Go to Post I have way too much time on my hands. - Brandon Martus [more]
Unread 13-03-2015, 14:36
SirGibbs SirGibbs is offline
FRC #5676 (Hornets)
Rookie Year: 2015
SirGibbs is an unknown quantity at this point
arcade drive
Hey guys I am from team 5676 and we have a little or big problem with our arcade drive and the java program. We are using talon motor controllers with the kop andymark motors and pneumatic's. But we don't get it running. The robot is just turning around the y and at the x axes at option 1 but the pneumatic's are working. At option 2 is it not driving and the pneumatic's aren't working also but I thought that it would be he exact copy of the example but the code is getting permanently deployed at the roborio. Because an other problem is that at option 1 is the code stopping and getting periodically erased from the roborio at around 1;50 until I restart it. My first thought was that it's maybe running out of ram but that doesn't seem to be the problem.
Every help or input would be highly appreciated. I thank all of you in advance for your time and help.
option 1:
package org.usfirst.frc.team5676.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.RobotDrive;
public class Robot extends IterativeRobot {
    RobotDrive myRobot;
    Joystick stick;
    DoubleSolenoid Piston;
    public void robotInit() {
    	myRobot = new RobotDrive (0, 1, 2, 3);
    	stick = new Joystick(0);
    public void autonomousPeriodic() {
  public void teleopPeriodic() {
	  myRobot.arcadeDrive(stick);
    	Piston = new DoubleSolenoid (0,1);
    	   		if(stick.getRawButton(5)) {
    	   			Piston.set(DoubleSolenoid.Value.kForward);
    	   			System.out.println("'A' button is pressed: Piston moves forward");
    	   	  else if(stick.getRawButton(6))
    	   			Piston.set(DoubleSolenoid.Value.kReverse);
    	   			System.out.println("'B' button is pressed: Piston moves backward");
    	   		else
    	   			Piston.set(DoubleSolenoid.Value.kOff);
    Piston = new DoubleSolenoid(2,3 );
		if(stick.getRawButton(3)) {
	  else if(stick.getRawButton(4))
		else
Piston = new DoubleSolenoid(4,5 );
	if(stick.getRawButton(1)) {
 else if(stick.getRawButton(2))
	else
		Piston.set(DoubleSolenoid.Value.kOff); }
     * This function is called periodically during test mode
    public void testPeriodic() {
option 2:
import edu.wpi.first.wpilibj.Timer;
    RobotDrive myRobot;
    Joystick stick;
	  while (isOperatorControl() && isEnabled()) {
            Timer.delay(0.01);
    	   		else
		else
	else
Unread 13-03-2015, 15:12
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: arcade drive
Q1. Do you have 3 different pistons that are supposed to move when different buttons are pressed?
Q2. Which motors on your drive train are plugged into each port?
Unread 13-03-2015, 16:00
Flywheel Police
Re: arcade drive
I cleaned your code up a bit. One issue you had was that you were creating new references to your pistons every ~20ms which is a bad thing to do. You were also sharing the same reference for ever single piston, also a bad thing to do. You can see that I moved the created 2 more pistons and created their references in robotInit().
    RobotDrive myRobot;
    Joystick stick;
    DoubleSolenoid piston1;
	DoubleSolenoid piston2;
	DoubleSolenoid piston3;
    	piston1 = new DoubleSolenoid(0, 1)
		piston2 = new DoubleSolenoid(2, 3);
		piston3 = new DoubleSolenoid(4, 5);
		if (stick.getRawButton(5)) {
			piston1.set(DoubleSolenoid.Value.kForward);
		} else if (stick.getRawButton(6)) {
			piston1.set(DoubleSolenoid.Value.kReverse);
		} else {
			piston1.set(DoubleSolenoid.Value.kOff);
		if (stick.getRawButton(3)) {
			Ppiston2.set(DoubleSolenoid.Value.kForward);
		} else if (stick.getRawButton(4)) m{
			piston2.set(DoubleSolenoid.Value.kReverse);
		} else {
			piston2.set(DoubleSolenoid.Value.kOff);
		if (stick.getRawButton(1)) {
			piston3.set(DoubleSolenoid.Value.kForward);
		} else if (stick.getRawButton(2)) {
			piston3.set(DoubleSolenoid.Value.kReverse);
		} else {
			piston3.set(DoubleSolenoid.Value.kOff);
Unread 13-03-2015, 17:31
FRC #5676 (Hornets)
Rookie Year: 2015
Re: arcade drive
At first thank you very much!!!
Question 1: Yes we do.
Question 2: I am sorry, I am not sure I am already home. Do you think that it could be just wired wrong? I tried the default labview code just for fun and it worked perfectly with the arcade drive. So shouldn't it also work with the java code with the "default example"?
Unread 13-03-2015, 17:37
Flywheel Police
Re: arcade drive
The way you have the ports in your RobotDrive constructor call they should be plugged in like this:
Left Front = 0
Left Rear = 1
Right Front = 2
Right Rear = 3
The constructor call has this order for the parameters:
RobotDrive(int leftFront, int leftRear, int rightFront, int rightRear)
If they are not in the right order the drivetrain will act funny.
Unread 14-03-2015, 20:59
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
cstelter will become famous soon enough
Re: arcade drive
option 2:
            Timer.delay(0.01);
The reason you see the symptom of your pneumatics not running is that telopPeriodic is *only* called when isOperatorControl() and isEnabled() are both true. So the first time through telopPeriodic() (which is supposed to be called every 20ms), you enter the while loop that is always true until you disable. You never leave the first call to teleopPeriodic() with this method.
You are mixing two paradigms-- this construct you would use for SampleRobot:
public class Robot extends SampleRobot {
    void operatorControl() {
            Timer.delay(0.01);
In SampleRobot operatorControl is called only once when the Teleop begins.
This is the style to use in IterativeRobot:
Up higher in the IterativeRobot base class there is something similar to
        	teleopPeriodic()
            Timer.delay(0.02);
It's actually much different, but the effect is the same-- Iterative robot will call teleopPeriodic() every 20ms as long as we're enabled in Teleop mode.
The net effect is in your option 2, your piston code will only be called once (maybe) only when isOperatorControl() goes false or isEnabled() goes false. I say maybe because it wouldn't surprise me if the teleopPeriodic call was on a thread that is terminated when either of these values go false.
But this explains the symptom you found.
Stick with Option 1 and take Matt's advice and you should get up and running quickly
