inverse is the same as going to the power of -1 if you don't have a calculator with the function already...
The inverse of a function f(x) is not 1/f(x).
The inverse of f(x) is g(x), such that g(f(x))=x
For example, the inverse of f(x)=x2 is g(x)=sqrt(x), not 1/x2
octave-3.6.4.exe:10> erfinv(0.33)
ans =  0.301332146133706
octave-3.6.4.exe:11> 1/erf(0.33)
ans =  2.78335488667249
Unread 10-03-2015, 18:09
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
Plus, for Qualifications, if the number of teams is not divisible by six, there are surrogate matches, which are the third match for teams that fill the surrogate role.
More Math!
Unread 10-03-2015, 18:10
Enginerd
FTC #11722
I knew Ether would show up and clear all this up
Unread 10-03-2015, 18:15
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
When the student is ready, the master appears.
Richard Wallace
since 2003
Unread 10-03-2015, 19:00
Rachel Lim Rachel Lim is offline
FRC #1868 (Space Cookies)
Team Role: Student
Rachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond repute
If you're looking for a more visual explanation (or a simpler one), I wrote up this summary for my team: http://goo.gl/lx2I2l
I tried to explain the math behind it without calculus or too much statistics, which makes it easier to read but not nearly as in depth as the official explanation (in my opinion). It's mostly a graphical / algebra based analysis to get at the basics of what district ranking is and how your ranking at an event factors into it.
Note: I haven't taken any statistics classes and we're not yet in districts, so I'm not sure if everything I wrote is completely accurate. Please let me know if anything is wrong and I'll try to correct it.
Last edited by Rachel Lim : 11-03-2015 at 02:11. Reason: 1. Fixed typo in the text. 2. Fixed typos in the document, replaced link. (I should proofread more carefully...)
