Go to Post Search is amazing. Give it a try. It's 10,000 lines of code that gets lonely if it's not played with often. - Brandon Martus [more]
  #46   Spotlight this post!
Unread 10-03-2015, 20:40
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Video of 1114
Originally Posted by Kevin Sevcik View Post
Well 18 frames is about how long a gravity drop from 78" should take, so I guess I must've missed some of the slower acceleration at the beginning. And/or it's not dropping a full 78".
It definitely doesn't drop the full 78". The claw's resting point is well above the height of a single tote -- the RC gets pushed upwards in the claw by the totes below it.
  #47   Spotlight this post!
Unread 10-03-2015, 21:12
Aidan H.'s Avatar
Aidan H. Aidan H. is offline
Unregistered User
FRC #3260 (SHARP)
Aidan H. will become famous soon enough
Re: Video of 1114
After some digging, I was able to actually get a pretty good understanding of their passive (-ish) lift. It seems like there is no vertical actuation of the tall lift at all that is only for the bin holder (it can go up by itself). It looks like there is actually some surgical tubing passively pulling the bin holder down (easily seen at ~30 sec in video), so that it can't "bounce" off the top of the stack while one is being made or when the stack is jiggling around. Also, when 1114 grabs a can, they have to first lift it to the height of 1 tote, which is actually done with the use of their normal "tote lifters" pushing their can grabber up while it is holding a can (at ~25 sec, little spinner is rotating to confirm the "tote lift" being run). It is not clear, at least from the video I can find, how the can grabber is kept at the 1 tote height after being lifted there, but there is a chance that there is a passive 1-way latch mechanism that locks it to (/above) that 1 tote height when the bin grabber is closed (dual use mechanism, can clamp on bins, and engage lift latch). The can grabber can drop all the way to the bottom and miss the latch because the can grabber is always open when it drops to the bottom, and (I presume) was designed to miss the locking level when the grabber was in the open state.
This is all just speculation as to what might be at work behind that beautiful red powdercoat, and it will probably be thoroughly explained when they post their robot poster for SideSwipe.
I am absolutely astounded by the complexity and simplicity that went into this robot, and the level of foresight that was paid to how this game would play out. Intaking fast and being able to sturdily handle a full stack seemed to have been top priorities for 1114, and they were definitely able to achieve them.
Here's the video that I referenced up there (Quarters 8): 2015 - Greater Toronto Central Regional - Quarter Final - 8
(watch in HD for a better view)
2016 - Greater Pittsburgh Regional Engineering Inspiration Award
2014 - Greater Pittsburgh Regional Winner
2013 - Pittsburgh Regional Finalists
2013 - Buckeye Regional Finalists
  #48   Spotlight this post!
Unread 10-03-2015, 21:20
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Re: Video of 1114
That is just spiral pneumatic tubing that connects to the pneumatic actuator on the bin grabber.
2016: FRC 865 Mentor
  #49   Spotlight this post!
Unread 10-03-2015, 21:34
Aidan H.'s Avatar
Unregistered User
FRC #3260 (SHARP)
Re: Video of 1114
It actually seems like it might have been some surgical tubing that was tied on at a later time in the competition, as it seems to be absent at ~37 sec in this video (Qual 30), but was there in at least their 2nd quarter final (QF8 at ~30 sec).
If it isn't spiral pneumatic tubing, I don't know where their pneumatics would be run through as I can't spot them (yet).
  #50   Spotlight this post!
Unread 10-03-2015, 21:50
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Video of 1114
I am pretty sure what you believe to be surgical tubing is actually the spiral air tubing. If there was surgical tubing stretched that distance, it would drop much faster. I think the cylinder is visible in the picture as well.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
  #51   Spotlight this post!
Unread 10-03-2015, 21:58
FIRST_Parent FIRST_Parent is offline
Proud Papa of a 2013 World Champion
FIRST_Parent has a brilliant futureFIRST_Parent has a brilliant futureFIRST_Parent has a brilliant futureFIRST_Parent has a brilliant futureFIRST_Parent has a brilliant futureFIRST_Parent has a brilliant futureFIRST_Parent has a brilliant futureFIRST_Parent has a brilliant futureFIRST_Parent has a brilliant futureFIRST_Parent has a brilliant futureFIRST_Parent has a brilliant future
Re: Video of 1114
Originally Posted by Bochek View Post
Thanks Bochek for these video's. Much appreciated.
  #52   Spotlight this post!
Unread 10-03-2015, 22:02
Aidan H.'s Avatar
Unregistered User
FRC #3260 (SHARP)
Re: Video of 1114
Originally Posted by Mike Marandola View Post
I am pretty sure what you believe to be surgical tubing is actually the spiral tubing. If there was surgical tubing stretched that distance, it would drop much faster. I think the cylinder is visible in the picture as well.
Yeah, you're right. Sorry about that. I guess the video just is pretty hard to see clearly enough.
On that note, does anyone have some close-up photos of any mechanisms?
Though in the future, I wouldn't be surprised to see something like a constant force spring pulling the lift down, as it definitely seems advantageous to have downward pressure on the stack (but gravity is probably enough). It also might just not matter; it's working perfectly as it is.
  #53   Spotlight this post!
Unread 10-03-2015, 22:08
118418 118418 is offline
118418 is an unknown quantity at this point
Re: Video of 1114
For the RC flip, it looks like they have a low arm (2"-4" high from the ground) that comes out and pushes on (or holds) the lower rim of the RC bottom, while the intake wheels pull the RC in. This creates a torque for the RC to rotate up. Look at ~63 sec of the game clock. The low push arm that comes out is not colored.
  #54   Spotlight this post!
Unread 10-03-2015, 22:13
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
Re: Video of 1114
Wow so much attention to detail every part of the stacking process is automated down to the second.... That is such a small detail but is super effective
  #55   Spotlight this post!
Unread 10-03-2015, 22:14
Re: Video of 1114
Here is a picture of the push/hold arm, posted in the GTRC thread by EddtG or #1285. You can see it clearly here.
https://www.facebook.com/FIRSTRoboti...type=3&theater
  #56   Spotlight this post!
Unread 11-03-2015, 02:10
Zentx's Avatar
Zentx Zentx is offline
AKA: Robert
FRC #3949
Team Role: Electrical
Zentx is an unknown quantity at this point
Re: Video of 1114
Here is a closer look at 1114 from the side, including AUTONOMOUS !
https://www.youtube.com/watch?v=r7-NigYFrWo
  #57   Spotlight this post!
Unread 11-03-2015, 07:11
DonShaw DonShaw is offline
FRC #1261
DonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of light
Re: Video of 1114
If you watch the video a long black like antennae comes well above the legal height limit. The rule states at no time can a robot exceed 78" during the match and if it does its gets disabled and DQ'd.
It does not allow for a mechanical breakdown or malfunction. It is one of the simplest rules they have with no grey area.
This is in the first video posted on this thread.
  #58   Spotlight this post!
Unread 11-03-2015, 07:38
Aren Siekmeier's Avatar
on walkabout
Re: Video of 1114
http://www.chiefdelphi.com/forums/sh...4&postcount=14
  #59   Spotlight this post!
Unread 11-03-2015, 09:21
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Video of 1114
From this thread I have learned that the Simbots will never ally with the Poofs.
Otherwise they'll have to make a movie about what happens when Transformers and Decepticons get along, and that would be quite boring.
  #60   Spotlight this post!
Unread 11-03-2015, 09:39
Batterink Batterink is offline
FRC #4519
Batterink is an unknown quantity at this point
Re: Video of 1114
Political thriller
