Go to Post but look at the bright side, you will now be able to size 1/4-20 nuts with your forearm and i doubt there are many people who can say that :p - Greg Needel [more]
  #31   Spotlight this post!
Unread 11-03-2015, 12:28
Crossle86's Avatar
Crossle86 Crossle86 is offline
Software Engineer
AKA: Richard Corn
FRC #4450 (Olympia Robotics Federation)
Crossle86 is an unknown quantity at this point
Re: Driver Station Update fails to install
This all sounds good. Thanks again for clearing up all my questions. Things seem to be on track with our DS PCs now.
  #32   Spotlight this post!
Unread 11-03-2015, 17:50
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Originally Posted by Crossle86 View Post
5) Don't forget about the Driver user shell program not getting renamed. After a successful install of the update, the Driver user still runs the old program (hence the renaming I am doing). Note that I could have tweaked the registry to the correct program name, but I have our DS PCs set up to allow switching between the 2015 and 2014 DS programs as we still run last years robots quite a bit for demos and having the DS program name the same facilitates this switching. I know the 2015 is supposed to let you switch protocols, but this did seem to work when we first installed 2015 so we did it ourselves. And doing it ourselves allows us to switch out the custom display program we have for the upper part of the DS display.
Our installer apparently never set this key up. It was done in the classmate image only. There is nothing we can change here. It is the Classmate Images that need to be updated. Please file a tracker here for the classmate images to be fixed.
