Go to Post Making a part look pretty even after it is functionaly done can be a very good thing, espically when the part gets cut from the bot and you get to keep it as a trophey. Take pride in your work. - Andy A. [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 11-03-2015, 18:13
razar51 razar51 is offline
AKA: John Faulkner
FRC #1288 (Raven Robotics)
razar51 is an unknown quantity at this point
Team 1288 Initial Python Code release
This is the first year team 1288 is using python for our robot. Here is our initial code going into the competition.
We only scratched the surface of what we can do with python and hope to greatly improve our coding process in the years to come!
Unread 11-03-2015, 23:16
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat will become famous soon enoughTimTheGreat will become famous soon enough
Re: Team 1288 Initial Python Code release
First off, congrats. Python is a great language choice since it's so easy to use.
I went through your code because it is always fun to see how teams do stuff differently, and I noticed a few things.
self.cameraFour = wpilib.USBCamera(b'cam3')
Did you mean to put b'cam3'?
Also, the code for gyro rotation seems awfully long. 1418 did this last year and the way we did it was
angleOffset = target_angle - self.return_gyro_angle()
if angleOffset < -1 or angleOffset > 1:
	self.rotation = angleOffset * self.angle_constant
	self.rotation = max(min(0.5, self.rotation), -0.5)
self.angle_constant was used to keep the rotation speed low. It was .04. The max(min()) code keeps the rotation in between -.5 and .5 as an extra safety precaution. Then we just pass self.rotation into the mecanum drive method to rotate.
Either now while you're waiting for competition or during the offseason rewrite your code. It is a great way to learn, as you often think of a better way to do something. Also, look at other python teams and their code from previous years.
PS: Don't forget to add yourselves to the 2015 RobotPy Roll Call
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 11-03-2015, 23:34
ArchdukeTim
You guys aren't using github are you?
Unread 12-03-2015, 01:02
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Good stuff! Glad to see more people making use of python
You might find that your autonomous state machines will be easier to create/read/adjust if you use the StatefulAutonomous stuff in robotpy-wpilib-utilities.
