Go to Post The ChiefDelphi forums are more than just a place for people to kill time and engage in some chit chat. - Karthik [more]
Unread 12-03-2015, 17:52
minutebot minutebot is offline
Programming Captain
FRC #4536 (The Minutebots)
minutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of light
Code Works on Robot but Still Displays Errors
I'm working with Java in Eclipse and even though when I deploy code it works fine on the robot, I'm still getting error messages throughout my code stemming from the initial errors in the import statements "The import edu cannot be resolved". I've tried a number of things to fix this
-Removing the JRE system library and readding it
-I've selected jdk.1.8.0_25 in the installed JREs
-Reimported from github
-Reinstalled eclipse
-Reinstalled the FRC plugins
Yet none of these have worked. I'd really like to be able to tell when my code has an actual error so any help is much appreciated.
Unread 12-03-2015, 20:17
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Code Works on Robot but Still Displays Errors
Try removing and added the referenced libraries in your code. By that I mean remove the wpilib and add it again...its looking in a different location and eclipse cannot find it however the build script does. I had the same problem just readd the libraries and it should be fixed.
Unread 14-03-2015, 11:44
Programming Captain
I just fixed it. Turns out I needed to add wpilib as a new variable and manually set the build path.
