Go to Post This our big chance to spread the word and change the culture, let's not waste it. So in the words of one Leroy Jenkins, "Time's up, let's do this." - Frenchie461 [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 11-03-2015, 08:43
Mschmeh144's Avatar
Mschmeh144 Mschmeh144 is offline
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Mschmeh144 is an unknown quantity at this point
Re: Most damage sustained
Originally Posted by Loose Screw View Post
Oh man those minibots. At our first competition one of them went up and hit the top with enough force to scrape the battery cover plate into the battery, resulting in a ball of smoke falling from a 10-foot high drop (very much like BX 2013). One of the volunteers quickly removed it from the playing field. That was the same volunteer who turned off power to the 2013 robot.
At our second 2011 event, our mini bots kept going up and down the pole. We were the only team who could win 1st, 2nd, 3rd, and 4th place in one match. It was fun for the crowd to watch, but usually resulted in motors burning out (we hadn't thought about using a 7.5 amp fuze until after that). We eventually found out that the flat light switch we were using to turn it off at the top was weak enough to switch back on from the force of the fall.
I would find that pretty amusing, especially If a ref was trying to get it down and it kept zipping back and forth
  #32   Spotlight this post!
Unread 11-03-2015, 09:18
Loose Screw's Avatar
Loose Screw Loose Screw is offline
A Loose Screw
AKA: Chris
FTC #5237 (Loose Screws)
Loose Screw is a jewel in the roughLoose Screw is a jewel in the roughLoose Screw is a jewel in the rough
The refs just let them go. They let our drive team handle them as soon as the all clear was given.
The minibots were eventually worn down after going up and down so much that they were driving really slow once the match ended (probably a burnt out motor). Some had even just stopped 1/3 of the way up the pole.
  #33   Spotlight this post!
Unread 11-03-2015, 10:29
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
I don't understand. Are you telling me tetrix motors burnout?!?!?
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
  #34   Spotlight this post!
Unread 11-03-2015, 12:34
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
This was not our bot but I hit 3604 last year and this happened...I felt bad but they brought it back for me to sign
https://drive.google.com/file/d/0BxN...ew?usp=sharing
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
  #35   Spotlight this post!
Unread 11-03-2015, 13:04
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
if you stall them or over work them they fail. theyre prone to burnouts, its very common
  #36   Spotlight this post!
Unread 11-03-2015, 13:10
A Loose Screw
AKA: Chris
That as well as those gearboxes were weak. Our minibots didn't use them, but the FTC team I coach used them one year, and ended up breaking multiple tetrix gear boxes for their lift. The next year they improved the gear boxes and made them stronger.
  #37   Spotlight this post!
Unread 11-03-2015, 13:11
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
that is also true.
  #38   Spotlight this post!
Unread 11-03-2015, 14:15
audietron's Avatar
I realize this. Tetrix motors ratings are terrible and an FTC team that uses solely tetrix will go through 10 or more motors in a season simply because of the lack of quality. Thank goodness andymark made the nevrest motors.
  #39   Spotlight this post!
Unread 11-03-2015, 14:22
A Loose Screw
AKA: Chris
Tetrix aren't as bad as you think. The Loose Screws (FTC 5237) used tetrix and we didn't burn any in competition. The last one we burnt was when we tested our lift and we continued to power it even though it was at the top.
Even when we broke those gearboxes in ring it up, the motors were perfectly fine.
There are also four other FTC teams in Bedford, and I haven't heard of them burning out motors.
  #40   Spotlight this post!
Unread 11-03-2015, 15:01
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
We are referring to the older Tetrix motors, they are the ones that are very prone to burning up
  #41   Spotlight this post!
Unread 11-03-2015, 15:08
A Loose Screw
AKA: Chris
They were worse before ring it up? Wow, those must have sucked. I'm glad now that the motors and gearboxes are stronger.
  #42   Spotlight this post!
Unread 11-03-2015, 17:31
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
The worst damage I've ever heard done to a robot was 801 and 1592's robots back in 2013 on load in night for the Orlando Regional. Both robots were destroyed when a pickup truck slammed into the back of their trailer and pulverized 1592 while 801's robot was decapitated. Fortunately the student and mentor were unhurt but they and their teammates were obviously devastated.
Then they got over it and built competition ready robots that made the elims in one night.
Inspiring stuff.
Pictures of the destroyed robots I mentioned.
1592.
801.
This is what they look like after a night of tireless effort.
  #43   Spotlight this post!
Unread 11-03-2015, 17:45
EmileH's Avatar
EmileH EmileH is offline
#dontbelarge
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
At a scrimmage event in 2014 our robot had our radio ripped out by an alliance partner's claw/shooter
2016-present: High School Student, FRC 1058 PVC Pirates
  #44   Spotlight this post!
Unread 11-03-2015, 17:49
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Much worse. If they stalled at all you can just pitch it because it probably won't unstall, just lock up and burnout. They started making them differently, much better now, they're still known for breaking sometimes. It wasn't just the motor, it was the gearbox too, the gears inside would strip out and then jam if it stalled. These motors are from the kit that came in the Frc kit of parts ( correct me if I'm wrong, I wasn't on the team that year ) theyve since made them better.
We still have out Tetrix motors. We still have the whole kit actually. With the original motors
  #45   Spotlight this post!
Unread 11-03-2015, 17:53
MooreteP's Avatar
MooreteP MooreteP is online now
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
Originally Posted by MaGiC_PiKaChU View Post
in 2013 we fell from the pyramid when an opposing robot hit us, breaking 2 wheels and their respective planetary gearboxes, and our inch-wide screw that held our elevator mechanism
You mean this?
Hyperion Falls
at 0:45.
My favorite fall down go boom, Team 1831, The Screaming Eagles:
1831 Falls
at 2:00.
