Go to Post Bottom line: if it confuses my mom, it is bad for FIRST. - Joe Johnson [more]
Unread 11-03-2015, 08:23
noah10001 noah10001 is offline
FRC #5447
noah10001 is an unknown quantity at this point
Detecting Talon motors on robo rio
How do I detect my motor controllers on the Robo Rio? Do i have to switch out my motors with this?
Unread 11-03-2015, 09:34
Re: Detecting Talon motors on robo rio
What do you mean by "detect"? Please rephrase your question.
Unread 11-03-2015, 09:41
NHoffmann's Avatar
NHoffmann NHoffmann is offline
FRC #0573 (Mech Warriors)
NHoffmann is an unknown quantity at this point
That "Open Motor Controller" block will, when placed in a block diagram, generate a drop-down menu where you can select the type of controller you are using, and the block changes depending on which motor type you select.
WHO ARE WE?
573!
Unread 28-03-2015, 11:21
Nunez4296's Avatar
Nunez4296 Nunez4296 is offline
Programmer
AKA: Joseph Nuņez
FRC #4296 (Trident Robotics)
Nunez4296 is an unknown quantity at this point
If you open up a web browser and search " roborio-(TeamNumber).local " you will be able to see every CAN enabled device on your robot. If your PDP, or any other CAN device isn't showing up, that means there is a problem with your daisy chain. Once you correctly assign device numbers, open Labview, and add a "Motor Open", it does NOT need to be a CAN Talon SRX. Then, from the drop down menu, you will see all types of motors. Select the CAN Talon SRX, create a constant for the device number, and you should be good to go.
Also
detect
[dih-tekt]
Examples
verb (used with object)
1. to discover or catch (a person) in the performance of some act: "to detect someone cheating."
2. to discover the existence of: "to detect the odor of gas."
3. to find out the true character or activity of: "to detect a spy."
4. Telecommunications.
a. to rectify alternating signal currents in a radio receiver.
b. to demodulate.
5. to detect the CAN devices on your robot.
The Eagle - By Alfred, Lord Tennyson
He clasps the crag with crooked hands;
Close to the sun in lonely lands,
Ring'd with the azure world, he stands.
The wrinkled sea beneath him crawls;
He watches from his mountain walls,
And like a thunderbolt he falls.
Unread 29-03-2015, 00:39
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Hey Noah,
Looks like a screenshot from our SRX software reference manual. If you are using talon SRXs on canbus, use the web based config to assign unique device ids to each CAN Talon. Then in LabVIEW use the same device ids when opening the motor controller.
Makes sense?
