Go to Post I believe youth is contagious. I want to catch as much as I can! - Al Skierkiewicz [more]
Unread 25-02-2015, 23:13
itwasntme455 itwasntme455 is offline
AKA: Brandon
FRC #4791 (Pandroids)
itwasntme455 is an unknown quantity at this point
Servo Help
We need a servo to move in one direction when button "A" or "B" is pressed and held but only move a certain distance. Then when you release button "A" or "B" the servo will move back the same distance and stop. How do we do this?
Unread 25-02-2015, 23:29
AKA: Brandon
Re: Servo Help
Would this work?
https://scontent-ord.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/11026250_10200285123408733_1602389002403779689_n.j pg?oh=5e3563c457b205e5364e54ce19b28a98&oe=5548BC9A
Unread 12-03-2015, 09:34
NHoffmann's Avatar
NHoffmann NHoffmann is offline
FRC #0573 (Mech Warriors)
NHoffmann is an unknown quantity at this point
Re: Servo Help
You might be able to do this with a sequence structure. While button A is pressed, first move servo for X seconds, create a while loop in a new frame, re-acquire the button value, set the servo to 0, then set the loop to continue while the button is pressed.
WHO ARE WE?
573!
Unread 12-03-2015, 23:03
nwall nwall is offline
It's a hardware problem
AKA: Nicholas
FRC #0418 (LASA Robotics)
nwall is an unknown quantity at this point
Re: Servo Help
I think this code does what you want it to. I think "itwasntme455" code might work, but I'm not sure because I can't see inside of the other cases.
servoThreePos.vi:
will simply check which position you're trying to go to, and then set position based on that. If you want, you can just replace "SetPosition" with "SetRotation" and replace the values for the positions.
